Everything posted by Sparrowhawk
Refurbish or replace UPVC bay window?
Sparrowhawk replied to Sparrowhawk's topic in Windows & Glazing
Thanks all! The trims and quadrants being the "strips of shame" between the window and the wall? I removed a section in the autumn. Behind it was... the open cavity. With slivers of daylight visible around between the outer brickwork and window. Instead of plastered window reveals we have the original half inch timber which was cut back when they installed the windows. My plan is to rip it off this year, close the cavity, seal the window to the new closing, and get a plasterer in to make good. As you can see, 3 trims stacked on each other between the window sill and window! Would this go along the edge of the outer wedge gasket? Thanks, jit seems such a waste (as well as unnecessary expense) when the UPVC is okay. And thanks for the link to replacement glazing, exactly what I wanted to see what it'd cost. How would I find out which paths are required so as not to muck it up? I drilled and filled the joint between a UPVC door frame and the abutted window with foam last winter as the extension had settled since it was built and the mastic pulled aprt, so (again) cold air came in through a half-mm gap up the join. Foaming that made a massive difference. I was wondering how to get the beading out, so many thanks. Now to find a few YouTube videos and see this in action. These windows regularly get hit by 40mph+ gusts throughout the winter months and these rooms are "breezy" - if I close the door out of them and put my hand under it, there's a stream of air. I can't wait to have to worry about ventilation -
New member - stuck for what to do next to warm the house
Sparrowhawk replied to Sparrowhawk's topic in Introduce Yourself
I keep coming back to this idea, it appeals because it would solve the airtightness issue alright. However it's a one way shot with no comeback if there's any problems. As I found a half-brick missing in the inner-leaf of the cavity in the first floor void where they'd dropped wiring through, I think I need to find and seal these up first before thinking further about cavity insulation, to stop the house being filled with foam/beads/insulation! If there's one of those in every room that's a heck of a lot of holes that are letting air in. -
Thinking about the bay windows: -
Our house has south facing UPVC double-glazed bay windows in one room upstairs and downstairs. I'm looking for advice for what to do with them. We don't know the age of the windows but maybe 25 years old? The frames are in fair condition, we had a locking mechanism replaced as it had rusted solid (coastal location) and bits are rusty but otherwise okay. However, airtight they are not. The bubble gaskets on the opening windows no longer seal and I'm replacing those, which makes a noticeable difference. And has made the air leaks around the glass panes more noticeable (marked by post-it notes above) The windows face the prevailing wind and the mould in this one should've been a giveaway that air and moisture is coming through, even before I went round with a candle finding draughts. Looking at the rubber seals around the glazing units they look worn down (for want a of a better phrase) and aren't angled up the glazing like they are on other, 20-year-old UPVC windows. I suppose these draughts can be sorted by taking out the panes and replacing the rubber seals around them. But then if removing the glazing, what about replacing it with new glazing units? They'll have better U-values and losing less heat out through the windows in winter would be good. I haven't got quotes so not sure what the costs are like. And then the option that gets every double glazing company salivating. Full replacement. I know that's not going to be cheap but don't know the price jump from replacing units to replacing it all. As brief background we're doing what we can to stop draughts and insulate, but it's never going to be passivhaus and as we live in it we can't strip it to a shell and rebuild. There is a cost balancing issue here e.g triple glazing would not make sense given the thermal inefficiency of the rest of the house, and replacing these windows probably wouldn't either. The north facing ones on the other side of the house, maybe have a better case. What difference would replacing the glazing units make? Anyone done that and sourced them themselves?
THE NATIONAL SELF BUILD AND RENOVATION SHOW
Sparrowhawk commented on MikeSharp01's event in Community Calendar
Is there a list of exhibitors? I've poked around their website but found nothing... -
I've been thinking about this and a few possibilities are: to get a power station built there may be contractual purchase amounts. So always going to be some as would be more expensive to tell that power station to "shut down" ability to ramp up quickly means the power station has to be already running, so must keep it generating at a low level Be interesting to hear from someone in the know about gas power stations.
Practical experience of ceiling acoustic performance sought
Sparrowhawk replied to dnb's topic in Plastering & Rendering
I found this 2020 PDF: https://www.gyproc.ie/sites/default/files/The White Book Oct 2020.pdf For the 2022 version it looks like you have to download it in chunks rather than as a single PDF, starting from https://www.british-gypsum.com/specification/white-book-specification-selector/white-book-overview -
Sealing the bottom of the door into the garage
Sparrowhawk replied to Sparrowhawk's topic in Heat Insulation
That's a good idea, I've done it for eaves cupboards and it works very well. The step is a bit of a problem as my dear wife is not the most coordinated person and I can see her catching her foot on it and going flying... I'll mock one up and see how quickly she injures herself Thanks, TIL those existed. It looks like I'd need to cut more off the bottom of the door to make it fit and/or cut it at an angle (an excuse to buy a track saw?) -
Started my first side-thread on the door into the garage: -
We have a door from the utility room built in the back of the garage into the garage itself. At the bottom there's a quarter inch gap between door and floor. The previous owners added a brush strip on the inside, but wind whistles through. What's the most effective way to improve the airtightness? To complicate matters (maybe) the floor isn't level under the door, as the tiles stop halfway under it and a wooden panel continues beyond, a tile thickness lower.
Deciding on heating is a challenge! I am still prevaricating over questions like is it better to run a radiator to the unheated kitchen, or once draught proofing is done will it be goood enough that an eletric heater can cope? Much cheaper and less disruptive if it will do, but more expensive to run. Mmm that's a really good question. I love looking at thermal images but they haven't proved to be that useful. Part of that was inexperience (I borrowed it during the 20/21 winter lockdown and had to figure it out myself), lack of a large temperature differential (having it for December 2022 would have been far more useful) and the big air leaks drowning out the detail. The best it did was help me trace pipes without lifting the floors. If/when I borrow one again I would be using it to check things I've fixed e.g. for cold spots in the loft ceilings (is there wind washing / did I not pack the insulation in properly?), leaky rubber seals on the double glazing (unlike you we are trying to refurbish at least the bay windows, as too expensive to justify replacing). But for airtightness the blower testing is head and shoulders above it. -
I filled that hole with Soudal expanding foam and stuffed insulation between wall and joist as a temporary fix (floor had to be relaid by this morning). Now making plans to cut and lift all floorboards by the wall, and remove skirting board to seal all draughts along the length of the wall. Foam gun wouldn't close and kept letting foam out so I took it outside to clean. Unscrewed almost-new can from gun, and it didn't reseal. Cue jet of foam spraying everywhere. The garden looks like a blue snowstorm hit. -
Cost of airtightness retrofit?
Sparrowhawk replied to anonymous's topic in Energy Efficient & Sustainable Design Concepts
@anonymousHow did you get on with your airtightness test, and what did they find? -
Noise requirements and planning consent
Sparrowhawk replied to JamesPa's topic in Air Source Heat Pumps (ASHP)
Do you know how the residents found the noise after the wind farm was built? I have low noise tolerance and living with a motorway a mile away and in direct line of sight was distracting and painful. I have heard that people complain about the noise of wind farms but when I have walked near one I haven't noticed much sound. -
Thanks. How reliable have you found them? Has the cover ever jammed on yours if dust builds up etc on them? The toilet is on the more leeward side of the house so an insertable draught shutter will be needed for the kitchen extractor as well, as it bears the brunt of the wind.
I've got a kitchen extractor on one side of the house and a cloakroom extractor fan on the other. I live in a windy location and when it blows it goes straight in through one and out the other. They have those 3-flap covers on the outside which do nothing, so I was going to try a backdraught shutter. After reading reviews of cheap ones on Amazon I was going to get a Naber THERMOBOX back draught shutter and try it - but both my fans are in 100mm ducts and Naber start at 125mm. So I'm back to square one. Any recommendations for relatively airtight backdraught shutters?
Happy Christmas everyone! We've had strong winds since Christmas and the front bedroom wasn't in use, so I took the opportunity to lift the laminate flooring and see where the draughts are coming from. There are big draughts under the skirting board to the side of the bay window (as well as in the bay window itself) and that was the easiest place to start. The laminate was easy to lift, laid in 2016 and didn't go under the skirting board. 2 floorboards were screwed instead of nailed so out they came. Looks like these planks were taken up for rewiring. White cable is the old stuff, grey the new. Bit more brick under the floor than I expected. Nice to see that when running heating pipes through the solid internal wall they knocked a chunk out of the wall rather than drill holes I digress. Looking at the external wall to the left of the window it's easy to see why it's so draughty here. At some point a hole approx 3x4" has been punched through the inner leaf and into the cavity. Sorry about the photos, there is only a plank's thickness between the last joist and the skirting board so a tight hole to take a picture through. Hilariously (got find something to smile about here) for the gray cable rewiring they drilled a tunnel 2 to the left of this hole to put the cables through. Didn't block the big hole up, oh no: To practicalities. What's the best way to make this airtight? I was thinking PIR board roughly cut around the cables and foamed into place, but without removing the original skirting boards it's going to be difficult to get it into there. Something thinner and more flexible to seal the hole, and then mineral wool or similar rammed in around the cables to stop any airflow? -
[Software engineer here] Not wishing to derail the conversation, but what have you used to do the schematic drawings? As I reverse engineer my 1930s-and-badly-extended house and discover where the pipes run (and which are disconnexted but still under the floors) and where the cables go I'm thinking that a model to record this information would be most helpful. In my mind I can see a 3D model of the house showing where the pipe runs are, annotated with details; I'm guessing this is done but no idea what that is called or how to do it. You've gone for schematics which is another way to do the same thing, though abstract enough that I find them hard to follow. I've got a couple of floorboards up atm trying to chase down air leaks and came across electrical wiring I wasn't expecting. Be nice not to forget about that by the next time I lift the floor. Do people do this?
Sealing skirting board to click vinyl flooring
Sparrowhawk replied to WWilts's topic in Heat Insulation
Do you have a large enough gap for the expanding foam taple like https://qualitape.co.uk/expanding-foam-tape/? I've used decorators caulk before and it has cracked over time with movement. Silicone sealants would last better but are more messy than I like and can't be painted over. -
We had 25-45mph winds yesterday and they were hitting out house front-on. You could hear the wind rushing through the warm-roof sections. This gave me an idea... would opening a window on the back of the house depressurise it like a blower test? The answer was a resounding "Yes". I have no idea what pressure difference that created (anyone want to guess?) but it revealed air leaks I didn't know about. I wish I had a way to quantify the flow. While each draught was small, the flow under the shut door of each room was sizeable, and was the way I measured the relative draughtiness of each. Some highlights starting upstairs: Front bedroom Coming up under the flooring in the bay window and at the flooring cutbacks in the corner of the bay window My wife says her feet get freezing sitting there Through the crack in the ceiling direct from the loft (less than 0.5mm wide) Plug sockets Suspect the "strips of shame" round the double glazing are all leaking through hairline gaps around the frame. Caulked a lot of them but... For the size of flow under the door, must be more leaks (under the floor?) Bathroom No unknowns here, extractor fan, waste pipes under the floor, and a little from the aging double glazing Bedroom in the newest extension I thought I'd got this pretty airtight but opening a Velux in the room showed leaks under the skirting board all round the room (starts to explain why in windy weather dust blows across the laminate flooring towards the middle of the room) plug sockets eaves storage (these leaks were known; I've foamed everything but can't get it airtight. The garage is also underneath) A room at the back that spans the 1920s house and the first extension via a gap knocked in the old rear wall When opening the Velux window in this room... Enough coming in from the eaves storage (which I lovingly taped and foamed in 2020) to make the loose MDF board move back and forth!! Under the floor around radiator pipes and cracks between flooring and walls. Significant volume of air. With the cracks I couldn't feel with my hand, but a flame would flicker every time a gust passed over the house Plug sockets Heading downstairs, I taped the cloakroom extractor fan shut and then went straight to the dining room which is hard to get warm. I shut the doors into the hallway and lounge, and taped a dust sheet over the opening into the kitchen. To create the pressure difference I opened an 80cm x 55cm window. The results: Masses of air from kitchen Much air under door into hallway Bigger Much around doors lounge (but didn't block under lounge door into hallway, so skewed test) A little coming out under skirting boards - I've sealed some already It was impossible to keep the dust sheet taped over the kitchen entrance. Here's a picture of it filling like a sail with the draught coming in via the kitchen. The kitchen has a concrete floor and no heating built in and is always cold. I found a few air leaks: Kitchen extractor fan. A massive known problem. The louvred vent outside does nothing to stop air blowing in Door to garage. It's got a brush strip at the bottom and is not sealing well Minor (in comparison) leak near the hinges of the UPVC side door. Most annoyingly, a stream of air from behind the kickboards under the fitted units. I found one airbrick; need to see if there's others. I taped up the extractor fan (a balancing act on steps as the wind whistled up the narrow gap between us and the next house) and it reduced the flow from the kitchen to dining room maybe by half. Dust sheet still filled like a sail but not as much. So... we got a few heat retention problems. Plug sockets and skirting boards are easy wins. I don't know where to start with the wind blowing through the first floor floor void. I'm guessing t's going to need floors up or ceilings down, and then taping joist ends and insulation adding to slow down whatever wind still gets in? All in all I had MASSIVE fun doing this testing 😀 -
300mm in the side extension, I added a 200mm top up before the winter. The ventilation remains good. In the 1920s part of the house (most of the loft) it's still 100mm. There was woodworm when we moved in 3 years ago which we had treated, and I've kept the joists visible so I can see if it comes back. No signs of return, so I am thinking about adding a 200mm top up next year. I have not, but there is one 6 inch square hole in the floor stuffed with glass fibre where the central heating pipes go down, and I will pull that out and take a look. It does, we are lucky this 1928 house had cavities. What that does mean is that the rooms in the extensions have an open cavity wall as an internal wall, because they pierced the original rear wall of the house instead of removing it. That is excellent advice. When they extended the house the roof starts at floor level in the upstairs rooms, and they shoved 50mm PIR between the new joists. It stops before the loft - I'm guessing below the joist or beam that is across the top of the old walls and blocks the top of the cavity, as no PIR is visible from the loft. I'm not sure if that's a good interface but that's a bit of the house I hope not to touch! Will do, thanks! -
I confess I don't understand ACH vs infiltration rate, and I'm wondering if I should have used an ACH of '7' rather than '1.5' which doubles the figure again. So I've kept it at 1.5 and also tried 0.5 as well below. Something else for me to read up on! Thank you both, so glad you've sense-checked my data! I went back through the lounge details and I'd set the internal walls to have -2C on the other side. Correcting for that it now says 2737W/9344 BTU is required. Leaving out doors & the bay window, the data I'm using is now: Room Wall material UValue Adjacent °C Dimensions Floor Bare Boards on Joists, Airbrick 2+ Sides 0.82 -2 °C 24.18m2 Ceiling Timber Joists, Boarding 19mm, Plasterboard 13mm 1.62 10 °C 24.18m2 Wall 1 Brick 105mm, Air Gap 50mm, Heavy Concrete Block 100mm (+ 13mm Plaster) 1.3 -2 °C 6.2m × 2.55m (15.81m2) Wall 2 12.5 mm plasterboard, timber studding, 12.5 mm plasterboard 1.7 18°C 3.9m × 2.55m (4.54m2) Wall 3 13 mm lightweight plaster 105 mm brick, 13 mm lightweight plaster 1.69 18 °C 6.2m × 2.55m (14.21m2) Wall 4 105 mm brick, 50 mm airspace, 100 mm dense concrete block, 13 mm dense plaster 1.77 -2 °C 3.9m × 2.55m (4.99m2) (Wall 1 & Wall 4 differe because I don't know the actual construction so hedged my bets. Most of wall 4 is bay window glass) Reducing the ACH from 1.5 to 0.5 reduced the heat loss requirement by another 500W. -
That has been my suspicion. If the "good news" comes from those with a vested interest in selling it - I am doubtful. A reason for posting here as a sanity check, as sitting in a 15C I start to soften and think "well maybe they're right and it would be okay" Yes that's horrific. Different to the 'green goo' issue with some cables. Thanks for posting, it's good to hear from someone who has seen the problem first hand.
