Quick recap:
  • 300m from sea (south coast)
  • Garage faces the sea
I want to use my garage as a workshop but, having just cleaned mould off a bunch of pine timber (stacked with spacers in between), and selected more MDF to take to the tip as it's mouldy, it's not in a fit state yet.
Normally I'd think "ventilation" but:
  • even with brush strips added the up-and-over garage door is nowhere near draughtproof
  • there's a 12"x12" air brick next to the door
So then I thought "damp":
  • no damp is coming up through the floor - I've done the paper-on-floor check
    • I also painted the floor with single pack garage paint when we moved in
  • but I do wonder if driving rain / general mist and damp air gets in via the air brick and around the garage door
And if damp, salt-laden air gets in and leaves the salt behind, that keeps everything a bit moist.
The metal garage door means big temperature swings inside on sunny days, as it heats up.
My thinking is that replacing the garage door, with a wall and door or anything more airtight, would improve things.
But before I do anything, what's BuildHub's diagnosis? Am I chasing the wrong problem?
I have just started to clear out my shed so that I can replace it.
Just about everything in it has mould or rust.
Timber going mouldy is a tricky one, some just attracts it, other timbers don't.
Ventilation and keeping the RH low is the only answer. The easy way to do that is with heating and a small wall fan.
You could try a tray of water softener salt, that absorbs what when the RH is above 50%
I suspect it's the sea air?
I am 3 miles from the sea and garage door faces north.  My integral garage is never damp, my tools don't rust, bits of wood stored in the garage remain mould free. My classic car in there stays dry and fresh.
The garage is well insulated, the wall make up is pretty much the same as the house, but I did not bother with an air tight membrane.  2G version of the same windows we have in the house (3g).  A reasonable but not expensive pedestrian door and an "insulated" roller door.
One difference is my garage was under the size that mandated air bricks for ventilation, so I have none. The only ventilation is the trickle vents in the windows and the leaks around the roller door, and the letter box in the pedestrian door.
It's most likely dampness through the floor but you've checked that....so driving through some weakness.. under the door, through the wall.
The simplest answer is much more ventilation.
But first walk all round it and go into it during heavy rain.  You'll often find a drip or dribble.
I don't think you need more ventilation. You mentioned that you have large temperature variations. The items in your garage are heating up and cooling down. Because of their thermal mass, if the garage is drafty, that process will lag the temperature of the air coming into your garage. The relative humidity of the air coming in, will go up and down with its temperature. After a cold night when the contents of the garage have had time to cool down, as the day warms, warm moist air getting into your garage will come into contact with items which are still colder than the air, and water will condense out on them.
Reduce the temperature fluctuations by insulation and perhaps some background heat. Slow down the rate at which the garage air is replaced by trying to get your garage door less leaky. You don't need much ventilation in a garage; trickle vents etc are there because we introduce moisture into our houses by living in them.
Correction, I should have said, actual humidity (g/m3 ) will go up and down, not relative humidity (%)
Insulate, that helps mitigate temp swings, which helps stop water condensing on thing in your garage.
That will never help the situation
Get an insulated one, or just add 25mm PIR to your existing door.
If you are considering background heat, think differently. You can get the same heat output from a dehumidifier of the same wattage and then you effectively get dehumidification for free. (They aren't designed as heaters but the electricity used ends up as heat). Dehumidifier will have a fan to keep the air circulating inside the room and will reduce the need for active ventilation to the outside (less air changes reduces the amount of work it will have to do).
It's not an air sealed space so the dehumidifier will likely work hard which is a consideration and they are more expensive than a small bar heater but I'd guess they are going to be much more effective even if not perfect.
As above. Make sure its as airtight as possible, and get a dessicant dehumidifier. Problem solved, though with some running costs.
Insulating will help a lot, but thats not going to be so easy.
You absolutely do not want more ventilation. If its 95% RH outside, it will be 95% inside. If its ventilated you cannot possibly get any other outcome.
Steel wont rust below 65%, and nor will mould grow on wood at that either.
I keep my workshop at 50%. Nothing degrades in any way. It does, however form part of my largest expense, electricity. But its a big workshop.
