As above.
Any recommendations? I've got the general principals just wondering if its worth shelling out for some of the diamond bits or just those arrow shaped tile/glass drills.
Thanks in advance
Got a cheap arrow shaped one that has done most things (including glass) and is fine.
Take it slow and use a spray bottle with water in to keep it cool
use a tile scriber to make a point in the tile, then the drill won't slip. I've used normal drills plenty of times, start off slow till your through the glazing and no hammer action
Depends on the tile. A normal drill bit won't even mark a porcelain tile. I had to buy a 6mm diamond tip bit for mine. For ceramic an ordinary masonry bit will be fine.
The heat generated when drilling porcelain is the number one reason that they break when being drilled. A water bottle hand spray and a diamond bit is essential, particularly when the hole is within an inch or two from the edge of the tile.
Is it ceramic or porcelain, do you know?
Expand
Porcelain and I've got about 2 dozen holes to do throughout the bathroom once the tiles are eventually finished.
I'll give the cheaper arrow shaped ones recommended by Dave a quick go and see how far I get.
Our plumbers have burned through tens of diamond bits this week while drilling the porcelain tiles - even taking it slow and using water. They've switched to cheaper arrow bits and are making much better progress.
I have been using the cheap arrow headed ones from Toolstation. Bought the set and a 10mm one too. All good.
Also got a couple of grit edged hole saws which I use for copper pipe through tiles.
Expand
Theyre doing something wrong then.
I've got bits that I've lent to mates and had back and are still drilling holes. My 30mm one is at least a year old and does between 5 and 7 holes per job. That's through porcelain and ceramic.
Just use plenty of water and keep the tile cool. A damp sponge works well also.
Expand
Tell him to stop buying the cheap diamond bits. Iv been useing the same one for probably 2 years now without a problem.
The brand has worn off it now. But it was one of the thicker walled ones with wax in the Center. (6mm)
Expand
No idea why, is there a preferable drill speed? They were using plenty of water and it was taking them ages. Tiles are not fancy, own brand from our local shop (£33/sqm) but very decent quality.
Has anybody here used / does anybody use the Two Hammers technique?
Obvs no good if the tile is already on the wall.
Edited by Ferdinand
  • Like 2
Id like to see that done with a porcelain tile :/
It would go something like "whack, smash, bin".
I can't imagine all that banging wouldn't have compromised the integrity of the tile.
I wonder if that's how they did it 'in the old days' ?
A man sitting on the bog comfortably making that sort of 'rhythm' is not the kind of tradesman I want to be around.
Probably thinking of ex-girlfriends.
Edited by SteamyTea
