Everything posted by Roger440
What is happening to this bit of plastering.
Roger440 replied to MikeSharp01's topic in Plastering & Rendering
Ok, but still no DPC? Im not there, but i bet that wall is wet internally.. Now its trapped under the gypsum. Drill a hole into the masonary above the skirting board. I bet what comes out isnt a nice dry dust. -
Detached garage. Warm roof, insulated walls
Roger440 replied to Russdl's topic in Garages & Workshops
You will find they are used extensively in mezzanine floors. -
Good work, but more interested in the camper. Did that come from NSR Leisure? I see you have been sensible to and not fitted it to a double cab. Curious as i just bought one too. Nowhere near as posh as yours though. On the upside i dont need to build a cover for it as there one already there behind it.
Im guessing old house, solid wall no DPC? Dont like to deliver bad news but damp proof injection is snake oil. It doesnt work and never will. Im guessing this wall was damp originally? -
Maybe you misunderstood my suggestion? You simply tick different boxes. Job done. No one is ever going to check. Find the right one, they wont even visit the house.
UK ‘built for climate that no longer exists’
Roger440 replied to SteamyTea's topic in Environmental Building Politics
My simple plan is an aircon unit in the main bedroom. Thats it. Downstairs living room, being 170 years old with 2 ft thick stone walls, tends not to be a problem anyway Cooling a whole house is not a cheap undertaking. -
Reasoning with people wedded to an ideology is indeed pointless.
That not going to be very accurate though is it. I know peopl who run their house at 15c throughut winter. I know others at 22. The difference in energy comsumption if its a poor house will be big. And then some will have log burners which they use to boost temps, which will often be run "for free". And of course, you can lie. Easily. And boost your epc. Problem ultimately is, whatever system they use is trying to get a semi accurate answer, when the inputs are a bunch of unknowables. Frankly, without an air leakage test, its all rather pointless.
Next time, use an assesor that asks you what outcome you want on the report. Problem solved!
First ive heard of it. £1 a kWh? Why isnt everone with batteries doing it?
But largely useless to me. Plus unaffordable. My wife might get one if it ever makes economic sense. Me, no. I enjoy driving. But not in an EV.
Or another car 🤪
For clarity i was talking about electricity specifically.
Id like to think the energy sector is doing well. Its like christmas day, every day! I wasnt just thinking about industry, but everybody. The more you spend on energy, the less there is to spend on everything else, and that impacts all industries.
Retro fit roof insulation - breathable vs non breathable
Roger440 replied to ab12's topic in Heat Insulation
Agree that some form of breathable insulation is better. Depends how much space you have. I fitted 50mm PIR to the slopey bit, but i only have 3 inch rafters. If they were 6 inch i may have done different. I then installed rockwool in between/over the joists. So only a small part is PIR. These were sealed up around the outside with the illbruck 330. I did quite a good job, but not as good as id have liked to do, but with the roof off, time is limited. My last house had the same, but the PIR was "loose" in most cases. I lifted some up and it was completely dry underneath. There was just plasterboard underneath to the room. No VCL/membrane etc. So yes, its a "risk", but not sure its a big one. Nail a VCL to the ceiling inside if you are worried. -
Energy independance is a (mostly) seperate debate from the cost of that energy. We still have some of the most expensive electricity in the world. That has a significant (negative) economic impact. And thats, to a significant extent, driven by the market structure of the UK. Thats what needs fixing. And if those who say renewables are cheaper, great, when can we benefit?
At last. However, this statement seems rather at odds with many of your previous ramblings. So which is it?
Its still BS. The only effective maintenance one can, once its clogged with silt, is to take it up and relay it including the base material. Which, quite obviously isnt going to happen. Even basic cleaning, almost no one is going to do Just because someone produced a pretty graph, doesnt change reality out in the real world. I just look at what really happens, not what some desk jockey, paid by those pushing a product produces. The principle of SUDS is sound, the application is mostly lip service, with products that clearly wont work long term. Proper solutions are expensive. Permeable paving is essentially "delayed" hard surfacing.
100mm perforated pipe... recommendations
Roger440 replied to JackOrion's topic in Landscaping, Decking & Patios
Im no civils engineer, but 6n backfill has fines it it, which will migrate to the bottom, ie the pea shingle and eventually block it up. Its not what i would do. Mind you, a structure like this behind my house would scare me. Though not as much as the ones ive seen not far from here that use the interlocking wood system. In his case over 4m high with the houses at the top. The timber will be rotted away inside 10 years and the whole lot will fall down. -
You can. Not much fun trying to fit them though. Id also say, not ideal as its in the wrong place. You dont want the backfill to get clogged with fines, which the socks do nothing to prevent. -
And this is another great example of tick box BS. Permeable paving is utter bollocks. For exactly the reasons you state. A few years down the line and its no better than regular block paving. Big Asda ( i think) near warwick. Whole car park done a few years ago. Now its just awash with huge puddles when it rains, and the rest just runs off onto the road, the fields, wherever it finds a route. So flooding will continue to increase. And no one, literally no one, in any useful position of authority cares. They all know its BS, anyone with 2 braincells can see its BS, but everyone is ticking the boxes and nodding it through.
You sure about the pea gravel? That gets blocked up pretty quickly. I always use 40mm stone round my drains.Which is what im led to believe is the right way. In my experience the perforated 100mm drainage products are all much of a muchness. -
The building game is awash with such things. And everyone telling you you must do X or the world will end. Dream up a product/service, get an "industry body" to say its essential, then push it hard. Like OFTEC for oil boilers. The building regs and the BS standard say what you have to do. OFTEC have, shall we say, embellished the requirements. No doubt for their own/members bottom line. But everyone just refers to OFTEC regs. But they are not the actual regs!!
Extends well beyond markets too. They appear to be wilfully blind/stupid/corrupt (delete as appropiate) to "consequences" of decisions they make. Which everyone else can see right at the start. 70 million people to choose from, and we end up with 600 odd morons/crooks. (delete as appropiate)
