Pocster Posted Monday at 16:23 Posted Monday at 16:23 I posted about this property a while ago. It has got worse. So really need recommendations. Not keen to google, click 'n' hope. I see lots of "resin" fixes this viable? ta
Redbeard Posted Monday at 17:59 Posted Monday at 17:59 Assuming this refers to a past thread could we see a link please? 1
Pocster Posted Tuesday at 12:03 Author Posted Tuesday at 12:03 (edited) Edited Tuesday at 12:03 by Pocster
Pocster Posted Tuesday at 12:06 Author Posted Tuesday at 12:06 TBH even with recent photo's it looks pretty much the same. I notice on the landing ceiling some obvious damp so maybe render cracked on roof? The main cracks are on a shared wall with neighbour i.e. terraced house. So even with resin how do they fix that? Going to have to get insurance involved for 1K excess ... What I dont want really is subsidence fixed 1k poorer and then I still need a roofer/plasterer and decorator!
Pocster Posted Tuesday at 12:14 Author Posted Tuesday at 12:14 of note (maybe) there is a drain running under the property (front to back) but thats on the opposite wall
markc Posted Tuesday at 13:26 Posted Tuesday at 13:26 That is more than a resin fix .. crack appears wider at the top than bottom so too is falling away - probably being pulled by next door property. Have they had any major works done? Cellar dug out to make it deeper etc.?
Big Jimbo Posted Tuesday at 13:28 Posted Tuesday at 13:28 It's buggered buddy. One of your rentals ? I don't know if there is still a stigma around houses that have had subsidence. Patch it up and flog it ?
-rick- Posted Tuesday at 13:28 Posted Tuesday at 13:28 Feels like it's time for a professional? Find an SE to give an opinion? 1
Pocster Posted Tuesday at 13:30 Author Posted Tuesday at 13:30 3 minutes ago, markc said: That is more than a resin fix .. crack appears wider at the top than bottom so too is falling away - probably being pulled by next door property. Have they had any major works done? Cellar dug out to make it deeper etc.? Nope they've had zero work
Pocster Posted Tuesday at 13:32 Author Posted Tuesday at 13:32 (edited) 4 minutes ago, -rick- said: Feels like it's time for a professional? Find an SE to give an opinion? Yeah I was thinking that. But wont an SE just say "yes subsidence" , cctv down drain to eliminate that as potential cause i.e. collapsed; and then tell me to get a professional subsidence company in? The most likely reason is ground shrinkage - as the entire area is mainly on clay. But how do you "get under" a shared wall that isn't directly accesible ? Edited Tuesday at 13:33 by Pocster
markc Posted Tuesday at 13:43 Posted Tuesday at 13:43 @Pocster if on clay it could be subsidence or heave ( your part is lifting when the other side stays put, is your floor and window cill still level? If yes then it’s the side that is subsiding and as you point out, access is the problem for under pinning or jacking. I would put some movement monitors across the cracks (can be as simple as a couple of pieces of tape with marks to see the movement). If movement has stopped then you can look at stitching.
Pocster Posted Tuesday at 13:54 Author Posted Tuesday at 13:54 8 minutes ago, markc said: @Pocster if on clay it could be subsidence or heave ( your part is lifting when the other side stays put, is your floor and window cill still level? If yes then it’s the side that is subsiding and as you point out, access is the problem for under pinning or jacking. I would put some movement monitors across the cracks (can be as simple as a couple of pieces of tape with marks to see the movement). If movement has stopped then you can look at stitching. Thanks. Floor window cills all fine. So how do they access that party wall?. Neighbour isn't helpful as presumably they want me to sort and pay the excess whilst potentially benefitting. Lets assume the movement has stopped ; how can we be certain there wont be more?. I have monitored it for a year now doesn't appear worse. So what would/should a contractor do?
Pocster Posted Tuesday at 14:00 Author Posted Tuesday at 14:00 I'm going to push the insurer to supply a loss adjuster/subsidence specialist - I hope they see it's in their interest to establish cause and remedial work rather than me "try" 1
ToughButterCup Posted Tuesday at 15:25 Posted Tuesday at 15:25 Well @Pocster , hair won't grow round this one.... A quick look for a cracked foul drain scouring out the pipe trench ? Cheap, quick, easy. 1
Pocster Posted Tuesday at 16:32 Author Posted Tuesday at 16:32 1 hour ago, ToughButterCup said: Well @Pocster , hair won't grow round this one.... A quick look for a cracked foul drain scouring out the pipe trench ? Cheap, quick, easy. yeah but as I said drains on the opposite side of the plot . Managed to get hold of the neighbor (another LL) and his tenants have reported cracks in the same place their side - so I'm on insurers back now.
Mr Punter Posted Wednesday at 17:40 Posted Wednesday at 17:40 If this is a rental you could just fill the cracks and redecorate. If the roof is letting in water you will need to get it sorted. My mum has a rental in Swindon with subsidence cracks. Five years on and not much progress with the insurers.
Pocster Posted Wednesday at 17:49 Author Posted Wednesday at 17:49 8 minutes ago, Mr Punter said: If this is a rental you could just fill the cracks and redecorate. If the roof is letting in water you will need to get it sorted. My mum has a rental in Swindon with subsidence cracks. Five years on and not much progress with the insurers. Yeah it’s a rental . How can an insurer take 5 yrs with no result ? . Don’t worry ; I’m good at motivating companies by annoying them - it’s my special skill .
Mr Punter Posted Wednesday at 17:54 Posted Wednesday at 17:54 3 minutes ago, Pocster said: How can an insurer take 5 yrs with no result ? I think the cause was linked to a tree in a neighbours garden. Neighbour not cooperative. 1
Russell griffiths Posted Wednesday at 18:56 Posted Wednesday at 18:56 What do you want to know, shrinkable soil, shallow foundations, two of the driest summers on record. there is going to be some serious insurance claims in the next few years. 1
Pocster Posted yesterday at 11:02 Author Posted yesterday at 11:02 16 hours ago, Russell griffiths said: What do you want to know, shrinkable soil, shallow foundations, two of the driest summers on record. there is going to be some serious insurance claims in the next few years. Insurers starting to listen now - so I think they will send a loss adjuster out which is what I want . 2
Gus Potter Posted 23 hours ago Posted 23 hours ago On 21/09/2026 at 17:23, Pocster said: I posted about this property a while ago. It has got worse. So really need recommendations. Not keen to google, click 'n' hope. But you have just posted one photo! You should know if you want folk to invest their time to help you then you need full inside, outside photos along with a good location of the property. Is it in Fife Scotland on highly mobile soils for example. Is it sitting over a tube line in London, is there vibration from a nearby road etc. Come on, you should know better than to just post so limited info. You have been on BH long enough to know better. 2
saveasteading Posted 19 hours ago Posted 19 hours ago 3 hours ago, Gus Potter said: long enough to know better. Agreed. I thought "this is my thing , I can help", but it's too scatty. Start again please, pics in and out, and the available info on topography and ground make-up. On 22/09/2026 at 14:32, Pocster said: But won't an SE just say "yes subsidence" , No. A local SE will know the ground and the issues. Sometimes stitching or underpinning are the worst action you could take.... the SE will know.
Nickfromwales Posted 6 hours ago Posted 6 hours ago On 24/09/2026 at 12:02, Pocster said: Insurers starting to listen now - so I think they will send a loss adjuster out which is what I want . Battling a car insurance company atm. Loads of annoyance and slow response's / dodging answering driect questions etc etc. Keep on at them or you drop to the bottom of the heap.
ToughButterCup Posted 6 hours ago Posted 6 hours ago 13 hours ago, saveasteading said: ... No. A local SE will know the ground and the issues. Sometimes stitching or underpinning are the worst action you could take.... the SE will know. Now that is interesting. Worst action because.....?
Russell griffiths Posted 5 hours ago Posted 5 hours ago 18 minutes ago, ToughButterCup said: Now that is interesting. Worst action because.....? These older houses can be built with lime mortar and a bit of movement is expected, stitch something together ridgid and you move the cracks to another part of the property. im no structural engineer but have been removing trees from properties for the last 40 years when the finger gets pointed at the tree, I’ve been on sites where you could shake hands with the neighbours through the cracks in the walls 😂😂
