Construction Channel
    14
Everything posted by Construction Channel
  1. Jcb's are all roughly the same size Mini diggers vary quite a bit but i would guess the one in the pic is about 1.9ton
  2. 1. I doubt the hinges would take such a wide door. (there is a lot of weight a long way from the hinges) 2. I would think the panels they make the doors from start at 1200 x 2400 so you would have a joint in the large panel anyway.
  3. The problem with very wide boards is they want to cup (curl up across the grain), You could biscuit some boards together but for strength you would probably be better laminating and off setting two layers. How are you planning to support the outer edge of the tread? I havent done much work with spirals but if you want to cantilever a 4' plank of a central column it will either need to be very thick (50-60mm), or have a big assed brace. The hole in the plank wont give you very much strength because the grain will just want to sheer out so most of the weight will have to be taken by the brace.... I suppose the handrail could offer some support but i really dont know very much about them.
  4. Im fairly certain the hole in the middle will be the wrong size. I had a lot of trouble trying to enlarge the hole on one to get it to fit my skill saw. Ended up using a plasma cutter iirc
  5. Have you still got the old bricks / stones?
  6. Its a bit late for me but i do like that insulated section. Great way to get over the issue. I also agree that in an already lit room they wont have as much of an impact as they did in my bathroom. That said, placed correctly it might still help
  7. You could bend it further. I think each "bending bit" would go up to 45deg (they're a variable angle thing that you twist to incease the angle). So with 4 bendy bits you could make the horizontal periscope that you want https://www.sterlingbuild.co.uk/product/velux-6013710k14-adjustable-elbow-for-14-sun-tunnel
  8. In my experience suntunnels are great. Rigid are far better than the flexible ones and the bigger the better although the smaller ones are still better than nothing. My bathroom before: My bathroom after: This is the 14" rigid velux version with about a 30 deg kink in the pipe. The insulation issue isnt really to do with the tunnel itself as you can wrap that fairly well with insulation. The issue is the 2 ends where the internal bit is a fairly rubbish attempt at plastic double glazing Hth Ed
  9. Did you manage to keep hold of the little cap? Always fun when that goes sailing down a main run ?
  10. I wouldnt. Firstly because its an expensive way to do the job, And those couplings are generally used for connecting to clay pipes. Not saying it wouldnt work, just unnecessary here
  11. Indeed. Were not talking about a courtesy dab of vaseline here.
  12. Also little tip for fitting pipes in a trench is to get the end into the socket loose (plenty of lube) then bang a couple of road pins (bits of rebar) in either side of it tilted out slightly. (this just helps to stop it jumping out which it will try to do). Then put that long shovel in the pic against the other end of the pipe and lever it in. (saves a lot of bending in the trench + gives you that extra bit of force) ?
  13. You'll need a 10 on that. I wouldnt worry too much about small nicks in the rubber as long as they're not too big. Fwiw weve never actually had to air test any foul drainage. Usually we just bung everything and fill the stack to an upstairs aav and make sure the water level doesnt drop overnight. Also dont use the adjustable bend if you can help it. Especially underground. You can get a couple of degrees play in each coupling anyway so you will be able to get it with standard fittings.
  14. 15 5+5*2 Silly game 5+19*2 43 but i blame the poor resolution
  15. You will not regret investing in a rail saw (plunge or otherwise) Personally i just bought an attatchment for my circular saws but i do also have easy access to a plunge saw if i ever need to cut out for sinks. The beauty of circular/plunge saws is that they are little mohammeds. Where the wood is the mountain ?
  16. Use 40mm nails is my best advice. Or hire the gun but remember the gun won't get to all of them.
  17. I'm a bit late to this party. But this sounds similar to the missing pound riddle. You don't want to get to 180. Else you would be going straight back up, (in that case you would want the 87 bend) You want to get back to 0. Hence a 92 and a - 92 being what you want.
  18. I thought my tongue was spelt wrong....... Just can't trust autocorrect nowadays.
  19. Building control officer
  20. You are. Or at least we always have been and we have had many houses passed by building inspectors. The horizontal band was a bit toung in cheek. But when the bco turns up and sees you have made a very nice job up to regs they will be much less likely to start looking for other issues.
  21. This is the foil tape stuff. If you use 100mm one strip will do both sides of the stud. Fixman 191666 Silver Aluminium Foil Adhesive Tape 100mm x 50m https://www.amazon.co.uk/dp/B00FHXGGXA/ref=cm_sw_r_cp_apa_i_W4cyEbK94YDKY You could even run a band of it horizontal at about 1200 off the floor and then everyone would just assume there is a noggin behind it.
