  • entries
    24
  • comments
    282
  • views
    8361
The Build - plaster boarding and insulation
Redoctober
Yes, now that the first fix has been completed, the plaster boarding has started with the upstairs being done first. The builders will move downstairs an a weeks time or so. Whilst they have been boarding out, I have been installing the insulation for the partition walls, loft space and ceilings downstairs. The insulation being used in the loft space is 140mm - two layers laid at right angles to each other if that makes sense. The insulation used for the partitions is 100mm and the plasterboard for these walls has sound proofing properties, weighing in at 6 kilos more than the standard boards.
You will see from some photos that we have also managed to install two full length oak beams. One for the sitting room and the other for the kitchen/family room. They look great even if I say so myself. They are not structural just aesthetic.
Outside, the stone mason and labourer have been cracking on with the stone work. They intend to get the house done at head height before moving up as additional scaffolding will be required. They start the back of the house later this week.
Enjoy the photos and I will be back in a couple of weeks, hopefully with a full boarded out house.
Thanks for reading.
  • Like 6
19 Comments
Recommended Comments
Wow that stonework looks amazing! In fact it all looks amazing. You must be delighted with how it’s going, and what a great year weather wise to be building! How’s the budget?
  • Thanks 1
This does it for me tbh. Just love the solidity of the outer skin and traditional look but with the passive esque make up behind.
  • Thanks 1
Hi @newhome the budget........... so many variables can be included but if I just include everything that has got me to this position thus far, stripping out all the professional fees,  services and the cost of the land, we are currently at £1220 p.s.m. It does include such things as skip hire, toilet hire and electric meter cupboard, amongst other stuff!!!
  • Like 2
  • Thanks 1
Floor looks a bit dirty in the fourth photo, are standards dropping? Glad you making quick progress.
  • Haha 1
I may be coming in late to the blog - but I love the look of the place, especially the stonework!  I want that house!  At least I know where to come when/if eventually find my piece of land.  ? I'm just going to copy yours.....
  • Thanks 1
Tidy tidy job Ramius...what's going above/in the apex of the dormers.
What's the chance you can have a bit of art work in there...
Submarine...
Family crest...
Initials...
Year of bulid is traditional
  • Thanks 1
Submarine...
Family crest...
Initials...
The dormers have just started to be clad in wood. We had hoped to render them but it proved to be too problematic. Happy with the results nonetheless. We do have a date stone, courtesy of the stone man. and that is already in situ. Photos attached.
Quick question for you @Redoctoberon the gable behind the extension, how is the weight of the stone distributed? Does this rest on the roof truss of the extension or do you have a block wall on the gable end?
9 hours ago, DavidFrancis said:
I've wondered about that too!
Guys, sorry for the delay in getting back to you but the stone wall you are enquiring about was built on to an internal block wall. That wall was then plaster-boarded and plastered. As you will see from the attached images, the doorway into the utility room from the kitchen, the recess is quite deep. Not a problem for us but thought I would just highlight it.
I think they mean the as yet "unclad" gable to the left of the extension. Zoom in people and you can see the stones coming up where the slates stop.
  • Thanks 1
Cheers @Onoff - exactly that. The block wall was built internally and "popped" out at the roof line, in readiness for the stones. The single storey building is our utility room and the room to which it joins, is the kitchen.
2 minutes ago, ProDave said:
That's a brave man cladding those dormers from a ladder. I would want some scaffold up personally.
Handrail & toe boards optional! :)
