jimseng Posted August 27 Posted August 27 I have had 3 quotes for my ASHP install on my new build. The cheapest was 10K for a 5k system but they have just come back with a re quote and it is now 12.7k, which is pretty much what the others came to. So I have got a bit fed up and decided to look at a DIY install. My plumber suggested he would do it last year and said I could get MCS sign off and claim the BUS grant and at the time I thought it was a lot of hassle for little gain. Since then I have established that the ASHP installation market is full of contradictions so I thought I should look at this again now I have more knowledge. I am building an efficient 3 bed house with MVHR, UFH on both floors with very high insulation. Total heat loss circa 3.3kw. The latest heat loss survey showed the heat output of the floors to be between 150 - 200% of requirement at a flow temp of 35 degrees. So I have always planned to run the system completely open loop. Total UFH volume on both floors is 105 litres so I have been advised I don't need a volumiser, which is a good thing as space is tight in the plant room. Now the thing is I have been quoted for a Samsung Gen 7 5kw unit and a Grant 4kw unit. I am planning on a 250l UVC. The thing is there are so many choices and brands so I thought I would ask you good people for some pointers as I don't know whether there is a huge difference between brands. Whether I should look at a kit etc. I am not actually going to do this myself, my plumber will but I am probably going to spec much of it myself. I am based in Somerset. Thoughts?
ProDave Posted August 27 Posted August 27 I recon from experience 2 days of electricians time and 2 days of plumbers time to install one on a new build. And I am in the camp that does the sums on that plus materials cost and wonder just how most of the companies that quote get figures as high as they do. If you are going for self install, then look at the other option, some companies will supply the kit for £0 using the grant for you to install. MCS sign off for a heat pump is not mandatory, in fact I struggle to see what that expensive bit of paper will actually do for you.
saveasteading Posted August 27 Posted August 27 28 minutes ago, jimseng said: going to spec much of it myself Your plumber may be limited in choices if they use a single merchant, as many do. Best discuss with plumber ASAP. Try talking to Trade Underfloor Supplies or similar. They supply the whole kit and I'm sure many plumbers get it done this way. But check you get the grant benefit.
JohnMo Posted August 27 Posted August 27 Timings as @ProDave says is pretty real. If your using a ToU tariff, I do and have the following 4kW heat pump - Hiaer monobloc. Then a use a direct UVC, so is charged via immersion (have plenty of solar also). Heat pump is then not trying to do heating and DHW in a cheap period, they are independent of each other. Going that route Heat pump under £2k when you claim the vat back. Cylinder £600 incl vat. Drive via simple time switch. £20. Plumbing very simple. You have loads of water volume. 2
LaChab Posted August 27 Posted August 27 It's probably not very relevant to you, but I've just self installed a 5kw Samsung Gen 7 with a 300l Oso using the "umbrella" scheme for an overall "profit" of about £1000. Free heat pump! If you do the course you can get a 7 year warranty for it. Our build sounds rather different to yours, but as we're in North Somerset you're welcome to visit for a look.
Square Feet Posted August 27 Posted August 27 Glyn Hudson on YouTube has some really good videos on DIY ASHP installs. Very technical and not flashy or clickbaitey. https://www.youtube.com/@GlynHudson 1
jimseng Posted August 27 Author Posted August 27 3 hours ago, ProDave said: I recon from experience 2 days of electricians time and 2 days of plumbers time to install one on a new build. And I am in the camp that does the sums on that plus materials cost and wonder just how most of the companies that quote get figures as high as they do. If you are going for self install, then look at the other option, some companies will supply the kit for £0 using the grant for you to install. MCS sign off for a heat pump is not mandatory, in fact I struggle to see what that expensive bit of paper will actually do for you. I didn't fully understand this. Are you saying I can get the kit using the grant and don't need MCS sign off? I agree that MCS is a waste of time but don't the BUS grant people need it for the voucher?
jimseng Posted August 27 Author Posted August 27 @LaChab What is the umbrella scheme? Can you expand on that a bit?
scottishjohn Posted August 27 Posted August 27 grant on a new build news to me ? iwas told no way as its new build in scotland
LaChab Posted August 27 Posted August 27 You pay the MCS umbrella scheme guy a fee up front to deal with the admin of getting the grant, then you get the work done either by yourself or using a plumber. The final commisioning is then done by the MCS guy. We only got one formal quote, which was a pretty excessive £16700 before grant, so I'm really pleased to have done it and made a small "profit".
jimseng Posted August 27 Author Posted August 27 @scottishjohn Yes. New builds are fully entitled to the BUS grant. I had very little problem getting my voucher, it has since expired though so I am going to have to applyagain. @LaChab That is similar to what my plumber told me today. I think he gets someone to design and supply a system and we install it, they sign it off and I get my BUS money.
JohnMo Posted August 27 Posted August 27 35 minutes ago, jimseng said: Yes. New builds are fully entitled to the BUS grant But the scheme is different in Scotland - heat pump mandatory on a new build so no grants for us.
Alan Ambrose Posted August 27 Posted August 27 @LaChab would you mind expanding a bit as that’s all v interesting. What is an umbrella guy? Who did you use for instance? Was it hard to find an ‘MCS guy’ who was happy to do just commissioning? Did they do the final plumbing and electrical stuff or just switch it on, test & verify?
Mr Blobby Posted August 27 Posted August 27 Our 5 KW panasonic was done between plumber and spark with no zones or buffer tank. Heat pump cost less than 3k. Plumber and spark think I need to have it commissioned but I fail to see why. Panasonic monoblocs are so breathtakingly cheap and simple to install and operate that I wonder how snake oil saleseman still get away with 12k installs. Get a larger UVC, maybe 300 litre. The panasonic UVC is cheaper than most and A rated. Just don't let your plumber screw into it 🤦♀️
LaChab Posted August 27 Posted August 27 @Alan Ambrose I used this company. https://www.air2heat.co.uk/mcs-umbrella-scheme. As you can see, they're based in Oswestry but they were happy to travel down to North Somerset for me. They did a first visit to chat about the design, then a second one to "commision" the system. I had a few queries on the way (should have taken notes!) which we handled by 'phone and email. As I did all the work myself I'd already got everything running by the final visit, so there wasn't much for him to do. I was a bit concerned about not having the fan coil connected when testing, but just having a volumiser was acceptable. I would have considered choosing a Panasonic rather than the Samsung, but they have an indoor "hydro" unit which I wanted to avoid if possible. And the Samsung's widely available at very good price!
Square Feet Posted August 30 Posted August 30 On 27/08/2026 at 14:27, scottishjohn said: grant on a new build news to me ? iwas told no way as its new build in scotland I understood that there's no grants any more in Scotland. I think they were removed either early this year or late last year, but I got that from a YouTuber so it might not be reliable info!
Nickfromwales Posted August 31 Posted August 31 On 27/08/2026 at 20:40, Mr Blobby said: Our 5 KW panasonic was done between plumber and spark with no zones or buffer tank. Heat pump cost less than 3k. Plumber and spark think I need to have it commissioned but I fail to see why. Panasonic monoblocs are so breathtakingly cheap and simple to install and operate that I wonder how snake oil saleseman still get away with 12k installs. Get a larger UVC, maybe 300 litre. The panasonic UVC is cheaper than most and A rated. Just don't let your plumber screw into it 🤦♀️ For warranty, perhaps. Get the wifi dongle and Panasonic can dial into it remotely and commission it, with some basic info from you. Iirc you’d need the plumber to register for a trade account (just an online registration) on the app to facilitate this.
SimonD Posted September 1 Posted September 1 On 27/08/2026 at 13:02, jimseng said: didn't fully understand this. Are you saying I can get the kit using the grant and don't need MCS sign off? I agree that MCS is a waste of time but don't the BUS grant people need it for the voucher? If you want the BUS Grant, then you have to have MCS sign off. On 27/08/2026 at 09:17, jimseng said: I have had 3 quotes for my ASHP install on my new build. The cheapest was 10K for a 5k system but they have just come back with a re quote and it is now 12.7k, which is pretty much what the others came to. So I have got a bit fed up and decided to look at a DIY install. My plumber suggested he would do it last year and said I could get MCS sign off and claim the BUS grant and at the time I thought it was a lot of hassle for little gain. Since then I have established that the ASHP installation market is full of contradictions so I thought I should look at this again now I have more knowledge. I am building an efficient 3 bed house with MVHR, UFH on both floors with very high insulation. Total heat loss circa 3.3kw. The latest heat loss survey showed the heat output of the floors to be between 150 - 200% of requirement at a flow temp of 35 degrees. So I have always planned to run the system completely open loop. Total UFH volume on both floors is 105 litres so I have been advised I don't need a volumiser, which is a good thing as space is tight in the plant room. Now the thing is I have been quoted for a Samsung Gen 7 5kw unit and a Grant 4kw unit. I am planning on a 250l UVC. The thing is there are so many choices and brands so I thought I would ask you good people for some pointers as I don't know whether there is a huge difference between brands. Whether I should look at a kit etc. I am not actually going to do this myself, my plumber will but I am probably going to spec much of it myself. I am based in Somerset. Thoughts? The important thing to understand is if the 'designers' have actually calculated in the MVHR into the heat loss. Most don't as they either don't have the understanding or the tool they use doesn't use a method that deals with whole house MVHR. For example, the new 2026 CIBSE Domestic Heating Design Guide method specifically excludes whole house MVHR. So check this before making a decision on the heat pump. You can use my tool at https://openheatloss.com as this does cover the BS EN 1281 standard for whole house mvhr. 105l may be okay, but it's important to know the minimum modulation of the heat pump first. Low temp running loves lots of volume. On 31/08/2026 at 08:17, Nickfromwales said: For warranty, perhaps. Get the wifi dongle and Panasonic can dial into it remotely and commission it, with some basic info from you. Iirc you’d need the plumber to register for a trade account (just an online registration) on the app to facilitate this. The Panasonic wifi connection is required for the 7 year warranty on these pumps. But commissioning cannot be completed merely using remote access as proper commissioning involves a lot more than this and has to involve an onsite visit. Unfortunately proper system commissioning is often misunderstood and undervalued. To get it done right it takes time. On 27/08/2026 at 22:55, LaChab said: but they have an indoor "hydro" unit which I wanted to avoid if possible. This design has other advantages often overlooked. It has built in expansion vessel good for a system of 200l volume. It also has a backup heater available in 3 or 6kW size so if there's ever a breakdown you have backup heating for your house. Overall, using the bi-bloc unit can be neater and more space efficient than installing another monobloc with all the additional expansion vessels and controller wiring as this is also all contained within the bi-bloc unit, especially if the alternative heat pump also requires an external circulator. E.g. installing a Grant heat pump is a pia in comparison and that's an easy heat pump to install.
Dave Jones Posted September 7 Posted September 7 issue will be if and when you sell, you will need an MCS cert.
JohnMo Posted September 7 Posted September 7 3 hours ago, Dave Jones said: issue will be if and when you sell, you will need an MCS cert. Can I ask why?
Bramco Posted September 7 Posted September 7 3 hours ago, Dave Jones said: issue will be if and when you sell, you will need an MCS cert. Also not sure why... But if it's anything like a lot of other things when you are selling a property, your solicitor should be able to get indemnity insurance to cover this - which is pretty cheap.
Dillsue Posted September 8 Posted September 8 20 hours ago, Dave Jones said: issue will be if and when you sell, you will need an MCS cert. Pretty sure that's not the case....desirable maybe but far from essential. I sold my late parents house a few years ago and the buyer(likely buyers solicitor) asked for gas cert, elec cert, this cert,that cert and all manner of things. I just said none were available and the sale went through.
