https://www.bbc.co.uk/news/articles/cqjrpv218r0o
You won't find a supplier prepared to take the risk on you! You need to derisk it yourself by paying by credit card in 30K lumps - take care there are dragons here. Or go to your local betting shop and see if you can get cover that way. We used Norrsken and they worked out just fine. Carefully doing the measuring processing the order sorting install, doing it well and fixing the one problem we had, a seal getting caught up, diligently.
Hello, thought Iād introduce myself!
MikeSharp01 replied to Ted Hall's topic in Introduce Yourself
Now you are showing your age. -
The ecodan must be working if the water is heating unless the water heating is done by something else? E.g. immersion heater. If it is heating the water I would look at the changeover valve(s) - maybe it is stuck in water heating mode and the HP is getting a good go signal for that and the error only occurs when heating is requested but it does not get the positional feedback from the valve to say it iss ready to direct the water round the heating.
Yes can't see why not - sounds like a plan.
We use the membrane approach and it worked out very well, using the 4m wide Intello stuff gets the coverage pretty quickly and with fewer joins, although building the internal structure for the service void afterwards / on top has been a pain. We had some section with PB skin on the inside as well as outside so I put inspection holes through that so I could see I had it packed correctly and then covered it in membrane. Don't forget that well packed cellulose fibre is pretty air tight on its own. We achieved 0.2 on the PH Scale (ACH n50) and .29 on the BR scale for our first test, pre Plaster boarding. So far I have not damaged it but I am about to push the MVHR inlet and outlet through it so we will see how we get on!
Welcome to THE forum.
We want to achieve a shadow gap under the window sills on our build. We are intending to drywall it all if we can, I have made a model of what we want but I am worried that I won't be able to feather this in. Is there a better way to form this in a drywall situation? Here are some pics of my model. Any ideas gratefully accepted.
Yes we have Norrsken - very happy. As I understand it not all their windows are Viking, we have two windows that are not but are close enough to looking the same to make no difference and one of them has a tilt & turn triangular casement which is what we wanted.
The Psychology of Visual Heating
MikeSharp01 replied to ToughButterCup's topic in Other Heating Systems
Create a fireplace outside ' you have that amazing veranda / lougia We just stayed in a PH place in Skye with a log burner - we light it up and flung open all the windows stripped to our undies - not a pretty sight, perhaps marginally worse than a picture of pocster. -
You already did it - twice!
Just spoke to a colleague of mine, civil engineer / soil mechanic he has never heard of 20m piles for a to story building other than if you are building on a bog! Ask them why they need 20m piles.
A small 2 story property needs 20m piles! Sounds a lot to me - do they need to get to bedrock?
Hi and Welcome to THE forum for people like us. Sound like a great project look forward to hearing more.
Right to light is a thing but not for planning. It can cost a lot to go to law over it but it can cost the people who infringe it shed loads. Get a feel for it here: https://www.onebroker.co.uk/business/business-sectors/one-indemnity/right-to-light-insurance/
- 7 replies
- right to light
- planning
(and 3 more)
Do they have an established right to light (RTL) as there are specific rules for this. Is it 20 years qualifying period, can't remember, of they don't qualify there is no establish RTL. Also it only applies to habitable rooms not driveways. Both properties seem to be close to oneanother, I guess that's location, location, location for you. Have a look to see how many houses have got extensions like the one you are planning and see what the planning history for them is to get an idea of whats been allowed. Also RTL is not a planning issue it a civil law matter.
- 7 replies
- right to light
- planning
(and 3 more)
We went with Norrsken after looking at Rationel, Nordvest and Norrsken. The problem with Nordvest was that they didn't have a local installer and only Norrsken could do a triangular tilt and turn window. We have been very happy with our Norrsken windows and Norrsken themselves.
We're featuring on Grand Designs next week š„
MikeSharp01 replied to thefoxesmaltings's topic in Property TV Programmes
Just watched it - you two did a grand job. Mind-blowing effort š -
Hang a tape rule out of the window to the ground and measure it.
