1 hour ago, newhome said:
How can you have a dry shower? ??
Anyhoo the leaking won’t be noticeable until the day it all collapses ?
Not even in jest please! If I get a leak through these corner pockets I'll be filling up the stud walls behind :(
It's why I'm so worried about these trims. Still not clear which way to go now. Applying CT1 from the rear (somehow) seems half sensible as it should ooze through any gaps at the front.
Edited by Onoff
You must be able to squirt some CT1 and force in with a sponge surely? Or failing that fill a medicine syringe with some and squirt that in from the back.
Why on earth will it leak any more than anyone else's shower? People tile showers and wet rooms all the time and never have any issues. I think you're being half empty here @Onoff ;)
I need to feel I've done everything I possibly can and I'm not there yet! Will probably knock up a bit of brake line in a U shape to slip over a standard mastic nozzle.
Custom CT1 injection nozzle for "getting round the back":
20181008_163655
Pissy little rips to be done above the window:
20181008_170025
Edited by Onoff
20181008_163655
20181008_170025
That’s a sex toy !!    ?
It's yours when I've finished with it! :)
1 minute ago, pocster said:
Too small for me . I’m XXXL ....
If you were an engine you'd be over bored!
17 minutes ago, pocster said:
No dream !
shall I post the photo ?? ?
Nah, you're fine - I'll leave you boys to compare notes ;)
A lapse in concentration brought on by the thought of @pocster pm'ing offensive JPEGs meant I dropped the L shaped tile bottom right of the reveal:
20181008_211755
What you can't see is that this is post breakage! Thanks to a clean break & the power of mitre bond the repair is nigh on invisible.  Excess glue taken off with a new Stanley blade. Fingers pointing at the two breaks:
20181008_211826
Yes, I could cut a new tile but considering the other various faux pas will I get away with it?
Edited by Onoff
Cut a new one! I can see the cracks from the tiny photo on my phone and you will see them every day and wish you had done it again!
15 hours ago, CC45 said:
You know it makes sense.
No , no , no . @Onoff is doing this all wrong ! . Put a crack in every tile then it will look right !
What "pen" to mark tiles before wet cutting? Using a Sharpie (genuine) the water stream on the tile cutter is just washing it off?
Pencil.
sill got pencil marks on my tiles from 3 years ago.
