Morning
My SB is an L-shaped bungalow which creates an internal courtyard garden. One of the walls facing the garden is exposed blockwork at present. I had been toying with cladding it, but prefer a slightly different idea....
I am considering erecting mesh frames onto the wall and growing ivy all over it.
Regarding preventing attachment (or damaging levels of attachment) to the house wall, the RHS says this:
Application of two coats of ‘Easy-On’, a clear anti-graffiti, silane-based, nanoparticle paint, was as efficient in preventing attachment. Application of another, petrochemical-based paint, while not completely preventing ivy attachment, significantly weakened it, thus easing ivy management.
This advice comes from the attached study. I am investigating the costs of appropriate paints, mesh, etc.
The obvious, and pertinent, question is: am I being mad?!
J-O-L-A-2016-Volume-3-Issue-1-Blanusa(etal).pdf
Having an old house last time, the damage caused by ivy can be very bad. I would avoid.  It grows very quickly and will be up the wall in no time, and then in the loft if you don't actively manage.
I wouldn't bother. But it's up to you.
No, you are making appropriate  enquiry.
I say don't do it. Ivy is superb for wbb's (wee brown birds). We have a wren , a possible greenfinch and a wbb on a small patch covering a neighbour' dreadful outbuilding.
But  is bad for buildings in 1. Clinging to surfaces, 2. Creating damp, 3. Intruding through any gap it can find.
So use something else there, like honeysuckle  perhaps and put the ivy up a pole or tree.
Thanks @JohnMo and @saveasteading.
The wall in question rises up to a parapet above a flat roof, so I don't need to worry about ivy getting into a loft. In fact, it would be pretty easy to trim at the top if needed.
I had thought about honeysuckle or other climbers, but few of them are evergreen like Ivy, nor are they as quick growing.
Are neither of you convinced by this arrangement of mesh sitting proud of a wall protected by this magic paint?!
54 minutes ago, Tony K said:
this magic paint?
I'm simply dubious about whether the RHS have fully tested this over a period of years OR thought through any other effects it might have.
An advantage of your  proposal is that you could trim or fully hack back the ivy occasionally. perhaps half each year.
OR   I have this and it is very vigourous, flowers for ages the remains attractive. we have pigeons (Posh name doves) and sometimes robins  in ours on a trellis.
It could almost be known as the 'mile-a-minute' clematis, such is the rapid growth of this variety. Clematis montana 'Mayleen' is the best scented Clematis montana too, with delightful satin-pink ruffled blooms. As if that wasn't enough, it has sparkling bronze foliage too. If you want a quick-growing handsome climber, look no further! Height: 10m (33'). Spread: 3m (10'). Pruning Group: 1.
For the mesh, Id get a plastic coated one, as it looks decent when bare.
Edited by saveasteading
Having removed thousands of metres of ivy from all sorts of structures over the years I wouldn’t say this is the worst idea I’ve heard of.
You will need a robust frame work as it can become very heavy.
I have only seen building damage occur if the building was in a poor state to start or the ivy was left unchecked.
for example poor pointing on brickwork, or the ivy getting under the gutter and behind the facia, I’ve seen thousands of pounds worth of damage in these instances.
you would need to build into your life a yearly trim, this would need to be the entire face and would involve getting onto the flat roof and cutting back from the copings.
i would want it cut with a 200-300 mm clear strip of blockwork showing below the parapet coping, allowing it to get under the coping could be disastrous.
you could build in a metal flashing at this level as a boundary.
