26 minutes ago, Onoff said:
These are what I have.
2019-02-09_05-02-28
Even these in the hands of someone competent should do the job I'm sure.
As soon as the grey is dry I'll rip it out and try again taking on board all the above.
me -- i would chuck the red bits
and use the 4 pink things that are very flexible and get in corners little else will .
practise on some waste
-nail a couple of bits together to make an angle to practise on-
chamfer  them half way through  at 45 to give the gap like you got on your bog .
Had a go on a bit of MDF:
White is Forever White, grey is Mapei:
20190209_193924
20190209_193938
20190209_193950
Same tool, same nozzle. Go figure???
Doesn't help I've run out of beer...well, beer that I want to drink.
You’ve used it on a porous surface that will pull the moisture from the sealant back into the board.
FWIW I hate that forever white stuff as it’s not a true silicone and it skins too quickly. If you’ve got Mapei grey, I would get a tube of Mapei white as I never have a problem with that.
Imo the two tests on the MDF are perfect. Happy with either.
Looks like you’ve already used the grey round the shower wall. Less in your face as the white so probably more forgiving.
I know you want to diy the lot and hats off to you for humour, instruction and beer/bathroom pics but...I was so surprised that on the last day of our extension build two guys appeared as the mastic crew.
they had every brand, nozzle and colour you could imagine. They whizzed around the kitchen, toilet and outside door and window seals in a jiffy and were a joy to watch.
Obviously they had the knack and technique and every job was close on perfect. I didn’t even know there was such a specialised trade...skill you could get a business out of.
if you can, get a man in, that’s all
Looks shite close up. Going to re do.
Yep, when it’s done by real professionals they are amazing. Most people are crap at it. Definitely something that those building a new house should add to their list.
I have watched a good mastic man before and I would happily class it as a trade. But I have also seen a lot of hotel mastic which I can only assume they get specialist's in for and they may as well have covered a hamster in said colour and let it loose.
Onoff will get this close enough. I have faith
  • Haha 1
I'm thinking of publishing the definitive  work on tiling using only this thread and its photographs. Due to be released on on an unsuspecting public by the well-known publishing house  Floggit and Runn
Should sell well.
Should sell well.
If that's not against our T&C's it should be....... Unless ofcourse you offered royalties
to me --still looks like the knozzle are cut too big  and maybe even more angle --keep praticing.
but much much better
Edited by scottishjohn
Nozzle cut dead square and at just less than the width of the face of the bead.  Very little waste when I tooled those samples.
To get a nice half round or oblong shape bead  for sealing door skins  we cut that shape out of one side of knozzle .
other side was cut  square  and drag it so the shaped side was at back ,so you get this shaped bead left behind
play about with knozzle size and cut angles.
 you don,t need to get that tricky
50 minutes ago, scottishjohn said:
as you are an expert at this i will say no more on the subject
I never said I was an expert. I appreciate all your advice but you're pretty back and white at times!
You can't say cut square doesn't work when I've tried it and put up the photos of the results that imo are perfect. If you want to "argue" in the face of absolute proof I'm at a loss.
I will likely try cutting at an angle too as I'm unable to get the gun in now under the wc.
I agree the fugee shape things are a joy and give great finish . Also I think less is more with mastic . When I use the structural silicone it cures in 10 minutes so I really have to move . With mastic etc. you do have time .
1 hour ago, Onoff said:
I think this proves cutting square works:
and this is not black +white? --
the only thing i see there is the beads are at least twice as wide as they need to be
to do the same job  and use twice as much product
,will take longer to cure right through cos of the thickness
the idea is to make the sealing as invisible as possible   is it not ?
what ever !!
what ever !!
Apologies if I missed the bit about them being twice as wide as they need to be previously. I'll now aim for a thinner bead from the off.
Cramer Fugi kit ordered (via a student Amazon Prime account :) ) Thanks @PeterStarck.
Some idiot forgot to position the bath prior to filling it up with water do had to drain & refill!
JPEG_20190210_161433
All grouted now. Wouldn't have believed the amount the deck "sank" with water in the bath. Must have been a good mm.
Another top tip from @Nickfromwales!
20190210_170955
Pipes for the towel rad grouted in too.
2019-02-10_05-41-42
Edited by Onoff
  • Like 3
