Just got my EPC figures
SteamyTea replied to joe90's topic in Energy Efficient & Sustainable Design Concepts
Cheers @joe90 May use that as an example of 'thermal mass' -
Save the world, install an LPG tank.
SteamyTea replied to epsilonGreedy's topic in Environmental Building Politics
Because by looking at extremes it can be helpful to the bigger picture. Because they look at the rate of increase or decrease in numbers and it is helpful to the bigger picture. Can you answer this? -
While I think of it, do you know the U-Value of your roof, is there insulation between the upstairs ceiling the the loft floor? -
Heat loss from thermal stores (and UVCs)
SteamyTea replied to dnb's topic in Boilers & Hot Water Tanks
Bit of a different issue. But I think most BCO would spot the difference between bricks and cardboard. They also rely on the integrity of professional bodies and leave it up to the owner/builder to sue for damages. -
@epsilonGreedy You are showing just one area of the globe there, and an extreme environment as well. If you constantly go looking for the outliers then you are just reinforcing your biases. There was a study a few years back about some glaciers that had increased in length and volume. This was used as proof that climate change was not happen, in fact I think they stated that it showed cooling. It was soon pointed out that in this special case, there was more rainfall in the region. Rainfall goes up when the world is warmer. It just happened to be dumped on those 4 glaciers because of the local weather patterns. There is a reason why we use different words for weather and climate. You really need to ask yourself what you are trying to prove here. -
I have a picture for sales called 6°F. Only one person has commented on its meaning. She did not buy it. -
Part of it is legislation. We are told what we can and can't use and what quality standards to work to. -
I tend to live in my kitchen, not sat on my sofa for years now. Last year I did heat the house during the winter because I am getting weedy. Though the heating is only two storage heater with a combined maximum capacity of 22.5 kWh/day. My biggest usage is DHW, but that is because I like a bath, a deep one, every day, sometimes twice a day. -
Or about a quarter of what I pay on a m2 basis. Small houses look terrible on paper and are even worse to live in. -
Does show that designing in PV from the very beginning is worthwhile. -
Just basic physics really. Treat it as such and the rest falls into place. -
I have never had a satisfactory answer to that. Excluding the combined cylinder/header tank ones, where you tend to heat the cold store with waste heat from the main cylinder, the physics is the same. One reason given is that there are losses though the pipework, but I find that a bit dodgy as pipework should be sufficiently insulated. -
Perversely, if I used more DHW, my losses would be lower. It is a quirk of Economy 7. One thing I did several years ago was to limit my E7 window to the last 3 or 4 hours of the period. This stopped the cylinder sitting there at maximum temperature while I slept. He had a combined DHW cylinder and header tank, so rather hard to reduce losses. I just have a bog standard vented cylinder, so the losses should be about the same as an unvented one (assuming similar shape, size, insulation levels and temperature range). -
I think they test in a slightly peculiar way. They start with a cold cylinder, heat it up, run some water off, which refills the tank with cold water. While measuring the heat loss. So basically they are testing the lower thermal value of the heat loss, not the highest thermal value. So in effect they are measuring a temperature difference of about 10 to 15 °C rather than 35 °C. All a bit a cheat as it does not take into account issues like Economy 7 heating where the cylinder may be unused for 18 hours. @JSHarrisknows a bit more about the testing standard. I measured my DHW losses a while back (I measure everything I can) and regardless of which method I used, I always had very high losses, in the order of 3.5 kWh/day. My DHW usage was around 1.5 kWh/day. I added a lot of extra insulation and got it down to a more reasonable 1 to 1.5 kWh/day, but that is really still too high. -
I have a picture for sale called 6°F. Only one person has commented on its meaning. She did not buy it. -
I have now learnt a new term. Gish gallop = talking bollocks -
You can treat it like any other heat loss problem as long as you know the surface area of the cylinder, the thickness and conductivity of the insulation, the temperature of the stored water and the temperature of the room. Just a bit of arithmetic. Who initially plumbed it in to the main cold tap. Sounds like a bad installation. My Mother lives in a hard water area, she, at 90, can top up the softer with salt. -
Except they were in the Monday Club. The Monday Club was for the builders that got so drunk on the weekend they were not capable of turning up on Mondays. So they met in the pub Monday lunchtime. Or maybe that was just High Wycombe builders.
It was non global, just a local event. There wasn't one, never was. It was misinformation by climate change deniers. This was more a wet period rather than a warm period. Quite often done before the data is released, but can easily be checked up on. Rather a clutching at straws argument as we have satellite data as well as many more weather stations. It does if it has already been answered. I had a girlfriend that would keep asking the same question, but with different words, until she got the answer she wanted. The final answer to her was 'I think we should go our separate ways'. -
Except Heat is the old term for Energy. Why we use terms like kWhh and kWhe Could stick a thermometer in one, or an energy meter. I can see what you are getting at, I had a car that had a broken fuel gauge once. I found that out when I ran out of fuel. I think this is why the newer storage heaters have more sophisticated controls, they make it easier to understand what is happening. This is really historic and came about in the 1950's and 60's, a time before microprocessors. There was also an idea that the countries nuclear power stations would deliver electricity that was 'to cheap to meter'. Life don't turn out like we imagine.
I think MacKay addressed the 125 kWh/day figure in the book. It is a long time since I read it though. Seem to remember that it also includes "stuff". I think Primary energy is really the better figure when talking at a national scale. Harder to know what it is at a local scale though as we do not know all the efficiencies off the top of out heads. The difference between Primary and Delivered makes it hard to compare some things, vehicles for one.
More like 0.8%. I work on 0.25% conversion and that is before combustion losses. Plants are just terrible at converting sunlight. If plants were good, we would not be using solar panels, or burning fossil fuels for that matter. I calculated that if we burnt all biomass on the planet, and that includes the sea, we would have enough energy to last 400 days. I am in good company there as Prof Brian Cox came to a similar conclusion.
I can't, in the medium term, see much difference coming for domestic users. People struggle with dual pricing already. If that was changed to even triple pricing, say day, evening and night, the general population would just not get it. One only has to listen to You and Yours to realise how people fail to understand even basic price switching, let alone variable rates.
What could possibly go wrong
SteamyTea replied to Russell griffiths's topic in Party Wall & Property Legal Issues
Cornish Hedge, proper job https://en.wikipedia.org/wiki/Cornish_hedge Should cut out some noise bird. -
Called Economy 7 isn't it. Used to be a third of the price, now it is under half the price of the E7 Day rate. Not surprising as the idea was to mop up excess nuclear during the quiet times. Not much nuclear online these days.
