SteamyTea
    200
  1. £2000 buys about 30,000 kWh of mains gas. Which would be enough to heat my house for about 25 winters.
  2. You can get wine glasses for a quid each at Wilco. Assuming @Adsibob don't drink Coop 3 quid bottles, and a washing machine costs 600 quid fitted. Cheaper to just throw the glasses away. Or just become teetotal. Makes the journey home cheaper, not been in a taxi since I left hospital with a broken pelvis. Thankfully I had had a swig of morphine to improve the journey.
  3. Nothing lives long on a diet of distilled water. Water is commonly referred to as 'the universal solvent'.
  4. You could use baffles, instead of filters, for the incoming air. Not hard to make and can be self cleaning. Basically just a box with sticks in them to increase the path distance the air takes.
  5. Welcome Being an ex lecturer in Environmental Science and Renewable Energy, I am interested to hear about your Eco Refurbishment teaching. Sounds fun.
  6. 12 quid. https://www.amazon.co.uk/Slug-Snail-Killer-300g
  7. Laws of Physics are the same.
  8. www.ibiblio.org/ml/libri/s/SmithA_WealthNations_p.pdf Should be read by everyone to stop them spouting nonsense. We would not have voted to leave the EU if Johnson had read it.
  9. To say nothing of the plasticizers used in containers, seals and pipes. https://en.wikipedia.org/wiki/Plasticizer.
  10. While ignorance of the law is no defence, I doubt if you were sensible i.e. increased usage and not increase exports too much, no one would notice. May be a strategy to implement over say 5 years, add 750Wp each year.
  11. Any mention of minimum combustible material amounts. A small burn will cool quicker in the flue, so draw less air into the chamber, causing an even more inefficient burn (running rich in automotive terms). This may be part of the reason that it is recommended to have a short, hot burn. Quite the opposite from what people actually want, sitting around the camp fire discussing the merits of red wine over white wine, or a vegan diet over a lamb dhansak.
  12. There is 3.2 kW for 18m2. So 178 W/m² A good module a decade ago would have been about the same (285W, 1m by 1.6) For the same amount of unshaded area a roof mounted system would take up 11m2. A circle of modules would have a diameter of about 3.7m (almost as wide as my house).
  13. Not sure if it is as simple as just pipe length once adjusted for bends. The inlet air density will be pretty constant until it reaches the combustion chamber, the density is then greatly reduced, but as it exits the chamber it rapidly cools and becomes denser again. Cool it too much and it does not flow i.e. exhaust gases at same density as incoming air. There will also be an optimal inlet flow rate for maximum thermodynamic efficiency. Bends and elbows https://www.engineeringtoolbox.com/minor-loss-air-ducts-fittings-d_208.html
  14. No, but you may reduce the grid draw by whatever the PV is generating, but why would you fit a piddling, pathetic, cheap, instantaneous electric shower.
  15. If you could get a second meter fitted, could you claim both to then, and get 2 400 quid grants.
  16. Going to be more likely in some places.
  17. Fantastic, they show the built in shading. All we need to go with it is a wind turbine that has blades designed similar to a sycamore seed.
  18. Have you looked at the Passivhaus list. https://database.passivehouse.com/en/components/list/heat_pump
  19. There is so much that is unknown that no recommendation can be given at this stage. First thing to do is the heat loss calculation for the house. Then an estimate of hot water usage.
  20. Possibly, they may want to make friends with some great crested newts.
  21. Welcome I suspect that once you start one job, you will find many things that need improving/repairing. You may be better off hanging back on things and starting to look carefully at what really needs doing. 5 of the 7 sockets not working could mean a major rewire, or something as simple deliberately disconnected circuit. Choose carefully where you spend your money, getting an old Victorian house comfortable and warm is not easy, but if most of the walls are going to be plastered, that is the time to do other improvements.
  22. I have E7 on a non smart meter. EDF keep pressing me to get it changed, and I think next year the radio system that switches the supply is being turned off, so maybe they are not installing the old radio switches. I would call them up and ask.
  23. What if there is a mass of them?
  24. Or not at 85% efficiency. That is what it was capable of in ideal conditions, not one out in the wild.
  25. One meaning is Humanity. Another is a Linux distribution. It is a totally free to use OS for PCs. Odd concept being free. If only there was open source building designs that worked.
