Now there is a thought, I had not thought of. The boxed in downpipe joins the stud wall. Think it is easy to access from the loft. Excellent.
Never given it a long trial. Maybe I should. See what happens. Been using an almost non foaming PU. Seems pretty good. https://www.sealantsandtoolsdirect.co.uk/everbuild-lumberjack-pu-wood-adhesive-30-minute-310ml-box-12
Was still in the West Indies then. Had a B&W Tele, but only for 2 hours a night, 3 nights a week. Snorkeling and SCUBA diving were much better entertainment.
Was it early 70s as it does not jog any memory.
Had a bit of 5/8th marine ply to hand, nice and sturdy and allowed me to get the twist out, near enough. Leaves a gap on the other side that I may fill with 3 layers of twin walk polycarbonate sheet. Should help the U-Value. Working in getting the place a lot more airtight this year. Investigating the loft this coming week to see what I can do up there. I get a draft coming down the stud wall and out the electrical socket. So that must be making the whole walk colder than it should be. Ply and PU adhesive are my best friends at the moment. It is hard to make a house airtight when 100+ MPH winds are not unusual.
Then that works out at 27p/kWh with the SEG. A penny shy of the cap. They know how to price these installations.
Air Source Heat Pump in Stone House
SteamyTea replied to Bemak's topic in Ground Source Heat Pumps (GSHP)
And more. W/m².K. The K becomes important with older buildings, so to keep the W at a sensible level, a lower ∆K is wanted. Only real choice is thicker insulation. -
I have recycled my old, rotten red door, to a blue one. More paint in the morning, and hopefully the drip bar will turn up. Still needs a bit of threshold work, but it closes properly now. Only taken me 15 years.
That's where you are going wrong.
Alternative broadband supplier questions
SteamyTea replied to ProDave's topic in Networks, AV, Security & Automation
As you have a bit of land, have you thought of offering to rent to to a Telco. They can put a 5G mast on it. That way you get FTTP and a strong 5G signal. -
5p/kWh isn't it. That makes it 11p/kWh. Not sure if you can get MCS fitted PV for £750/kWp at the moment, but self installed is a possibility. In a new build, with a suitable roof, well worth it.
I should have added that is peak power, not peak generation. Dare I mention kW (power) and kWh (energy, or in this case generation).
Is it just the temperature, it could be the altitude and azimuth of the sun. There is also turbidity in the atmosphere. Often the reason the modules seem to perform better in the spring and autumn is not temperature, just the altitude of the sun is the same as the roof pitch at noon.
Probably not. You have to look at the raised temperature in conjunction with the extra radition that they are getting. We tend not to get exessive temperatures without excessive radiation in the UK (thare are odd exceptions where a wind blows over a mountain and, as it falls to Earth, compresses the air and heats it up). So if a module is tested a 20% converstion efficency, at 25°C anC d at 800 W/m2, and for every 1°C above that it looses 0.5%, at 35,you get 138 W/m2 of electricity. If you tested it at 35°C, but at 1000 W/m2, you get 171 W/m2 out. (not exact figures, but highlights how the 'efficiency' is measured) The other thing is that during those fairly rare high temperature events, you don't need much electricity.
Be interesting to know what the temperate differene is between PVed and unPVed roofs. Maybe a project for when you get it fitted as I am ausre there will be a bit that is not covered.
I still don't understand why we don't fit small wifi reperaters to all cars. Most of us are never far from a car. Then with some software trickery, hotspot to our phones and share a little bit of bandwidth. OK, people in remote rural areas won't get much service, but if you move to an isolated area, you will know this in advance. Bit about wifi here. https://www.bbc.co.uk/programmes/m0014pgk -
Spray can of matt black and it soon will be. I have often thought that it woud be worth fitting UFH, with aluminium spreader plates, under the roof time. Well, worth it till it leaks.
Was a podcast on the Beeb about it the other day. Hopefully @Onoff will print us one up.
Let us say that you can get PV installed at £750/kWp. A kWp will generate between 850 and 1050 kWh/year, depending on where in the country you are, and how well orientated your system is (any fool can make a PV system fail). Assuming that 50% of the PV is self use (the other 50% helps to keep others bills down), then that is, in effect, £1500/kWp. Taking a ten year life (which is very low) that is £150/kWp. Taking a median generation of 950 kWh/year, £150/ 950 kWh/year is £0.16/kWh. Or 12p cheaper than imported power.
Gift it to mine -
Seeking Imperfect small plot in Cheshire for first home modular
SteamyTea replied to jon9483's topic in Introduce Yourself
Welcome WHat do you mean by this? -
A possible future carbon tax. This would make the modules more expensive and any imported electrical energy that was generated from gas, coal and biomass.
https://www.ena-eng.org/gen-ttr/ In the past (it is a decade since I stopped workign in the industry), MCS had a list of approved modules, but inverters were 'open'. Not sure if that is stil the case now.
Sit outside and enjoy the Perseid meteor shower, maximum tonight. https://www.rmg.co.uk/stories/topics/perseid-meteor-shower-guide-uk-when-where-to-see (starting to cloud over down here, so everything East is in for thunderstorms, probably)
