Hi,
Desperately need some advice. My plot is number 3 out of 4 on a development. The developer is contracted to block pave the access road into the 4 plots in block paving, which is about 100m long. 2 of the houses are complete, 1 hasn't started at all (and not sure if it's even been sold) and I'm in the process of building.
I received an email from the developer last Friday telling me they intend on constructing the access road starting the 16th. This may possibly cause me huge issues as delivery vehicles, concrete lorries and a crane could damage the block paving.
In my contract under sellers obligations is the following:
"No later than 3 months after the last house on the any adjoining land (then or formerly belonging to the seller) which is practically completed the seller shall at its own cost surface the said access road using block paving or such other materials as may be required by the local planning authority"
Now my understanding of that is within 3 months after the last house of the 4 is practically completed, the access road will be constructed and not before. I've pointed that out to the developer but he is still going ahead with the access road and told me that I will have to pay for any damage. Can that contract clause mean anything else? Am I reading it wrong??
Thanks for any advice
Vijay
The clause as worded wouldn't (as far as I can tell) preclude him from undertaking the work prior to the 'no later than' date specified.
It could be argued the clause declares a 3 month window during which the seller is obligated to finish the road.
Its certainly ambiguously worded. I would speak to a solicitor, at least for an initial free consultation and go from there. The interpretation of these things can depend on precedent. And besides even just a solicitors letter can be an effective means of raising the profile of your concerns with the counterpart.
That's how I've read it but it leaves me in some potential trouble if stones is right
39 minutes ago, Vijay said:
Hi,
Vijay
Hi Vijay
If he paves the road knowing that you have heavy traffic to run over it
It is his responsabilety to make sure the road capable of carrying heavy vehicles
Any idea what sort of solicitor I would need who would know that?
55 minutes ago, nod said:
Hi Vijay
It certainly seems stupid timing but I assume he's under pressure from the completed houses................
As its a potential contractual dispute, any family high-street solicitor would do in the first instance.
Could you:
a) ask him to just install the base and delay laying the blocks until your heavy deliveries are complete? or
b) get some road surface protection to spread the weight?
Both are long shots but it looks like the guy is doing what the contract says. A solicitor should advise. Do you think he's trying to pressure you to get you to pick up some of the liability/cost?
What happens when the 4th house is built - won't this chew up the road too? It could make this plot unsellable.
“No later than” is a fairly standard term.
It is designed to stop someone delaying doing something. You wouldn’t want the road built years after you are finished.
There is nothing at all to stop them doing it earlier.
I really don’t see it as open to any other interpretation.
Now if they were sensible they would wait until you are finished but they don’t have to.
The question I would ask is what does the contract say re responsibility for repairs of your deliveries damage the road? Sadly you could be on the hook for this.
Surely if the paving is done correctly there will be no likelyhood of damage? After all, it will see bin lorries, oil tankers, removal vehicles on a regular basis...
@Vijay contact the solicitor who did your plot purchase they will have all the papers and should have advised you about this at the time
Edited by lizzie
Hi. @Vijay
As others have said, advice from a relevant solicitor or barrister would be the way if the numbers involved justify it.
IANAL, however ...
The seller obviously has no obligation to complete the road until 3 months after the last house is completed.
Questions are
1 - whether you have a reasonable expectation that the road would continue to be suitable for purpose in letting you complete your house
2 - and if so whether the developer has forfeited any right to claim damages by his being fully aware what the road is going to be used for. if he builds it regardless then perhaps he should do it such that it cannot be damaged by construction traffic that he knows damned well will be using it. Whether this would fall under a ‘fit for purpose’ test or some aspect of Contract Law is beyond my ken.
3 - has he potentially estopped himself from claiming damages by an expectation / implied promise he may have given you that it would be possible for you to complete your house. Suspect it may not meet the test for an explicit promise.
As for where for advice. I think I would frame a general question to Planning Aid in an email, and I might even send a short email to Martin Goodall of the eponymous Planning Law blog to ask if it is something he would be able to advise on professionally, and whether it is worthwhile Pursuing.
@Vijay, One thing I think it is definitely worth doing is to write to the developer with proof of receipt informing him that by completing his road now it is possible that the construction traffic he knows you will need to drive over it has potential to cause damage, and perhaps that you will consider such damage to be his responsibility therefore. You may not use it, but it gives you a fact on the ground to refer back to just in case you get "but you never told me".
Ferdinand
Edited by Ferdinand
I think that these are the links:
http://www.rtpi.org.uk/planning-aid/about-us/what-we-offer/
http://planninglawblog.blogspot.co.uk
9 hours ago, RandAbuild said:
Could you:
A base was put down and has been there for some time while the other houses were built.
Road protection mats would cost a fortune and probably more than any possible repairs. The road is around 100m
The last 2 plots are in the same position and I've emailed the owner last night to get his opinion on it as he was trying to sell it
I would hope so but the developer is not very forthcoming with capacities of the road. I'm trying today to find out the exact makeup of the road. There won't be bin lorries but you're absolutely correct with other heavy duty vehicles. Plus it's down to how well it's done
I have been told it should be a "small estate road" which would use 80mm blocks instead of 65mm on a 225mm type 1 base and 50mm sharp sand
Sadly he's retired
Other things to consider that should be noted in your purchase documents. Who owns the access road, and who is responsible for its ongoing maintenance once built? I have a shared access to my plot and it clearly notes that it is owned equally between the 2 plots and we are each responsible for a half share of the maintenance.
My thoughts. Whilst the wording would seem to not preclude the owner from putting the access road in at any time the fact that he is selling the plots for houses to be built provides you with a reasonable expectation that the road will either be built to the standard required to allow any heavy plant traffic to pass over it if it is constructed before the houses are built, or that the builder will make good the damage on the road if it is found wanting. If the damage is a 4 way split (or whatever) I doubt that the neighbours will want to risk being liable whilst heavy building work is taking place so getting them onside may help.
A solicitor’s letter should help and if your has retired he should have passed the files onto another one.
Edited by newhome
There is nothing in the contract about road damage. It only says that all the plot owners have to maintain the road.  He has since said by email that if anyone damages the road (which he still owns) then they would be responsible for the repair
1 hour ago, Ferdinand said:
One thing I think it is definitely worth doing is to write to the developer with proof of receipt informing him that by completing his road now it is possible that the construction traffic he knows you will need to drive over it has potential to cause damage, and perhaps that you will consider such damage to be his responsibility therefore. You may not use it, but it gives you a fact on the ground just in case,
Ferdinand
Already done. I emailed it to him Sunday night and posted it signed for yesterday. He's already replied to the email though saying if I damage the road it is my responsibility to repair it
As I stated earlier
Its upto him to make sure that the paving will stand heavy traffic
Many new developments have large areas of block paving that have cranes and lorries running over for several years
I wouldn’t be to concerned You may just have the inconvenience of constantly Jet washing mud off
4 minutes ago, Vijay said:
Think I have found something that might help me, one of the planning conditions:
Yep, seems perfect for your needs!
Of course this could also mean that you are living with a temp road for years if the last plot isn’t sold or developed .....
