recoveringbuilder Posted August 15, 2018 Share Posted August 15, 2018 That’s right if you employ an erector through them you don’t pay the vat on the kit Link to comment Share on other sites More sharing options...
recoveringbuilder Posted August 15, 2018 Share Posted August 15, 2018 At the erection stage they only put up load bearing walls any other partition walls are part of the roughing Link to comment Share on other sites More sharing options...
newhome Posted August 15, 2018 Share Posted August 15, 2018 17 minutes ago, Christine Walker said: At the erection stage they only put up load bearing walls any other partition walls are part of the roughing I’ve never heard that term before. The partition walls were put up during the frame erection but the same builders were doing all of it so it didn’t matter. Link to comment Share on other sites More sharing options...
Jeremy Harris Posted August 15, 2018 Share Posted August 15, 2018 5 minutes ago, newhome said: I’ve never heard that term before. The partition walls were put up during the frame erection but the same builders were doing all of it so it didn’t matter. Me neither. Our frame erection included all internal and external walls, floor joists and first floor flooring, plus roof sarking boards, membrane and slate battens. Took 4 1/2 days start to finish. Link to comment Share on other sites More sharing options...
recoveringbuilder Posted August 17, 2018 Share Posted August 17, 2018 @Google I’ve just looked at your floor plan , wow! That’s some bungalow! Link to comment Share on other sites More sharing options...
Google Posted August 17, 2018 Author Share Posted August 17, 2018 (edited) 7 hours ago, Christine Walker said: @Google I’ve just looked at your floor plan , wow! That’s some bungalow! We were originally looking at a 1 1/2 storey but the plot is 1.6 acres, so decided to spread ghe house over 1 floor. Our plans have been approved for another 2 bedrooms and a mezz in the attic, so we’ll do those before we sell in the future. Planning on doing this again...all being well. Edited August 17, 2018 by Google 1 Link to comment Share on other sites More sharing options...
dpmiller Posted August 18, 2018 Share Posted August 18, 2018 that's a fancy house not to have MVHR... Link to comment Share on other sites More sharing options...
Google Posted August 19, 2018 Author Share Posted August 19, 2018 (edited) Okay....so now I've just found out that our architect didn't check the drawings properly and the steel that has been erected(3 sets of goalposts)is all 300mm too low!! The fabricators took the heights to the bottom flange of the beam rather than the top, and our architect didn't spot it. He thought the beams would be sitting on top of the columns rather than be bolted to the side. We only saw the problem when it was up and we measured it. The guy is a balloon....made some smart remark along the lines of "ach well, it won't cost much to fix". Our bloody kit arrives in 10 days time and I'm supposed to be able to get the beam extensions fabbed, dismantle the steel, have the new bits welded on top of the existing columns and re-erect and bolt on the beams!!...and have all that done for the kit and joiners arriving. Goodness knows how long it will even take just to get the steel I-beam extensions. Wanted to punch his lights out....he couldn't even be arsed to come to the plot..says he got waylaid. We have kit arriving, with steel at the wrong height due to his failure to check the drawing correctly, and yet something more important has his attention. And of course, the chances of anything being done at the weekend are zero. Edited August 19, 2018 by Google 2 Link to comment Share on other sites More sharing options...
recoveringbuilder Posted August 19, 2018 Share Posted August 19, 2018 Were you providing the steels yourself? Ours came as part of the kit and were erected while the joiners were on site, our builders had prepared the pads for the steels being bolted to and given the heights to claymore who worked it out with the fabricators from there, it did take a day and a half on site for them being put up while the joiners were here but at least everyone concerned could see what was happening, our architect really had no input at this stage other than checking correct materials had been used. Link to comment Share on other sites More sharing options...
ultramods Posted August 19, 2018 Share Posted August 19, 2018 If it wont cost much to fix then I am assuming he will be happy to pay for it! 1 Link to comment Share on other sites More sharing options...
Onoff Posted August 19, 2018 Share Posted August 19, 2018 Whereabouts are you? I assume the crossmember bolts to the verticals via a plated connection? Can you not just "slip in" short, 300mm extensions? Assuming SE is happy and that they're getting covered up. A local fabricator should eat that in a day if your steel people can't help. Link to comment Share on other sites More sharing options...
Russell griffiths Posted August 19, 2018 Share Posted August 19, 2018 Can you lift them vertically and install on a concrete pad stone, hidden in your insulation and floor makeup. Link to comment Share on other sites More sharing options...
newhome Posted August 19, 2018 Share Posted August 19, 2018 Have you paid the architect to oversee the construction? If so I would expect him to be dealing with this. If not then this sort of detail is down to the project manager really. Whose drawings are they? If they are not his and you haven’t paid for his ongoing services for this type of activity I’m not sure that you can necessarily lay the blame at his door. This is also why self builders tend to have all of the elements for the initial construction wrapped into the TF company’s remit so that components being provided in the wrong size become their responsibility not yours. So if for example you supply the windows yourself and they don’t fit it’s your issue not the TF company’s. Conversely if the TF company supplies them it’s their issue. The project manager still needs to oversee the construction however and ensure that the right windows are put in the right places. Link to comment Share on other sites More sharing options...
Google Posted August 19, 2018 Author Share Posted August 19, 2018 Thanks for the replies folks. The architect is supposed to be overseeing the build, although not full project management...that's our job. He is also providing our warranty and technical audits. The kit supplier also supplied the steel, however, they have supplied exactly what they were instructed to supply by the architect and structural engineer. We wanted the kit company to supply both the steel and timber as well as the windows, so it should all fit together. The kit company sent the steel drawings to the architect for approval prior to fabrication. He admitted to not checking them properly, hence the steel is now wrong. There was a height to the steel which should have been to the bottom of the beam...it was made to the top of the beam...so it's out by 300mm(the depth of the beam). Not the kit manufacturers fault...they made what they were told. 1 Link to comment Share on other sites More sharing options...
newhome Posted August 19, 2018 Share Posted August 19, 2018 2 minutes ago, Google said: Thanks for the replies folks. The architect is supposed to be overseeing the build, although not full project management...that's our job. He is also providing our warranty and technical audits. The kit supplier also supplied the steel, however, they have supplied exactly what they were instructed to supply by the architect and structural engineer. We wanted the kit company to supply both the steel and timber as well as the windows, so it should all fit together. The kit company sent the steel drawings to the architect for approval prior to fabrication. He admitted to not checking them properly, hence the steel is now wrong. There was a height to the steel which should have been to the bottom of the beam...it was made to the top of the beam...so it's out by 300mm(the depth of the beam). Not the kit manufacturers fault...they made what they were told. That really inspires you with confidence for his attention to detail as you progress through the build ... Ask him for the details of his PI insurance. That'll put the shits up him hopefully!! Link to comment Share on other sites More sharing options...
Declan52 Posted August 19, 2018 Share Posted August 19, 2018 His bill would be £X minus the cost of the remedy. Link to comment Share on other sites More sharing options...
Nickfromwales Posted August 19, 2018 Share Posted August 19, 2018 39 minutes ago, Google said: He admitted to not checking them properly, hence the steel is now wrong In writing or over the phone ? Put this firmly in his lap and tell him it's his problem. Don't phone him, send it by email and recorded signed for copy by post. Then he should sit up and take notice. What a Penis. Link to comment Share on other sites More sharing options...
Google Posted August 21, 2018 Author Share Posted August 21, 2018 (edited) Next question folks.... So I have things happening to get the steel corrected, and also should have a new team of joiners lined up shortly, however, the kit is due next week and the joiners may be a week or so (perhaps 2)behind that. So, will that cause any issue with the timber kit? I’ve had someone suggest that it could warp if it’s not stored correctly and it gets wet from lying out in poor weather. Is this true? Should I store the panels flat and cover with tarps, for example and have the trusses stood upright? Obviously, it’ll be fine once it’s bolted/nailed together but if it lies for a week or 2 first? I have to accept delivery as the manufacturer doesn’t have the facility to store for me...I’ve already managed to get it delayed till next week. All advice welcomed. Edited August 21, 2018 by Google Link to comment Share on other sites More sharing options...
Russell griffiths Posted August 21, 2018 Share Posted August 21, 2018 A slightly different thought, do you have help to unload and stack the frame, don’t underestimate the size of this task look at j Harris picture, that’s a lot of timber to move around. As for storage i would either store flat or upright, but what ever method make sure you have blocking underneath to keep out of the puddles and ensure panels are flat, no waves or kinks i was always told to store trusses upright, with blocking under the ceiling ties to prevent damage to the ends, again no kinks or waves. Why can the frame manufacturers not hold on to it for another couple of weeks. Why not drive to the company and have a chat face to face, I find this works so much better than an e mail. Link to comment Share on other sites More sharing options...
Google Posted August 21, 2018 Author Share Posted August 21, 2018 55 minutes ago, Russell griffiths said: A slightly different thought, do you have help to unload and stack the frame, don’t underestimate the size of this task look at j Harris picture, that’s a lot of timber to move around. As for storage i would either store flat or upright, but what ever method make sure you have blocking underneath to keep out of the puddles and ensure panels are flat, no waves or kinks i was always told to store trusses upright, with blocking under the ceiling ties to prevent damage to the ends, again no kinks or waves. Why can the frame manufacturers not hold on to it for another couple of weeks. Why not drive to the company and have a chat face to face, I find this works so much better than an e mail. Thanks for the advice. We have the offload sorted fortunately. I may see about laying the panels on the concrete slab...that way keeping them flat. And the blocks is a good idea to keep things out of the wet. I already have an area cleared with terram put down where I can stand the trusses upright(On blocks) Link to comment Share on other sites More sharing options...
PeterW Posted August 21, 2018 Share Posted August 21, 2018 2 minutes ago, Google said: may see about laying the panels on the concrete slab...that way keeping them flat You must make sure they are stacked on minimum 4x2 bearers at 600 centres and the TF co will tell you how high. Are they pre-insulated ..?? Lay them outer side up and make sure they are strapped down too..! Do not use pallets to stack them on ..!! Link to comment Share on other sites More sharing options...
Google Posted August 21, 2018 Author Share Posted August 21, 2018 16 minutes ago, PeterW said: You must make sure they are stacked on minimum 4x2 bearers at 600 centres and the TF co will tell you how high. Are they pre-insulated ..?? Lay them outer side up and make sure they are strapped down too..! Do not use pallets to stack them on ..!! Thank you!! Link to comment Share on other sites More sharing options...
