nickw Posted February 10, 2019 Posted February 10, 2019 Has anyone got any contacts for buying longer lengths of this. My lay has just gone up from 1000m to 1950m, and I'd like to lay the pipe with the least amount of joins in it. I've one quote for for pipe in 500m lengths, £996 ex vat plus 100 delivery for 2 500m. For heaving it around 500 is going to be the max length but struggling to find anyone else that will quote over the norm lengths of 150m or less. Also by using at least 1 long length I can avoid a wayleave cost which started at free and turned into I'll speak to the solicitor to get a cost. I know using the plasson joins should be ok but less joins has got to be better if possible. I will be using stopcocks for each join just so I can section off and test each part if any leak does arise. So does anyone know anywhere, I have googled and spoken to most of the suppliers that do come up and just getting "nope either 100 max or some 150m max" Awaiting the breadth of knowledge that sits on this forum. Ta Nick
Russell griffiths Posted February 10, 2019 Posted February 10, 2019 I will just add my thoughts i can see exactly why you want to. But the question have you felt a 500m roll or looked at the size of it, having just laid 260m of 32mm I can’t imagine what a 500m roll feels like, I would think 500m would be the max you would want to go and it will be a job for a couple of strong lads, not something to do with the wife on a Sunday arvo.
Onoff Posted February 10, 2019 Posted February 10, 2019 1km of that would need to be on a cable drum type trailer imo. You can hire them: https://www.rotrexwinches.co.uk/products/cable-drum-trailers/?
Miek Posted February 10, 2019 Posted February 10, 2019 I would ring the pipe manufacturer and ask them if any of their stockists hold the longer lengths.
nickw Posted February 10, 2019 Author Posted February 10, 2019 I'm struggling to actually find who the manufactures are, I worked out the 500m would weigh about 140kg so 2 of us should manage that but yup wouldn't want to go bigger unless hiring a cable drum trailer which I'm trying to avoid. I'm laying the first part with the farmer , he is laying 500 odd metres of a new line as he'd like 32mm aswell, so hopefully it'll be easier if we use his handler or anything else we need, thereafter I'll ask nicely for some help on some nice days. The Mrs read this post and yes agreed she isn't going to be doing it with on any! afternoon. If anyone can point me in the direction of the manufacturer I would be eternally grateful and will make some calls tomorrow.
PeterW Posted February 10, 2019 Posted February 10, 2019 2 minutes ago, nickw said: I'm struggling to actually find who the manufactures are, I worked out the 500m would weigh about 140kg so 2 of us should manage that but yup wouldn't want to go bigger unless hiring a cable drum trailer which I'm trying to avoid. I'm laying the first part with the farmer , he is laying 500 odd metres of a new line as he'd like 32mm aswell, so hopefully it'll be easier if we use his handler or anything else we need, thereafter I'll ask nicely for some help on some nice days. The Mrs read this post and yes agreed she isn't going to be doing it with on any! afternoon. If anyone can point me in the direction of the manufacturer I would be eternally grateful and will make some calls tomorrow. Uponor make most of the high end MDPE in the U.K. and it’s a continuous extrusion plant so you could buy 2000m if your reel was big enough. Do you know if you can have a 32mm connection as most are at best 25mm and are restricted to a 15mm water meter orifice at the stopcock end.
nickw Posted February 10, 2019 Author Posted February 10, 2019 The info I have from south west says I can have up to 32mm , looking to reduce at the house down to 25 to up the pressure after such a long run, least im hopeful this is how it'll work.
nickw Posted February 10, 2019 Author Posted February 10, 2019 Also is it worth signing up for an account with anyone to get the price down for stuff like this , got some bm accounts but their costings dont make it worth it to but all the fittings , thinking one of the plumbing or specialist places might be better if anyone has a recommendation?
PeterW Posted February 10, 2019 Posted February 10, 2019 You could try Pipestock but there prices are already pretty keen. I’ve exchanged a couple of texts with a mate who installs this sort of stuff and he said to check if you can find someone who does electro fusion welding however he said it may just be more expensive. How far down the lane is the farm supply and what do they want to run off it ..? May be worth looking at 32mm to the farm and then both of you run 25mm from there.
nickw Posted February 10, 2019 Author Posted February 10, 2019 Farm is about 1500m mark, but he actually want to up his 25 to 32 as thats what im putting in , so kinda works as we use his wayleave and half the cost of the first 500m for trenching. Tried pipestock they were no good on any other lengths
Frogeye Posted February 10, 2019 Posted February 10, 2019 Hi, I had quite a few bits from a company called Drainage365(.co.uk?). Run by a really helpful guy (Simon?). He been in the industry for a long time and recently set this company up - he might be worth a call and could probably point you in the right direction if he can't help you himself.
Jeremy Harris Posted February 10, 2019 Posted February 10, 2019 16 minutes ago, nickw said: The info I have from south west says I can have up to 32mm , looking to reduce at the house down to 25 to up the pressure after such a long run, least im hopeful this is how it'll work. Worth bearing in mind Pascal's Law...
recoveringbuilder Posted February 10, 2019 Posted February 10, 2019 Ours is done in 32mm right into the house
scottishjohn Posted February 10, 2019 Posted February 10, 2019 only way it will loose pressure is if you site is a lot higher than where it comes from -then pressure will drop . https://physics.stackexchange.com/questions/30000/static-water-pressure-vs-height
Mr Punter Posted February 11, 2019 Posted February 11, 2019 Try these guys http://www.stevevick.com/services/water/pipe-handling-equipment/ and your water authority. I have seen people really mess up GSHP loops and it can be a real wrestling match if you do not plan it properly.
nickw Posted February 11, 2019 Author Posted February 11, 2019 Interestingly or not Uponor don't manufacture the pipe now, they put me onto Wavin (supposedly a manufacturer), they don't make it now they buy it in, they put me onto Radius ...they do manufacture it but wont do longer lengths, hmmm enough time spent on the phone now to inquiries followed by technical followed by not this technical dept the other one and then followed by nope we can't do it. I'll use the quote I have, pay the premium, and shut up and use a lot of joins happy days ahead ?
Triassic Posted February 11, 2019 Posted February 11, 2019 (edited) We installed 1.25km of 100mm plastic sewage pumping main and it came in 250m lengths. As we didn’t have a decoiler we hoisted each coil up between two trees with a rope through the centre of the coil. We then used an expanding nose cone with swivel and attached it and the pipe to a dumper and slowly pulled the pipe out alonside the trench. Once the pipe was positioned in the trench, the joints were electro fusion welded using a hired machine and a generator. All trenched dug by machine, pipe laid and backfilled by a team of 6 Scout leaders in a weekend. Edited February 11, 2019 by Triassic
Mr Punter Posted February 11, 2019 Posted February 11, 2019 55 minutes ago, Triassic said: We installed 1.25km of 100mm plastic sewage pumping main and it came in 250m lengths. As we didn’t have a decoiler we hoisted each coil up between two trees with a rope through the centre of the coil. We then used an expanding nose cone with swivel and attached it and the pipe to a dumper and slowly pulled the pipe out alonside the trench. Once the pipe was positioned in the trench, the joints were electro fusion welded using a hired machine and a generator. All trenched dug by machine, pipe laid and backfilled by a team of 6 Scout leaders in a weekend. Epic job! Did it need 6 people? Could you have made do with 3 with the decoiler? We did a fairly short run (100m?) of 90mm in cold weather and it was a real fight for 2 of us.
Pete Posted February 11, 2019 Posted February 11, 2019 (edited) 23 hours ago, PeterW said: Uponor make most of the high end MDPE in the U.K. and it’s a continuous extrusion plant so you could buy 2000m if your reel was big enough. Do you know if you can have a 32mm connection as most are at best 25mm and are restricted to a 15mm water meter orifice at the stopcock end. Hi @PeterW, what do you mean restricted to 15mm at the stop cock end? I have 32mm from the main, through the water meter, i know it is 32mm as I bought the box with the 32mm built in connections and then it goes into the house and reduces to 22mm at the stop cock. Edited February 11, 2019 by Pete
