Everything posted by Susie
What can you do with a drainage field, long-term?
Susie replied to Drellingore's topic in Waste & Sewerage
Is it classed as agricultural land or garden? What did you want to do with it? -
There is a spreadsheet at https://www.futurehomes.org.uk/avoid-overheating You can fill that in and if you get a pass you're done but it is very difficult to pass the spreadsheet method, this is supposed to be the simplified method but you will find it’s far from simple. It does not take into account MVHR, solar glass, shading. For the dynamic modelling it’s buy the software or pay a consultant. I had a simple single floor rectangle but still failed. We were not overglazed but did have a lot of non opening windows because we are having MVHR and I don’t want flies inside in summer. Plus other reasons. Have a look at the spreadsheet and if you need any help ask away I have learnt a lot.
I know you’re doing PHPP but have you done your Part O modelling yet. You need to do that ideally before the planning.
Sounds like it was ok to start the build so @LSB probably on the old regs. we haven’t submitted the building regs plans yet so are definitely on the new regs the part o model has to be submitted with the plans. yes @Alan Ambrose Simple is not simple but the dynamic is even harder.
Hi @LSB I thought you had already started building. if you got building regs in on the old regs then you don’t have to do this.
We have our planning permission but fall under the new regs so for Part O Overheating we have to pass either the simplified model or the dynamic model. I have created my own spreadsheet and by changing nearly all my windows to opening and to opening inwards to get round the arms reach criteria and a few minor size changes to increase ventilation we have just scraped through as a pass. My architect has given me my sketchup file and this weekend I plan to start looking at the Thermal Dynamic modelling TM59 with Part O adjustments using TAS software. The simplified model does not take into account the MVHR or the overhang shading so I am hoping by spending a bit of time and money on the software I can keep some of my fixed windows. As this is a new reg if any one wants to look at my spreadsheet I have attached it below. I’m a Mac user so if you run into any problems on Microsoft excel let me know and I can amend it. Thanks @craigfor your help so far. It’s been a steep learning curve to get this far so if I can help any one else on their journey that would be nice. So I’m off to start another steep learning curve using the software, just preparing with a big breakfast and lots of coffee. Any tips on the software welcome. https://kb.goodhomes.org.uk/wp-content/uploads/2022/07/220720_FHH-Part-O-guidance-Final-LT.pdf#page44 https://www.edsl.net/tas-engineering-downloads/ Part O Calculations Simplified method.xlsx
Welcome it’s a great site. and you will learn lots and get lots of different ideas!
I like the vent axia S for my build also, 135m2 . I was advised against the xs as the set up is a bit different I can’t remember why but the Wi-Fi bit can be purchased separately for the s model and it works out cheaper than the sx. not purchased yet but BPC have done some plans already for free enough to get through new SAP and Part O hopefully. you need to compare the SAP test results for your size of dwelling kitchen+n the thermal efficiency and SFP note BPC and some other sellers had the out of date SAP test 2013 is the old one I think it’s 2016 but you should check it’s been a few months since I looked at this. The test changed and you need to check your comparing apples with apples.
Great another local member. im in Morwenstow. The right end of Cornwall I know of a little house just by the side of the main road with ground mounted solar and wind turbine. If that’s you I’m sorry but I look out the car window every time I pass thinking how nice it is.
Hi welcome land for sale near me in Morwenstow but it’s for 5 houses. what are you looking for and I will keep my eyes and ears open.
Side Extension moving along, slowly but surely
Susie commented on MikeGrahamT21's blog entry in Back on the self-build waggon...
Warm roof is above and between the rafters. Hybrid is between and under rafters. Both give a warm loft space. A warm roof doesn’t need the air ventilation that a hybrid roof needs. -
We’re The Old Cow Shed but I was told by a local farmer who use to play on our farm when he was a kid it was a bullock shed. It’s close enough for a townie. We’ve called it The Old Cow Shed for 6 years it seems wrong to change its name now. Six years ago it never occurred to us to build our own home. The name was just to identify which storage shed.
I like seeing my address pop up when you enter your postcode on a form.
Ideas wanted to pass Part O Simplified modelling or to use Dynamic modelling?
Susie replied to Susie's topic in Ventilation
Unfortunately no its a bit similar to the SAP software I believe some architects are doing it in house others are farming it out. the advice is get it done before planning permission but guess what our local Architect got the planning first and then tells me he isn’t doing the new Overheating calculations that have to go to BCO before you start the build and is using a local company instead. More delays. -
Don’t forget which way to hang the doors into hall not into room. and if you don’t like that swap after you get completion certificate.
I have been told by architect that because it’s new regs some people were fudging the results but BCO have caught on and are checking all spreadsheets on the simplified model throughly. got a company in Bude ringing me back later hopefully for the Dynamic modelling. I need the software for the dynamic modelling as I just can’t pass the simplified modelling. The simplified doesn’t take into account MVHR, shading by other buildings it designed into the build such as overhangs and canopies. For the dynamic method… To demonstrate compliance using this method, there are a number of bits of guidance that must be followed, including: CIBSE’s TM59 methodology for predicting overheating risk The limits on the use of CIBSE’s TM59 methodology (set out in AD:O) The acceptable strategies for reducing overheating risk (set out in AD:O -
I have used Jeremy Harris’ spreadsheet for heating. This is to pass Part O and it’s a real pain for a bungalow that is facing south for solar PV (and the views) but because it’s a bungalow has restrictions on night time opening of windows. I have to make every single window including the plant room open inwards to meet the arm’s length criteria but some are too high to open manually. it’s just a load more red tape for us small builders who have to pay to have another report done because we are so well air sealed we use MVHR for ventilation. If I was building a few houses I could model one dynamically as a so called worst case and use those results for all my builds. it looks like another grand for a bit of paper that is going to say my house has solar gain because it faces south but with MVHR it’s ok. that’s my middle of the day moan over. -
This is the telephone number from my email from them. 0800 0328660
I would be happy to pay £900 if they took the MVHR into consideration in the modelling before changing my fixed windows to opening. I shall look up R J energy consultants -
The shading required is a bit misleading I live in a medium risk area and so do not require shading. The target is no shading and my answer to shading provided? Is no if I was in London for example in a high risk area I might be required to have shading my target would be yes to shading and I would have to answer yes to providing shading, and it would have to meet set measurements. it’s a shame it doesn’t count in the simplified model but if I do pay for the dynamic modelling the overhang may be considered. -
Having got our planning permission in October our architect is only just looking at drawing the building regulations up, and looking at Part O. He wants another company to do the modelling, simplified and dynamic. By my own calculations, we haven’t passed the simplified model, and I have had to change almost every fixed window to an opening window. The cost of this change could lead into thousands of pounds, and a possible increase in the sight lines. Since we already have planning permission I don’t really want to start changing windows too much. I think the Dynamic thermal modelling method will take into account MVHR, which we have already planned to include in the build. Does anybody know if dynamic modelling can take MVHR into consideration and keep most of my fixed windows. I don’t know how much the dynamic modelling would cost but would hopefully not be as much as changing all my fixed windows to opening windows. We are also a bungalow with downstair bedrooms, with 2 windows open 300 and one 150 at night. We are in a very safe area and I don’t see this as a problem especially as in reality they would be on vent with the MVHR on but I do have to take security into consideration for the simplified modelling, hence the restriction on opening but I don’t know if they are opening too much to pass security. I don’t want bars or grills on the window. Notes on calculations All windows are single pane and top hung, which gives me only one ventilation area for each window opening. Glazing area is calculated as Window openings less 10mm packer and 53mm Frame. Opening pane is calculated as window openings less 10mm packer. 53mm frame is similar to Velfac and Ideal combi rather than Rationel and Origin OW80 casement type window. I could recalculate with larger frame. Max stroke length of .650 (arms reach) has been applied to most windows reducing opening angle, they were originally meant to be fixed picture windows. Ideas on ways of passing Part O Sill heights have been increased already. Change windows from opening outwards to opening inwards, the arms reach criteria means I can now open my windows more. What is the opening angle of an opening inwards window e.g Zylefenster? Do I model as 700? I shall look into this tomorrow. I could somebody to do dynamic modelling to include MVHR and solar control glazing. Recommendations for dynamic modelling companies are welcome.
Contact Openreach they have been very helpful with me. I contacted them early. We are digging the trench next week for water, electric and Openreach. this is what they are providing for free. 100271 x 90m:30 lengths of duct 56 094929 x 2: .Bend duct 56A 090126 x 1: .Bend duct 56 house end 095002 x 3: .Bend duct 56B 095096 x 1: .Connector bend 4 095037 x 2: .Joint box 26 075874 x 2: .Frame and cover 102C 054822 x 100m.5/0.5 PET cable 041304 x 1: .Draw rope bag 250m 071987 x 1: .Cover 101A 072180 x 3: .Capping 25 Susan's builders will install our duct and cable from new house to EL pole Xxxxx. Installer to erect two spans of drop wire back to DP 8. EL pole xxxxx will require a license. DP 8 will require a pair divert. they have a guide book at https://www.openreach.com/building-developers-and-projects/fibre-for-developers/guides-and-handbooks similar with electric if I collect from depot. we getting temporary site electric so will have tail ends of water pipe and pull ropes tied up for about a year we may get the new fibre installed by the time we finish the build 2 years off minimum.
Is the ‘Worksop’ a business you run? Putting this on its own phase could be good depending on what equipment you have in eg welding equipment, lifting, or compressors, for some items we are suppose to tell western power (new name is National Grid) incase we cause spikes on the network. Another useful possibility is putting a meter on the workshop phase just for your own accounting as a business expense rather than the low working from home of £250 apx we claim for the business. Working from home can be a tax minefield though shared private and business use of a Worksop can often get round this. We have 3 phase, one for our workshop, one phase for night storage heaters, immersion cylinder and kitchen and one phase for everything else it’s fairly well balanced but we moved in as it is so we didn’t design the circuits or phases. I would expect a lot of electricians down here are use to 3 phase and yours should be able to design it ok as it’s a lot more common than back in Manchester my home town. We had 3 phase in our Trafford Park premises but not in the suburbs so most domestic electricians didn’t touch it enough only the industrial electricians like ourselves.
A bit late as I think you have had enough but incase someone else reads we had this in a hotel which worked well so we are replacing our hinged screen to stop water splashes come out further down where screen finishes. https://www.qssupplies.co.uk/bathroom-furniture-shower-taps/91721.htm?srsltid=AeTuncqrptgoRmFCtDJeR69YHahjZmVtVmq56pgT-pD1uvuLw-8N90d6GBk a very neat combination of screen and curtain.
