JoeBano
Everything posted by JoeBano
How’s does your Ufh weather compensation affect your heat pump one?
Not been a problem yet, have both heating and cooling on weather compensation so they shouldn’t hit the desired room temperatures on the stats. I suspect hot days and cold nights in autumn maybe a different story but I’ll see how it goes. I can change the deadband higher if needs be.
Sounds complicated? I know you probably want to use what you’ve got but heatmiser fan coil stats are good https://heatmisershop.co.uk/app-control-fan-coil-thermostat/ It has 1 call for heat and 1 call for cool, used a relay to switch a volt free connection on my heat pump. Has a 2c deadband, my set up is heat to 20c and cool from 22c, flick automatically from each with both having weather compensation. If you get the neohub you can automate IFTTT app with octopus energy rates and local weather forecast, this service is all free.
I’ve been running my fan coil units all summer on 12-14c flow temperature. I get water beading on my copper pipes when it’s really humid outside which isn’t too bad to worry about. The water coming out of the condensation trap I’ve had to bowls under them! A insulated pipes and condensate trap pipe work is on the list for me.
Recommend a Silicone Render system ? (DIY / newcomer friendly)
JoeBano replied to bmj1's topic in Plastering & Rendering
Johnstone storm shield system -
I wonder how many on the list are actually doing cooling aswell? Done well tweaking your settings.
I pay more in standing charge then i use in gas for cooking on the hob.
@JohnMo off topic, what heat pump do you have? My friend is starting his self install heat pump and yours was a good price and quality.
- 70 replies
- utilities
- electric bill
(and 3 more)
ASHP without Boiler Upgrade Scheme?
JoeBano replied to timhowes's topic in Air Source Heat Pumps (ASHP)
In 2008 you would need a buffer as they were all fixed output, now with inverter driven heats pump like yours they can modulate down to the heat demand. I managed to get a grant aerona3 10kw, megaflow cylinder and a cordvari buffer for £1600. Right place right time. -
When I was on octopus agile it was a lot cheaper then octopus intelligent go which currently on. Only swapping over because I got an electric van. On agile it’s cheapest between the 10am to 4pm. You can get tracking apps to tell your technology to come on when it’s cheapest 4 hour window. In summer you get paid to burn electricity. I would swap back but I need to charge my van (60kw) at night when I’m home.
- 70 replies
- utilities
- electric bill
(and 3 more)
Fancoil - Best invention ever no contest!
JoeBano replied to Dave Jones's topic in Air Source Heat Pumps (ASHP)
. I’ve got myson ivectors (1000x600) fan coil units, 1930’s detached outside walls insulated to 0.3 U-value. Running a flow temperature -2 35c on lowest fan speed nice and quiet. Now it’s 32c outside running it at 15c just above dew point and its fan speed 3 to keep 21c. So If you are thinking about cooling more than heat, insulated pipe work to run lower than dew point or bigger units if you can’t insulated pipework. These Panasonic units are a nice looking unit, some are nasty out there. -
Ducted chilled water fan coil options
JoeBano replied to HughF's topic in Air Source Heat Pumps (ASHP)
I’ve got heatmiser fan coil stats do cooling and heat. Need 3 pole relay to get it to work because I’ve got a 4 pipe buffer setup. -
I got a tiny bit of condensation on my pipe works yesterday but it was very humid. 12c flow temperature seems to be the best outcome for me. -
I was having a look yesterday for my kitchen, found theses https://theheatpumps.co.uk/products/chilled-water-fan-coil-units.html I have no idea how quiet they are. Might be a starting point…. ive got myson Ivectors in the bedrooms quieter than a normal fan blowing about, managed to keep the bedrooms at 20-21 while it was 29c outside without insulating the pipework. They are control by heatmiser fan coil stat -
You could swap the radiators for fan coil units? I swapped mine beginning of last summer worked a treat. Not insulated the pipework, 16c is my flow temperature not had any issues. I’ve got myson Ivector units, think they are brilliant, lowered my heat flow temperature to 32c @ -2. My bedrooms suffer room overheating in the late evening, they kept the bedrooms at 20c on the hottest days last year.
Smart thermostats - Nest thermostat losing many features
JoeBano replied to JohnMo's topic in Other Heating Systems
Glad I changed mine to heatmiser neo stats now. Always got sick of nest changing my schedules -
If you don’t want any issues in 5 years time I would follow the spec. With silicone render you get issues in the long run. You used be able to get anyway with just OCR on blockwork, primer and finished in tf but Weber now insist on rendaid basecoat with meshcloth for guarantee.
ASHP - Weather Compensation AND Zoning?
JoeBano replied to SBMS's topic in Air Source Heat Pumps (ASHP)
I run 2 zones upstairs and downstairs. Gone back to a 4 port buffer and now got a balancing valve on the return heat pump side. Seen the short cycle reduced in this mild temperatures. Probably not the way for a new build but I live in 1930s solid brick house and with one room can be 21c and the next room 19c, completely different scenario to a new build. I use my stats as a temperature limiter, weather compensation set up for a max room temperature 21c @ -3 room stats set for 21.5c. The other reason is cooling in summer it’s needs very little cooling downstairs but upstairs is very warm for sleeping. -
ASHP - how noisy are they in reality
JoeBano replied to Walshie's topic in Air Source Heat Pumps (ASHP)
My extractor fan in the downstairs toilet is louder than my grant aerona3 unless it’s doing a hot water cycle the compressor noise is louder. -
My grant anerona3 hardly goes into defrost, it is sat on my garage roof gets plenty of circulation up there. I hope the new ones have a modulating water pump rather than a fixed one on mine.
thinner alternative to flowing liquid screed - views?
JoeBano replied to mikeysoft's topic in Underfloor Heating
I used Weber floor system in my hallway needed something that could take foot traffic in 3 hours. It’s 50mm thick I used Ritmo render machine, 22 bags in 30 mins. It was warms up very quick compared to my traditional floor screed (65mm) in my kitchen but that keeps the heat way longer. Bag screed costs 3x times more than traditional screed. -
My living room wasn’t hitting 20c I wanted it to be, tried increasing the flow temperature that didn’t work. In the end I drop my flow temperature down back to original temperature and dialled my flow rate on the hallway Ufh and now it’s achieving 20c, hallway is still hitting 20c aswell. you might just play with it’s the balancing, how loops do you have?
Good video on how to work it out. Don’t know glycol heat capacity, someone will know here.
Can the flow temperature be too low?
JoeBano replied to JohnnyB's topic in Air Source Heat Pumps (ASHP)
Since I replaced my radiators with fan coil units and dropping my flow temperature down to 32c it was short cycling a lot. Managed to balance my pumps got better run time, turned my max flow temperature to 35c and now getting 4 hours run times. I don’t know why but my grant aerona3 doesn’t like super low temperatures. -
Good job I swapped over to octopus cosy this morning! I’ll swap back in April.
