Interested in a Heat Pump...
SteamyTea replied to Slippin Jimmy's topic in Air Source Heat Pumps (ASHP)
The buffer/volumiser side is something that crossed my mind as well. How sensible is it to run a heat pump (or any 'boiler') very close to the minimum volume. My feeling is that it is a bit like running a car at the lowest oil, or coolant, levels. Possible, but probably not really the best thing to do if you can add a bit more easily. -
I have been pondering that as well. -
Yes, but I think a lot of that is down to the UK having oversized, but highly modulating, gas boilers. To run less controlled zones relies, more and more, on a decent room by room heat loss calculation. This becomes harder with UFH as you can only change the flow rate and flow temperature, you can't change the size of the emitter. -
Heat pump planning rules to be overhauled
SteamyTea replied to Temp's topic in Air Source Heat Pumps (ASHP)
Sadly true. It used to be so good for the sports coverage. -
Disabling Weather Comp during mid winter?
SteamyTea replied to Andeh's topic in Air Source Heat Pumps (ASHP)
As warm air rises, have you checked the air temperature up there? You may find a ceiling fan can shift enough to raise the temperature lower down. You could try it out with a desk fan first if you have one. -
Emptied his sack.
I have done every panel on my car, where I live is like Stapleford, it is the place that stolen cars get torched.
They should give then automatics/EVs.
Optimising windows for solar gain & heat loss?
SteamyTea replied to Alan Ambrose's topic in Windows & Glazing
Not really. All the 'solar houses' books I read 20 years ago when studying this area were all a bit flaky and 'it will be alright'. Geometry and physics is really all that is needed. And a spreadsheet. -
Where is it all going, downwards?
High temperature UFH is not the best, higher losses to the ground, not so nice to walk on in bare feet.
? Slow flow rate or high flow temperature.
Clean Heat Market Mechanism to incentivise heat pumps
SteamyTea replied to LnP's topic in Air Source Heat Pumps (ASHP)
Yes, you are right. Anyone else got one as it would be interesting to know how good, or bad, they are. -
Yes. The best correlation was with AT difference, rather than just OAT. Probably more true in places that have prolonged periods below 0°C. The problem with cramming in as much energy in as shorter time is that it requires a larger output heat source and room for the storage. This penalises smaller houses. For my climate, as I said in my analysis, ToU probably does not make much difference. Out of the 2152 hours I have had my heating on, only 676 hours were 4°C or less (31.4%). 325 hours and I did not need heating as it was over 9°C (my mean switch on temperature) that is 15% of the time. Of course, having storage heaters I don't have the luxury of stopping output fully, so the room temperature just rises a bit for a few hours. Most of those few hours, the excess heating is during the day, when it is most useful and does not cause excessive heating, My mean room temperature, when it is 4°C or below, it is 18.6°C, when it is 5°C and above, it is 20°C (which is my target temperature).
Welcome. What thickness Celotex did you fit and did you fit a vapour control layer (VCL) and what are you doing to heat the space?
Would Shelly relays suffice? If you initially want to keep the storage heaters (as you have them and you are doing other work), remote control relays should do the trick. You just reduce the hours they are running to limit the input/output. The only thing I would worry about is how well they deal with a power cut. Do they reconnect easily and reliably?
You can get them, our old mate @Jeremy Harris had one. Can't remember the make. Think it was only 2 kWp, which would me useful in my house, but for larger properties several may be needed. -
Shall have a look when I get time/bored. Currently looking at the temperature and energy distributions.
With UFH it is really down to how much insulation you can get under it. I suspect that radiators are going to be your best option. But still add floor insulation if you can. If you can put up with a bit of noise, and the new room/s are not constantly used, then plinth/fan assisted radiators may be an option. They take up less space.
Adding panels myself? (Inverter & cables already installed!)
SteamyTea replied to glock339's topic in Photovoltaics (PV)
Should always be the first thing to do. -
Worth reading as it has some notes and comments that explain a lot of it. -
One way to increase the efficiency of an ASHP is to increase the size of the external heat exchanger (the radiator). Our planning system puts a limit of 0.6 m3 for a permitted development unit I think though. -
That was lucky for everyone. I drive up the M5 every couple of weeks, there is a new development near Taunton, seems to be mainly detached houses. Talk about crammed in, and next to a motorway. And it seems to be on a flood plain. About 2% of the UKs land area is housing, about time we added another 1% to that. Many of the old arguments i.e. near work, transport links, schools and services are really outdated these days. Not as if householders only want to walk or travel by bicycle. My nearest town is 2.5 miles away. 40 minutes walk. Walking is not a practical solution. And the town is rubbish for shopping, but they have built a few thousand houses on the outskirts. The town has not improved, still no decent shops or restaurants.
Have you done any manual calculation that include the solar elevation and azimuth? https://www.sunearthtools.com/dp/tools/pos_sun.php
