What is allowed to be left on a building site?
MikeSharp01 replied to Vijay's topic in General Self Build & DIY Discussion
good move - face the daemons head on. -
Nope, no motorways in Norfolk, but not 100 miles to the M11 - the closest I suspect maybe 40 miles. The M11 gets gets you to the bottom of the A11 which is still in Essex - the A11 / A14 bit of the run is good through Cambridgeshire & Suffolk then, when you switch back to the A11 and head for Norwich and into Norfolk, they hit you with a selection of annoyingly busy roundabouts interspersed by some great bits of dual carriageway.
We love Norfolk, spent the last couple of days there, going backwards and forwards round the Norwich ring road - one thing we can say is that the diesel is cheap up there, and the pan tiled roof's, the North Norfolk coastal path, big skies only a couple of draw backs- the two lane section of the M11 and the roundabouts on the A11, sort them and it will be even more of a pleasure to visit!
+1 I have wired ours as full radial lighting so every light fitting and switch has a wire back to the panel with a number. Appreciate that this cannot be done in this situation but we should move to it, or something equally simple for future builds. The only thing the old approach has going for it is that is probably uses less cable.
Sealant around sliding doors
MikeSharp01 replied to tokyotecubate's topic in House Extensions & Conservatories
Would be good to see the outside finish, should be Compriband, might be mastic as @Mr Punter says, post a picture to confirm. -
Welcome to THE forum for people like us, sounds like an interesting project.
That looks like Ilbruck air tight sealing foam, they just have not pressed it in flush with the foam. Our installers waited for it to skin then just pushed anything that stuck out back into the gap nothing stuck out. You can probably still do it as the Ilbruck foam stays flexible anyway. You can then run the final plaster board reveals round and plaster from there, assuming that is your build up. -
Just in case I am not happy with my drywalling skills. Did the garden room OK but the house has much bigger expanses and on 10m long wall directly to your left when you come in the front door so you will see any undulations I worry. Base of plaster boards is dead flat and all vertical joints are butt joints with tapered edges - it's just I wanted to be sure I had a get out if I need it.
I am wondering if it is OK to plaster over an easyfill filled drywall?
Welcome to THE forum for people like us. Ask away.
Looks very good, assuming 25p day rate and 17p night rate your energy cost you: £599 which is £50 PCM all bar the shouting - bloody good.
ASHP Unit distance from property?
MikeSharp01 replied to ashthekid's topic in Air Source Heat Pumps (ASHP)
Sorry. What I meant was that the smooth continuous operation gets interrupted by the demand for DHW so that needs to be factored in - does higher temperature operation, or changes to from, impact noise levels. -
How does this relate to the need once / twice a day to run up the DHW temp if PV / Solar not available? -
Cat6a cable everywhere, um, now what?
MikeSharp01 replied to Tom's topic in Networks, AV, Security & Automation
Only by having camera's in places you shouldn't - I dimly recall your being knocked back across a rubicund you were thinking to cross in this regard. -
Yes 96 + outlets does seem a lot for a house. -
Welcome to THE forum for people like us. Ask away for advice and support.
The house has MVHR so it looks like the overall outer envelope is what the calc should based upon that not individual spaces I would have thought. The whole place at a common temperature is the goal really although I suppose many would want the bedrooms cooler than the living area so that might be a problem. Life is full of compromises.
Short term fix needed. Any suggestions?
MikeSharp01 replied to TheMitchells's topic in Electrics - Other
Great it is sorted but you dodged a fire there, wonder what caused the 100A isolator to burn out, is it switched on/off under load regularly? -
I find push down simple enough, you can label it up simply and from the front it looks much tidier with short patch leads. -
Although that sounds odd, many think fibre should be faster unless you are on a low data rate tariff. Actually the theoretical Max data rate on 4G is 1Gbs for stationary users while domestic fibre can easily make well over 1Gbs, max in UK is 10Gbs, but the theoretical top is 5G which can max out at 20Gbs - in theory. The issue with them all is the infrastructure and number of users concentrated on your pathway. If you live near a motorway with a big jam suddenly you have a vast number of people using the 4/5G network and in the end that all hits the fibre backbone anyway. Oh and yes you will definitely want power to your data cabinet.
