March 31, 20197 yr We're planning skylights in the faulted ceiling over the hallway -- 2.5 stories up. It will make great stack cooling, but that means electric (and ideally automatable) opening. Velux do one, but I've heard mixed things about it so at least want to explore a second option. Fakro can do PassiveHouse certified OR electric opening, but not both together, AFAICT. Any others I should look at, or just make Velux work? Edited April 1, 20197 yr by joth
March 31, 20197 yr Both Fakro I hope ours open electrically as that is what we ordered and Velux supply ph rooflights with electric opening. Edited March 31, 20197 yr by MikeSharp01
March 31, 20197 yr 1 hour ago, joth said: Farko can do Passiv or electric opening, but not both together AFAICT. What do you mean by "Passiv"? Do you mean PassivHaus certified? Is it on a flat or pitched roof? We have an electric opening quad (I think!) glazed Fakro rooflight on our flat roof. Not PH certified, but the numbers are fine.
April 1, 20197 yr Author Yes, by Passiv I meant PH certified, editted to clarify. This will be on a 45° roof. I was using the Fakro product selector and pricelist: the U8 seems to be the only PH certified opening windows, but they're not list on pages 18-19 with all the other electrically opening units.
April 1, 20197 yr 55 minutes ago, joth said: Yes, by Passiv I meant PH certified, editted to clarify. Cool, thanks. Next question: why do you need them to be PH certified? From memory, PH-certified windows aren't a requirement even if you're going for PH certification. It's just that you get a little more leeway in the numbers (can't remember how it works for windows, but as an example, for MVHR you need to put in a penalty factor of something like 15% if the unit isn't PH-certified). If you aren't going for certification, I'd just look at the specs and make sure you're happy with them. The PH-certified product will be more expensive than the same spec non-certified, because of the fees paid to the PH Institute for certification. If you are going for certification, then it's only one window, and using a non-certified product in this position will likely make no difference to your ability to achieve certification (assuming appropriate specs otherwise).
April 1, 20197 yr Author @jack That helps a lot. Obviously for majority of windows they should really be certified else the penalties would add up. But for the odd awkward one we can negotiate it. Very helpful input to be heading into detailed design with. Thank you. Yep the goal is certified EnerPHit.
April 2, 20197 yr 23 hours ago, jack said: PH-certified windows aren't a requirement even if you're going for PH certification. ????????? Loving it... Edited April 2, 20197 yr by Ferdinand
April 2, 20197 yr When I spoke to Peter Warm, a Passivehause certifier he said not to worry about rooflights if they are in a communal area such as a hall as they are treated differently than if in your bedroom. He didn't have any problem with the two massive triple glazed automated Velux ones that I specified on my build. The Passivehause certified ones only come in smaller sizes, I guess because of the weight. The Velux rooflight didn't cause any issue on the airtest either.
April 20, 20197 yr Our electrically opening one s is from Lamilux (around 60cms square) and is Passivhaus Certified - as is the house as a whole because the plaque arrived in the post today! We also have a big Lamilux roof-light (4m x 5m) but that is non-opening and has an external blind.
April 20, 20197 yr 2 hours ago, Eileen said: Our electrically opening one s is from Lamilux (around 60cms square) and is Passivhaus Certified - as is the house as a whole because the plaque arrived in the post today! Congratulations .
April 20, 20197 yr 22 minutes ago, Eileen said: Thanks! Take a picture of the plaque and use it as your avatar .
April 20, 20197 yr Thanks! Website is www.thewalledgardendevon.uk Edited April 20, 20197 yr by Eileen
April 21, 20197 yr @PeterW It's Cedec self-binding gravel - scarily bright gold when laid but then soon calms down to this pale look and hardens up with rain and footfall.
April 21, 20197 yr Have finally done an "introduce yourself" entry, so that's probably a better place to discuss the project than hijacking this thread! Also it's me rather than Eileen that's doing most of the writing as she's too busy doing the landscape.....
April 21, 20197 yr I must be thick or more likley computer illiterate where are all the pictures please
April 21, 20197 yr 16 minutes ago, scottishjohn said: I must be thick or more likley computer illiterate where are all the pictures please If you follow the link above (https://thewalledgardendevon.wordpress.com/ ) and then click on "photos" on the top menu it takes you to a page with a link to a lot of photos. The direct link to all the photos is: https://www.flickr.com/photos/nigpic/sets/72157688294789963 (for all the construction photos) or this: https://www.flickr.com/photos/nigpic/sets/72157704667571174 (for all the completed photos).
April 30, 20197 yr Author (Strangely didn't see any these replies until now - sorry!) On 02/04/2019 at 12:31, Alex C said: When I spoke to Peter Warm, a Passivehause certifier he said not to worry about rooflights if they are in a communal area such as a hall as they are treated differently than if in your bedroom. He didn't have any problem with the two massive triple glazed automated Velux ones that I specified on my build. The Passivehause certified ones only come in smaller sizes, I guess because of the weight. The Velux rooflight didn't cause any issue on the airtest either. Thanks! I hadn't heard about the difference for communal areas (I thought that was more about shared-use passegeways in apartment blocks, but maybe totally confused!) On 20/04/2019 at 10:58, Eileen said: Our electrically opening one s is from Lamilux (around 60cms square) and is Passivhaus Certified - as is the house as a whole because the plaque arrived in the post today! We also have a big Lamilux roof-light (4m x 5m) but that is non-opening and has an external blind. Thanks - hadn't seen Lamilux before, I'll have a look. And, congrats on the build. Looks amazing!
May 2, 20197 yr Author Anyone heard of / got experience of "Roof Maker" rooflights & skylights? Luxlite for pitched roofs Roof lights overview - inc fancy stuff like sliding lanterns and a round one Quoted U values are good, typical best cases in the 0.6 area. Remote control opening and blackout blinds as an option. Targeting the Passive House market. 20 year warranty. Made in Leicester, UK What am I missing? Edited May 2, 20197 yr by joth
