I appreciate that this might sound lift a daft question, but how do people go about communicating with trades to ensure the task is completed satisfactory and to LABC warranty standards, without sounding like you are insulting their intelligence or micromanaging?
As you know, we have had two brickies and both were shit.  They cut corners and didn't take pride in their work.  For instance, the last guy had never laid Marmox blocks.  His response like many (incorrect of course) was to say "that's what the insulation upstand is for".  Needles to say, they were fitted with large air gaps at the joints ...
It's difficult managing these people yourself, as they see you as someone not in the trade and therefore assume you know nothing and that their 20 years in the business makes them an expert.
Our new bricklayers start Tuesday and I want it to work.  I should not have to go out and see that the 3 courses of brickwork on the internals has been simply butted up to the 3 course that run perpendicular without either being bonded or tied in ..
Any pointers welcomed on the best approach.  I can completely see how a Clerk of Works is helpful here.
Your question is fundamental. It goes to the heart of the horror that self-building can become. And is the main cause of self-build-sleep-deprivation-syndrome
Humility, respect, time, trust, effort, plain speaking. And knowledge of their (the trade's) networks
Self builders are - to the trades we deal with - mostly one off customers. And because we self builders have to invest so much more time , emotion and 'fizz'  into our builds than those who 'simply' sign a cheque, many self builders ( not all)  think we're special.
To trades people, we aren't.
We're one of many jobs they have on the go at any one time.
Either
  • invest in someone who can manage the situation for you or
  • take the time to understand the trades networks so you can break through their communication blocks and
  • accept that substandard work does occur and that some work will have to be remedied
  • but most of all - be lucky
  • DIY
  • know when an error is something you just have to accept - and when not.
After more than 10 years at it, I'm only just getting to know like and trust a core of people who communicate well, do what they say they will do, when they say they will do it to an acceptable standard.
10 years to many people is just too long.
  • Like 4
When I was forced to teach the younger students I found that giving them loads of small, achievable tasks kept them busy and improved classroom behaviour.
With the older students, once they were broken in, more self learning could be introduced, this gave more opportunity to deal with the ones that were struggling.
Project management is the same.
Set simple tasks achievable tasks that you have the skills to check, find out who does as needed, and give them a bigger job next.
The ones that struggle with the simple stuff need guidance, maybe from one of the better workers, before they can move on to bigger jobs.
Project management generally has (expletive deleted) all to do with technical abilities, more to do with people interacting.
I also use a simple metric when assessing trades (generally was for maintenance work).
If their van has non standard wheels fitted i.e. larger alloys with lower profile tyres, I find they tend to rush a job. They usually drive like (expletive deleted), and park inconsiderately, as well.
Before they start  check they have the drawing. Ask them if there are any issues arising. That is their moment to explain that they disagree or agree to build it as designed.
Then you have an agreement and they work to it, or you don't and you have to manage the situation.
You'll often find that they haven't got the drawing, or that your workers are not the one you agreed the job with.
  • Like 3
Perhaps explain briefly what a rough experience you have had before, and invite communication right from the start in the case of any doubt whatsoever. Not so easy, I appreciate, if you are not on site, but can they get you at short notice on your mobile to clarify any uncertainties, for example?
Absolutely agree with @saveasteading re a dwg. Am I, however, right in remembering that you have only general, not detailed dwgs? Even an agreed scribbled (annotated with dims where applicable if not to scale)sketch can be invaluable in lieu of a detailed dwg, as long as the context is clear and understood.
  • Like 3
Tbf I think it would be quite common finding brickies who've never touched marmox. Its uncommon.
A more reliable indicator with vans is to look in the back see how all their tools are kept. Neat or messy. I've never met a neat worker who has a messy van and tools. Maybe they exist but ive not met them.
You only find that out after they have started, or spun a good yarn.
2 hours ago, Redbeard said:
Even an agreed scribbled sketch can be invaluable
Get them to sketch it or describe it enough for you to draw up. To scale ad with dims.
I'm afraid for you if you don't have drawings. It can work but there's a lot of risk.
For a set task by any trade, I am increasingly asking myself ‘what can go wrong here’ and ‘what is most important to get right’. It’s amazing how you can often predict what the f. ups will be in advance. Then make sure you’re around for that part and be firm and unapologetic. A good trade will like that you’re double checking. Listen to all the ‘we normally do it this way’ lines, decide whether you agree and, if not, explain politely why you want it done.a different way. Check in with your trades a lot at first, then less as you trust them.
  • Like 4
I have full drawings and our new structural engineer is just finalising the drawings for expansion joints and reinforcement, lintels and the associated installation details.  For me though, it's more about when to let something slide and when to flag it as an issue.  We live on site and as a result I will be out scrutinising the work each evening.  For instance.  How square should a door opening be? +-5mm, +-15mm ..   Same goes for levels.
I think I was unlucky with the last idiot.  Massive ego due to being a bricklayer Instagram poster, who during the final tirade. told my wife and I that he was the best fxxxing bricklayer in Britain and I won't find better 😮‍💨.
Can't find the post quickly but @saveasteading suggested being on site as much as possible when people are there, even if you are just tidying, making tea etc, (but doing something) goes a very long way to building the relationship, as well as seeing what's happening.
Difficult if you are not able to do that, even for a short while each day, as once it's happened and your seeing it after the event, it gives the resulting discussion more potential for getting fraught.
My bricklayer never saw them, my architect never saw them, I never saw them. Until I came here, then I SAW them. And I sold them the my bricklayer and my architect and I got what I wanted.
It’s seriously tough when you don’t have the experience, but by being objective and listening to their needs you can usually find a way of communicating your needs.
if you haven’t got detailed drawings, sketches or a written scope it’s hard for anyone to do anything on a price. Were marmox blocks clearly on the cards when they took the job?
British standards are the first step in understanding what good should look like… then you have NSSS for steel and NSCS for concrete (which both basically reflect relevant BS in a slightly easier to read format) or the Highways Specification Series for earthworks, surfacing etc.
But, good luck if your run of the mill builder has ever read or understands the whys and wherefores of them. And that’s what you have to manage… Expectations and realities.
11 hours ago, Alan Ambrose said:
... Check in with your trades a lot at first, then less as you trust them.
@Alan Ambrose , to the point as ever.
@flanagaj hints at the trauma suffered by self-builders when the trust-building exercise faulters: they suddenly 'go-dark' , lay bricks with a muck-spreader.
Pulling the project back on course when stuff goes wrong - now that's an art form.
And also you are there for any questions arising. Usually they have a suggestion and usually it's sensible., but you will be part of the process.
And you can nip to the BM to get what will sort it.
Btw I'm relating a fraction of what goes wrong / causes other issues.
On 27/08/2026 at 21:33, Spinny said:
Apparently it is all easy, and everything turns out perfect...
https://youtu.be/wfitA6sDVcY?si=u3vMa5nAb6mKIq78
From my limited experience I don't remotely understand how any of this is even remotely achievable ? Anyone know ?
I really like that house (though been a while since I watched the video). From my memory of it I think they made it work by:
1. Having plenty of previous experience. She is a designer with experience of remodels and IIRC her husband has industry experience of some form. They have worked up from from smaller remodels and projects.
2. From that previous experience they have a well established network of trades they can trust. These trades know they are reliable customers and this job is not a one off so they get better attention to detail and less 'risk' mark up for an unknown customer.
3. She seems really detail oriented, focusing on lower cost ways of achieving a result. But even with that focus, they had the money to spend to address issues as they came up (and trust in their trades when the trade needed more).
Edited by -rick-
Using great people who know what they're doing, and actually GAF.
From wet concrete late March ‘26 to moved in for Xmas ‘26 (with some areas incomplete but survivable) is my goal for current high-spec MBC build.
I’m on site full time, both grafting and as principal consultant in charge of trades / quality control / sequencing etc etc.
Defo can be done, but requires parting with money.
Standards are useful no doubt, but I am not sure I would say they define 'good'. Often they define acceptable, or not unsafe, or structurally sufficent etc.
I think 'good' tradespeople would easily exceed standards provided they have the attitude, working terms, environment to do so. There was a young lad early 20's working for my original builder, clearly seemed to want to do things properly and wanting to take job satisfaction from it. He was no longer working for the builder after a few months. It seemed clear that the builder's modus operandi & 'culture' just wasn't acceptable to him, he didn't want to be told to cut corners etc. There can be a very autocratic heirarchical structure in building - boss dictates, you do, don't ask questions, don't challenge, if something looks awry - keep your mouth shut. Site lead calls the shots right or wrong. Army like.
There is always a time-cost-quality triangle. Some builders want to make money by squeezing down quality - cheap people, cheap materials, faster the better. A fair few customers can't afford or don't want to afford more I suppose. A sub-section of builders wanting to get paid for one quality standard, and build another.
It used to annoy me how often that was quoted, perhaps as an excuse. Mostly true but it ignores that a really good builder can be very efficient, and so can be faster and lower cost than a shambling, do it twice, one.
Also that people said " choose two".
My view was that we should reduce the size of the triangle. That involved defining quality with the client and then designing really well and practically for ease of construction.
I think some designers confuse innovation and style with quality.
And some clients confuse price with cost.
And some builders are not as good as they think they are.
Or make it an equilateral one.
The area (size) of a triangle is 1/2 x height x base.  So changing the angles makes no difference to the area, it just changes where the priorities are.
There may be a management tool hidden in a triangle, somewhere, if I thought hard enough about it.
