Good spray of WD40 on the stems of the isolator valves and when you reopen them, open full then back off 1/4 turn.
And use pipe  pliers on the big nuts ..!
2 minutes ago, PeterW said:
Good spray of WD40 on the stems of the isolator valves and when you reopen them, [...]
I'd heard of the back off a 1/4 turn , but not WD40 on the isolators valves. I've just renewed the valves because the previous lot were seized solid - because I didn't know about using WD40 :$ on them.... Hmmm.
Ya dunno whatcha dunno do ya?
1 minute ago, Nickfromwales said:
And the pump MUST lay perfectly flat or the front wet bearing will run dry and burn the pump out prematurely. The pic seems to show it slightly uphill.
There ya go! If anyone wants to know why I keep coming back to BH, here's the answer.
Thanks Nick
Ian
51 minutes ago, recoveringacademic said:
OK then boys... (sorry @lizzie, @Hecateh, @Moira Niedzwiecka and every other woman in the world O.o).....
How do you level a pump? Eh? Tell me that, now
Jack up the left hand side of the house
(Your left as you’re looking at the pump)
+1
See page 27 of the installation manual...
http://net.grundfos.com/Appl/ccmsservices/public/literature/filedata/Grundfosliterature-4609706.pdf
The shaft of the pump should be horizontal and it looks "tipped back" (possibly as much as 45 degrees) in the photo above.
Edited by Temp
And use a decent lubricating / pipe fitting compound I would, like (Jet Blue Plus) on the compression joints.
