richo106 Posted 6 hours ago Posted 6 hours ago Hi All I am in the early stages of doing my driveway and we are looking at options of if we want to install electric gates etc.. I have put ducting around the drive and house so cabling is not an issue One thing I am struggling to get a definite answer on is distance from the road the gate has to be, this will determine if this is suitable for mine driveway and then when the visability splays Will I be able to do this under permitted development and will it need planning. I have made initial contact with my council but as always its very slow progress at the minute Has anyone installed gates (over 1m) and what regs/guidelines did they follow? I even had an electric gate company out and they didn't know (which didnt fill me with confidence!) Any information/advice appreciated on this topic Many Thanks
JohnMo Posted 5 hours ago Posted 5 hours ago 57 minutes ago, richo106 said: Will I be able to do this under permitted development and will it need planning If you are doing a new build and it's not signed off, permitted development doesn't exist. You're legal obligation is to follow the agreed plans or do a variation. If you have a need for visibility splays, your into planning and highways approval. There is highways documentation that has full details of visibility delays (they change with speed limit and gate placements and how much of the driveway has to comply with highways road spec - that part only certified people can install the tar and sub surface.
richo106 Posted 5 hours ago Author Posted 5 hours ago I am not doing a new build, i had some major renovations and extensions couple of years ago and now finally getting round to doing some externals Cheers
Mr Punter Posted 4 hours ago Posted 4 hours ago The distance back from the kerb depends on the road type. The gates take a while to open, so you don't want to obstruct traffic. If the gates are over 1m high you will need planning consent.
Andeh Posted 2 hours ago Posted 2 hours ago I think (!) distance to road is governed by not blocking traffic whilst waiting for it to open. Ours is about 5m from memory.
