flanagaj Posted August 27 Posted August 27 I appreciate that this might sound lift a daft question, but how do people go about communicating with trades to ensure the task is completed satisfactory and to LABC warranty standards, without sounding like you are insulting their intelligence or micromanaging? As you know, we have had two brickies and both were shit. They cut corners and didn't take pride in their work. For instance, the last guy had never laid Marmox blocks. His response like many (incorrect of course) was to say "that's what the insulation upstand is for". Needles to say, they were fitted with large air gaps at the joints ... It's difficult managing these people yourself, as they see you as someone not in the trade and therefore assume you know nothing and that their 20 years in the business makes them an expert. Our new bricklayers start Tuesday and I want it to work. I should not have to go out and see that the 3 courses of brickwork on the internals has been simply butted up to the 3 course that run perpendicular without either being bonded or tied in .. Any pointers welcomed on the best approach. I can completely see how a Clerk of Works is helpful here.
ToughButterCup Posted August 27 Posted August 27 1 hour ago, flanagaj said: I appreciate that this might sound lift a daft question, but how do people go about communicating with trades to ensure the task is completed satisfactory and to LABC warranty standards, without sounding like you are insulting their intelligence or micromanaging? ... Your question is fundamental. It goes to the heart of the horror that self-building can become. And is the main cause of self-build-sleep-deprivation-syndrome Humility, respect, time, trust, effort, plain speaking. And knowledge of their (the trade's) networks Self builders are - to the trades we deal with - mostly one off customers. And because we self builders have to invest so much more time , emotion and 'fizz' into our builds than those who 'simply' sign a cheque, many self builders ( not all) think we're special. To trades people, we aren't. We're one of many jobs they have on the go at any one time. Either invest in someone who can manage the situation for you or take the time to understand the trades networks so you can break through their communication blocks and accept that substandard work does occur and that some work will have to be remedied but most of all - be lucky DIY know when an error is something you just have to accept - and when not. After more than 10 years at it, I'm only just getting to know like and trust a core of people who communicate well, do what they say they will do, when they say they will do it to an acceptable standard. 10 years to many people is just too long. 4
SteamyTea Posted August 27 Posted August 27 When I was forced to teach the younger students I found that giving them loads of small, achievable tasks kept them busy and improved classroom behaviour. With the older students, once they were broken in, more self learning could be introduced, this gave more opportunity to deal with the ones that were struggling. Project management is the same. Set simple tasks achievable tasks that you have the skills to check, find out who does as needed, and give them a bigger job next. The ones that struggle with the simple stuff need guidance, maybe from one of the better workers, before they can move on to bigger jobs. Project management generally has (expletive deleted) all to do with technical abilities, more to do with people interacting. I also use a simple metric when assessing trades (generally was for maintenance work). If their van has non standard wheels fitted i.e. larger alloys with lower profile tyres, I find they tend to rush a job. They usually drive like (expletive deleted), and park inconsiderately, as well. 2
saveasteading Posted August 27 Posted August 27 3 hours ago, flanagaj said: without sounding like you are insulting their intelligence Before they start check they have the drawing. Ask them if there are any issues arising. That is their moment to explain that they disagree or agree to build it as designed. Then you have an agreement and they work to it, or you don't and you have to manage the situation. You'll often find that they haven't got the drawing, or that your workers are not the one you agreed the job with. 3
Redbeard Posted August 27 Posted August 27 Perhaps explain briefly what a rough experience you have had before, and invite communication right from the start in the case of any doubt whatsoever. Not so easy, I appreciate, if you are not on site, but can they get you at short notice on your mobile to clarify any uncertainties, for example? Absolutely agree with @saveasteading re a dwg. Am I, however, right in remembering that you have only general, not detailed dwgs? Even an agreed scribbled (annotated with dims where applicable if not to scale)sketch can be invaluable in lieu of a detailed dwg, as long as the context is clear and understood. 3
Oz07 Posted August 27 Posted August 27 6 hours ago, flanagaj said: I appreciate that this might sound lift a daft question, but how do people go about communicating with trades to ensure the task is completed satisfactory and to LABC warranty standards, without sounding like you are insulting their intelligence or micromanaging? As you know, we have had two brickies and both were shit. They cut corners and didn't take pride in their work. For instance, the last guy had never laid Marmox blocks. His response like many (incorrect of course) was to say "that's what the insulation upstand is for". Needles to say, they were fitted with large air gaps at the joints ... It's difficult managing these people yourself, as they see you as someone not in the trade and therefore assume you know nothing and that their 20 years in the business makes them an expert. Our new bricklayers start Tuesday and I want it to work. I should not have to go out and see that the 3 courses of brickwork on the internals has been simply butted up to the 3 course that run perpendicular without either being bonded or tied in .. Any pointers welcomed on the best approach. I can completely see how a Clerk of Works is helpful here. Tbf I think it would be quite common finding brickies who've never touched marmox. Its uncommon. 1
Oz07 Posted August 27 Posted August 27 3 hours ago, SteamyTea said: When I was forced to teach the younger students I found that giving them loads of small, achievable tasks kept them busy and improved classroom behaviour. With the older students, once they were broken in, more self learning could be introduced, this gave more opportunity to deal with the ones that were struggling. Project management is the same. Set simple tasks achievable tasks that you have the skills to check, find out who does as needed, and give them a bigger job next. The ones that struggle with the simple stuff need guidance, maybe from one of the better workers, before they can move on to bigger jobs. Project management generally has (expletive deleted) all to do with technical abilities, more to do with people interacting. I also use a simple metric when assessing trades (generally was for maintenance work). If their van has non standard wheels fitted i.e. larger alloys with lower profile tyres, I find they tend to rush a job. They usually drive like (expletive deleted), and park inconsiderately, as well. A more reliable indicator with vans is to look in the back see how all their tools are kept. Neat or messy. I've never met a neat worker who has a messy van and tools. Maybe they exist but ive not met them.
SteamyTea Posted August 27 Posted August 27 25 minutes ago, Oz07 said: A more reliable indicator with vans is to look in the back see how all their tools are kept You only find that out after they have started, or spun a good yarn.
saveasteading Posted August 27 Posted August 27 2 hours ago, Redbeard said: Even an agreed scribbled sketch can be invaluable Get them to sketch it or describe it enough for you to draw up. To scale ad with dims. I'm afraid for you if you don't have drawings. It can work but there's a lot of risk.
Alan Ambrose Posted August 27 Posted August 27 For a set task by any trade, I am increasingly asking myself ‘what can go wrong here’ and ‘what is most important to get right’. It’s amazing how you can often predict what the f. ups will be in advance. Then make sure you’re around for that part and be firm and unapologetic. A good trade will like that you’re double checking. Listen to all the ‘we normally do it this way’ lines, decide whether you agree and, if not, explain politely why you want it done.a different way. Check in with your trades a lot at first, then less as you trust them. 4
flanagaj Posted August 27 Author Posted August 27 I have full drawings and our new structural engineer is just finalising the drawings for expansion joints and reinforcement, lintels and the associated installation details. For me though, it's more about when to let something slide and when to flag it as an issue. We live on site and as a result I will be out scrutinising the work each evening. For instance. How square should a door opening be? +-5mm, +-15mm .. Same goes for levels. I think I was unlucky with the last idiot. Massive ego due to being a bricklayer Instagram poster, who during the final tirade. told my wife and I that he was the best fxxxing bricklayer in Britain and I won't find better 😮💨.
Spinny Posted August 27 Posted August 27 Apparently it is all easy, and everything turns out perfect... https://youtu.be/wfitA6sDVcY?si=u3vMa5nAb6mKIq78 From my limited experience I don't remotely understand how any of this is even remotely achievable ? Anyone know ?
G and J Posted August 27 Posted August 27 Can't find the post quickly but @saveasteading suggested being on site as much as possible when people are there, even if you are just tidying, making tea etc, (but doing something) goes a very long way to building the relationship, as well as seeing what's happening. Difficult if you are not able to do that, even for a short while each day, as once it's happened and your seeing it after the event, it gives the resulting discussion more potential for getting fraught. 1
BadgerBodger Posted August 27 Posted August 27 9 hours ago, Oz07 said: Tbf I think it would be quite common finding brickies who've never touched marmox. Its uncommon. My bricklayer never saw them, my architect never saw them, I never saw them. Until I came here, then I SAW them. And I sold them the my bricklayer and my architect and I got what I wanted. It’s seriously tough when you don’t have the experience, but by being objective and listening to their needs you can usually find a way of communicating your needs. if you haven’t got detailed drawings, sketches or a written scope it’s hard for anyone to do anything on a price. Were marmox blocks clearly on the cards when they took the job?
BadgerBodger Posted August 27 Posted August 27 1 hour ago, flanagaj said: I have full drawings and our new structural engineer is just finalising the drawings for expansion joints and reinforcement, lintels and the associated installation details. For me though, it's more about when to let something slide and when to flag it as an issue. We live on site and as a result I will be out scrutinising the work each evening. For instance. How square should a door opening be? +-5mm, +-15mm .. Same goes for levels. I think I was unlucky with the last idiot. Massive ego due to being a bricklayer Instagram poster, who during the final tirade. told my wife and I that he was the best fxxxing bricklayer in Britain and I won't find better 😮💨. British standards are the first step in understanding what good should look like… then you have NSSS for steel and NSCS for concrete (which both basically reflect relevant BS in a slightly easier to read format) or the Highways Specification Series for earthworks, surfacing etc. But, good luck if your run of the mill builder has ever read or understands the whys and wherefores of them. And that’s what you have to manage… Expectations and realities. 2
ToughButterCup Posted August 28 Posted August 28 11 hours ago, Alan Ambrose said: ... Check in with your trades a lot at first, then less as you trust them. @Alan Ambrose , to the point as ever. @flanagaj hints at the trauma suffered by self-builders when the trust-building exercise faulters: they suddenly 'go-dark' , lay bricks with a muck-spreader. Pulling the project back on course when stuff goes wrong - now that's an art form. 2
saveasteading Posted August 28 Posted August 28 10 hours ago, G and J said: goes a very long way to building the relationship, as well as seeing what's happening. And also you are there for any questions arising. Usually they have a suggestion and usually it's sensible., but you will be part of the process. And you can nip to the BM to get what will sort it. Btw I'm relating a fraction of what goes wrong / causes other issues. 1
-rick- Posted August 29 Posted August 29 (edited) On 27/08/2026 at 21:33, Spinny said: Apparently it is all easy, and everything turns out perfect... https://youtu.be/wfitA6sDVcY?si=u3vMa5nAb6mKIq78 From my limited experience I don't remotely understand how any of this is even remotely achievable ? Anyone know ? I really like that house (though been a while since I watched the video). From my memory of it I think they made it work by: 1. Having plenty of previous experience. She is a designer with experience of remodels and IIRC her husband has industry experience of some form. They have worked up from from smaller remodels and projects. 2. From that previous experience they have a well established network of trades they can trust. These trades know they are reliable customers and this job is not a one off so they get better attention to detail and less 'risk' mark up for an unknown customer. 3. She seems really detail oriented, focusing on lower cost ways of achieving a result. But even with that focus, they had the money to spend to address issues as they came up (and trust in their trades when the trade needed more). Edited August 29 by -rick-
Nickfromwales Posted August 29 Posted August 29 On 27/08/2026 at 21:33, Spinny said: Apparently it is all easy, and everything turns out perfect... https://youtu.be/wfitA6sDVcY?si=u3vMa5nAb6mKIq78 From my limited experience I don't remotely understand how any of this is even remotely achievable ? Anyone know ? Using great people who know what they're doing, and actually GAF. From wet concrete late March ‘26 to moved in for Xmas ‘26 (with some areas incomplete but survivable) is my goal for current high-spec MBC build. I’m on site full time, both grafting and as principal consultant in charge of trades / quality control / sequencing etc etc. Defo can be done, but requires parting with money.
Spinny Posted August 30 Posted August 30 On 27/08/2026 at 23:07, BadgerBodger said: British standards are the first step in understanding what good should look like… Standards are useful no doubt, but I am not sure I would say they define 'good'. Often they define acceptable, or not unsafe, or structurally sufficent etc. I think 'good' tradespeople would easily exceed standards provided they have the attitude, working terms, environment to do so. There was a young lad early 20's working for my original builder, clearly seemed to want to do things properly and wanting to take job satisfaction from it. He was no longer working for the builder after a few months. It seemed clear that the builder's modus operandi & 'culture' just wasn't acceptable to him, he didn't want to be told to cut corners etc. There can be a very autocratic heirarchical structure in building - boss dictates, you do, don't ask questions, don't challenge, if something looks awry - keep your mouth shut. Site lead calls the shots right or wrong. Army like. There is always a time-cost-quality triangle. Some builders want to make money by squeezing down quality - cheap people, cheap materials, faster the better. A fair few customers can't afford or don't want to afford more I suppose. A sub-section of builders wanting to get paid for one quality standard, and build another. 1
saveasteading Posted August 30 Posted August 30 2 hours ago, Spinny said: always a time-cost-quality triangle It used to annoy me how often that was quoted, perhaps as an excuse. Mostly true but it ignores that a really good builder can be very efficient, and so can be faster and lower cost than a shambling, do it twice, one. Also that people said " choose two". My view was that we should reduce the size of the triangle. That involved defining quality with the client and then designing really well and practically for ease of construction. I think some designers confuse innovation and style with quality. And some clients confuse price with cost. And some builders are not as good as they think they are. 2
SteamyTea Posted August 30 Posted August 30 18 minutes ago, saveasteading said: My view was that we should reduce the size of the triangle Or make it an equilateral one. The area (size) of a triangle is 1/2 x height x base. So changing the angles makes no difference to the area, it just changes where the priorities are. There may be a management tool hidden in a triangle, somewhere, if I thought hard enough about it.
saveasteading Posted August 30 Posted August 30 45 minutes ago, SteamyTea said: There may be a management tool hidden in a triangle Like a circle in a spiral. Your line doesn't fit the song so well.
Redbeard Posted August 30 Posted August 30 23 minutes ago, saveasteading said: Your line doesn't fit the song so well. More like 'Canyons of your mind' (Bonzo Dog Doo Dah Band) than 'Windmills of your mind'....
Spinny Posted August 30 Posted August 30 1 hour ago, saveasteading said: Mostly true but it ignores that a really good builder can be very efficient Yes indeed. I could cite so many examples we have had where cocking something up has caused huge delay and rework and therefore cost. It is one of the reasons I have become a bit paranoid and am constantly trying to think 'what could go wrong with this job', and 'how can I get things prepared for that job' and 'have we got all the items needed' and 'what happens if it doesn't get finished'. When something is done wrong it often means: - You can't move on, the next task has to be put back or cannot be finished. - A trade needs to come back to do unplanned work and can't come back immediately. - undoing what has been done, before it can be done again correctly - items/materials being scrapped and having to be repurchased - Extra time being spent working out and agreeing how it can be put right - Some level of potential friction/frustration between the tradesman and the PM or customer Unfortunately without experience (and sometimes with) you cannot always cover all the bases and there are things that can come up that only arise as the task is underway. But that doesn't mean it makes sense to go into each task unprepared. Trades want to get on and get paid by the builder/customer. They may have been put under time and cost pressure and payment threats by the builder. If an issue arises or there is an ambiguity they normally just don't stop - they make their own decision, they carry on, they don't mention the issue. Good people will check, speak to or call someone - 'are you sure this drawing is right because it doesn't make sense?', 'these timbers are warped are you sure you want me to use them ?', 'I need to know where you want this socket ?'. Often times I have found it makes more sense to actually stop work and down tools. If we don't have certainty on the answer stop - take a day or even a week or two to get that certainty. You have different stakeholders with different self interests. The pig is committed, the chicken only involved - the customer wants his bacon and eggs please. And a cold half egg scraped off the floor with a bit of gristle on the side ain't going to do it.
