SteamyTea
    200
  1. Water is the blowing agent for most PU formulations, tough if it was really cold, tat would stop it as well.
  2. Not trying to run a heat pump purely off the PV, it reduces the grid imports. Actually don't need an diverter for that as any PV generation will go to the nearest load anyway.
  3. Put a bit of randomised multipliers into it, plus or minus 5%.
  4. It becomes a statistical exercise. The idea is to run the heavy load at the times when PV generation are most likely to be high i.e. hour and a half either side of local noon, or depending on your PV orientation, whatever time you get maximum generation. Then the heavy load will probably use all the generation and import less. This is part of the reason that oversizing PV is not always the most economical thing to do.
  5. Could reduce that to an effective 2.5p/kWh
  6. Yes, mainly to ensure than it works, could be fortnightly. That way, if any problems, you get prior notice. Really only needs to be on for an hour. If you heated your DHW with the ASHP, you would use less energy. Turning everything off when not needed is a good move. I have reduced my parasite loads, some hours I draw no power at all.
  7. My Raspberry Pis I use for monitoring seem to use so little that they don't register. A Micro Contoller needs about 0.25W, or about 2 kWh a year. Still a quid.
  8. Probably, just may take a while to start up, the crankcase may need reheating. May be worth seeing if you can put it on a weekly cycle. If you have UFH, you may want to run that in the summer to distribute any/some room heat around the house. This can help lower overall temperatures. Purely out of interest, why do you not heat your DHW with it?
  9. Seems to be about normal for a controller. Would annoy me having a controller that used that much power.
  10. Welcome Have a read of this: Quite a bit in it. kWh not kwh
  11. A same one has to listen to him. And he talked about Thermal Mass.
  12. So around -0.15°C/h Pretty good for an unfinished place.
  13. There is on some of them. Winter generation ideally needs South Facing and around 15° from vertical. Was just a thought, I quite like the look of hexagon and pentagon, housing as it a little different. Would be harder to make, and if an architect was involved, crap to live in.
  14. I could, but working on a load of more interesting data ATM. The main thing is to make sure air and water does not reach the pipes. Polystyrene is a pretty good insulator, just make sure that you dig the trench large enough to separate the pipes by at least 100 mm. Make the separators of polystyrene. If you open an account with a 'bead expander' there are a few on here that will buy extras off you, seems the only way to get them is to 'be in the trade'.
  15. I know it. If the walls were angled to 15°C or so, the upper ones what face the sun (NE to NW) could be covered in PV, get good winter generation. I would feel a nob living in a place like that, but would make for a good business premises.
  16. You can treat the heat loss from a pipe as exactly the same problem as a wall. Hot side, Cold side, Surface area and Thermal Properties. Dig a trench, pour in some polystyrene beads, lay pipe, more beads, then cover with a foot of dirt. Plant grass. If water table is a problem, pour in two part expanding PU foam and cover with paving slabs, then earth and seed.
  17. Only trigonometry. Should not make a difference to the overall losses, would make a difference to the room by room though. Half dome is the best shape for a house, not sure how well a wardrobe would fit. There is a cafe in Tehidy Woods that is a hexagon (6 sided), it is not open much so don't make a special trip. I have often thought that as it is getting closer to a dome, it could make for an interesting house.
  18. Yes. This is especially true if you do not know your air infiltration rates. The form of a building also makes a difference. Using two connected, but separate, metrics may shed more light on it. Volume to Total Area and Floor Area to Exposed Area may shed light on it. Just thought that Exposed Perimeter Length may be useful. Generally small houses perform badly on a Floor Area metric.
  19. Yes. I intend to group the next analysis by delta T. Well I like statistics, much more informative.
  20. Why? Spend the money on beer or whatever other happiness-inducing activity puts a smile on your face!!! Monitoring makes me happy. This topic has made me look back at my historic data, going to take me hours to get it all filtered, but should be able to see what improvements have happened. At least you know it, and where the problems are.
  21. All our data is in that general ballpark, so probably pretty good. Yours works out as 0.35°C.h-1 If there was a temperature difference of 15°C, then I think that is reasonable. Would not be the case if the difference was 3°.
  22. The analysis side is similar to a Bayesian result i.e. if this has happen, what is the probability that another thing is true. Weather prediction uses, and is checked with Bayesian statistics. Another way is to make up some probability tables from known variables and just look up results. That can be quite effective and uses little computational power.
  23. I can see my laptop, with the phone charging off he USB port. That is it. If I look behind me, there is a radio.
  24. Why we live here.
