richo106 Posted Monday at 11:41 Posted Monday at 11:41 Hi All I am in the early stages of doing my driveway and we are looking at options of if we want to install electric gates etc.. I have put ducting around the drive and house so cabling is not an issue One thing I am struggling to get a definite answer on is distance from the road the gate has to be, this will determine if this is suitable for mine driveway and then when the visability splays Will I be able to do this under permitted development and will it need planning. I have made initial contact with my council but as always its very slow progress at the minute Has anyone installed gates (over 1m) and what regs/guidelines did they follow? I even had an electric gate company out and they didn't know (which didnt fill me with confidence!) Any information/advice appreciated on this topic Many Thanks
JohnMo Posted Monday at 12:45 Posted Monday at 12:45 57 minutes ago, richo106 said: Will I be able to do this under permitted development and will it need planning If you are doing a new build and it's not signed off, permitted development doesn't exist. You're legal obligation is to follow the agreed plans or do a variation. If you have a need for visibility splays, your into planning and highways approval. There is highways documentation that has full details of visibility delays (they change with speed limit and gate placements and how much of the driveway has to comply with highways road spec - that part only certified people can install the tar and sub surface.
richo106 Posted Monday at 12:50 Author Posted Monday at 12:50 I am not doing a new build, i had some major renovations and extensions couple of years ago and now finally getting round to doing some externals Cheers
Mr Punter Posted Monday at 13:49 Posted Monday at 13:49 The distance back from the kerb depends on the road type. The gates take a while to open, so you don't want to obstruct traffic. If the gates are over 1m high you will need planning consent.
Andeh Posted Monday at 15:35 Posted Monday at 15:35 I think (!) distance to road is governed by not blocking traffic whilst waiting for it to open. Ours is about 5m from memory. 1
Big Jimbo Posted Wednesday at 12:40 Posted Wednesday at 12:40 I think i did a bit of hunting around, and found 6 meters somewhere. Doubtful you will own a car longer than that. The council did pop round about the height of the gate. I told them it was 6 meters from the highway, and to f.off. They did. I wouldn't bother with PP. loads of case law out there about how far back from a highway, is far enough.
SBMS Posted 17 hours ago Posted 17 hours ago On 16/02/2026 at 12:45, JohnMo said: If you are doing a new build and it's not signed off, permitted development doesn't exist. Not quite true… PD rights exist when house is substantially complete. It doesn’t need to be signed off. I think if your gates are above 1m in height (when next to a road) you need planning otherwise they are PD.
ProDave Posted 16 hours ago Posted 16 hours ago On 18/02/2026 at 12:40, Big Jimbo said: I think i did a bit of hunting around, and found 6 meters somewhere. Doubtful you will own a car longer than that. But a motorhome could well be, and car towing any form of trailer. You don't want to be stuck with the a**e end of your vehicle stuck out on the road while waiting for your gates to open.
Roundtuit Posted 16 hours ago Posted 16 hours ago (edited) I forget the detail, but someone locally installed 6ft electric gates within about 2m of the highway. They were caught out and had to apply for retrospective permission. They successfully argued that the gates could be operated by remote control on the approach so that no road obstruction would occur. Utter bull$hit, but they got it passed... Edited 16 hours ago by Roundtuit typo
JohnMo Posted 6 hours ago Posted 6 hours ago 10 hours ago, SBMS said: Not quite true… PD rights exist when house is substantially complete. It doesn’t need to be signed off. So where does it say that in black and white?
torre Posted 6 hours ago Posted 6 hours ago 37 minutes ago, JohnMo said: PD rights exist when house is substantially complete. It doesn’t need to be signed off. Signed off by whom? You will certainly need to have satisfied all planning conditions, or it's not a lawful development in the first place. Relevant Planning geek article (we needed a NMA to install our solar during construction as it wasn't shown on the plans, even though clearly PD after)
JohnMo Posted 5 hours ago Posted 5 hours ago 1 minute ago, torre said: Signed off by whom? Building control, via a completion certificate. While building and site is under planning permission and the agreed scope of works, permitted development isn't lawful. Substantially complete as mentioned @SBMS, no idea where that comes from. Extending that, you add an extension to a new house before it's complete, sure that's not allowed! 1
Big Jimbo Posted 4 hours ago Posted 4 hours ago My understanding is that PD rights do not come into play untill a completion cert has been issued.
Oz07 Posted 2 hours ago Posted 2 hours ago (edited) I had a automated gate about 1.5m high and put it inline with the boundary about 300mm back. I pressed the button as approaching or just pulled up at side of rd. It was a decent width rd though. I was using an existing access which already had gates on it though. Never heard anything from council. Makes me wonder whether "installing" some scrap gates across an existing access before applying for permission is a good "hack" bet you can find scrap gates on marketplace Edited 2 hours ago by Oz07
Oz07 Posted 2 hours ago Posted 2 hours ago If OP installs his gates above 1m and council dont notice how long before they become legit.
