What is the difference between a distribution chamber and an inspection chamber? To be placed between the septic tank and the soak away. Distribution chambers, when googled, seem to come up very expensive.
I think the main difference is that an inspection chamber is basically a hole to look at the pipe going in and out of the chamber
a distribution chamber will have one inlet AND an umber of outlet connections --usually 4 for the soakaway perforated hoses
so its fitted where the main grey water pipe meets the soakway field
this is my understanding of it
Edited by scottishjohn
8 minutes ago, ProDave said:
Between the septic tank and soakaway is usually a sample chamber,  one pipe enters, thre is usually a small drop and another pipe exits. the idea being SEPA / EA or whoever can drop a container in and take a sample of your effluent
Here is the first one I found doing a quick search. https://www.wplinternational.com/optional-extra/wpl-sample-chamber/
how goes the 50mm pipe problem dave
24 minutes ago, Roz said:
This was what I found when looking, which just seemed expensive when compared to the inspection chambers!
https://www.drainagesuperstore.co.uk/product/underground-sampling-and-distribution-system-chamber-110mm.html
But then found this..
https://www.drainagesuperstore.co.uk/product/polylok-standard-4-hole-distribution-chamber-with-flat-cover.html
and i don't understand why the difference in price
It's the difference between a Trabant and a Rolls Royce. They both do the same thing, but the quality, and the price.
The cheap one does not look very deep to me, I am not sure it would have worked for us.  The treatment plant outlet was 700mm down and then another 100mm ore more step for the sample chamber, you will be looking at about a metre down.
I think ours is about that depth too. I might just ask the builder to sort out the distribution chamber from the merchant!
Is non-woven geotextile the right option also by the way? It's more expensive than woven so wanted to check before I committed.
  • 5 months later...
I'm now at this stage but I have a 32mm MDPE feed to the sampling chamber as we have a pumped outlet. My thinking is just drill a hole in a normal inspection chamber sidewall to locate the MDPE and provide a easy to access sample point then use normal T connectors to branch the 110mm pipe out across the distribution field.
Can anyone see an issue with this?
Use Y or 45 degree connections for your drainage field. And what you suggest is ok but angle the MDPE into the chamber at 45 degrees so it doesn’t spray up the wall when the pump runs.
If you have a pumped system, the holding tank with the pump is the sample point, or in our previous pumped system the sample point was in between the septic tank and the pumping chamber.
I have never seen a sample point installed in this location with a pumped system.
That makes sense, I need to take a look in the treatment plant and see . I still need to drop the 32mm into 110mm for the drainage field though and this could double as an inspection point if needed. That is unless a fitting that converts 32mm MDPE to 110mm exists which I doubt.
  • 4 years later...
I am designing my drainage. I have a sewage treatment plant, like this thread states needs an inspection chamber with a small drop to catch a sample of water. Looking at the warrant handbook it needs to be a drop of 150mm. I don't have much height to work with and if the building inspection definitely needs this drop I will possibly have to pump the water higher just for it to fall again over the 150mm drop. This seems a little mental as I'm sure you could find a way of extracting a sample of water easy enough from a straight flowing inspection chamber with no drop. Im going to phone the warrant department on Monday, but I was wondering if anyone has gotten away with not having this 150mm drop after the sewage treatment or septic tank?
Yes, our Graf One2Clean has a built in sampling chamber and the treatment plant wasn’t too dear so simplified the install with no extra cost.
Edited by Kelvin
That's a good point. This will lower all subsequent drain runs and the soaway or drainage field, increasing cost and risk. We need another solution.....the buildhub detail.
I'm guessing that the intention is that an inspector can take a flowing sample as it emerges.
My ground was very flat and virtually no fall, my Vortex had a built in sampling chamber which saved the day.
Did it have that 150mm drop in it though? They seem to want that and it is still a 150mm loss of height.
1 hour ago, dpmiller said:
the Solido airlifts well above the outlet, into the sampling pot, and this then overflows to the outlet
Interesting. I will have to read the bumph again because I am not understanding how it works, or why they have not used 3 chambers. It seems to be a single chamber, ie more like a cess tank than a digester, but with air bubbles.
Then the outlet is by  a pump, not gravity, the 'airlift' of the title.
There is only a 20mm drop in level from in to out.
The sampling pot does not have the 150mm suggested but is effectively pumping a sample out.
But if it works...
Ah, not sure if it was 150mm, can’t remember and the diagrams don’t show the drop. 🤷‍♂️ but it worked.
Correct. It's an SBR- Sequencing Batch Reactor. It goes through a run of aeration and settling cycles before a final settle and pump out.
15 minutes ago, joe90 said:
but it worked.
If the bco accepts it and it works, then that may conclude the process. It will probably never be tested by the authorities.
I will try reading the instruction manual again, to see if I can work out how it works, and if it is a real or imagined advantage.
That sounds complicated and the effluent would go untreated if there was any problem, whereas the 3 chamber types work to a high % of optimum without power.
