I’m on a roll here !
Getting Alexa to run your own automations and use your own wording is a pita . Lots of “ let’s stop you “ from Amazon .
So I had a ha voice assistant - it’s ok ;  but its microphones are poor .
So ! Let’s make something that’s as reliable as  Alexa that’s local and no LLM .
zillion discussions with chat - and we have a planned approach . Bought an office style conference speaker unit . So multi directional etc . Mac mini has good processing for noise/ background suppression before passing it on . Speech back will be via a squeezebox player . .
VOICE SYSTEM – SOFTWARE STACK SUMMARY
  1. Wake Word Detection
    Software options:
  • Porcupine (Picovoice)
  • openWakeWord
  • Snowboy (older / legacy)
Purpose:
Continuously listens for a wake phrase locally with very low CPU.
  1. Speech-to-Text (STT)
    Software:
  • Whisper (OpenAI Whisper local model)
  • whisper.cpp (faster C++ local version)
  • Faster-Whisper
  • OpenAI Whisper API (cloud option)
Purpose:
Converts recorded audio into text.
  1. Speaker Identification (Voice ID)
    Software options:
  • Resemblyzer (voice embeddings)
  • pyannote.audio
  • SpeechBrain speaker recognition
  • Picovoice Eagle (commercial)
Purpose:
Creates a voice fingerprint and compares it against enrolled users.
Important:
This runs separately from Whisper.
Voice identity ≠ transcript content.
  1. Intent Parsing / Command Understanding
If rule-based:
  • Home Assistant built-in intent engine
  • Rhasspy
  1. Permission & Policy Layer
Software:
  • Home Assistant user permissions
  • Custom Python logic
  • Node-RED (optional orchestration layer)
Purpose:
Checks:
  • Who spoke?
  • Are they authorised?
  • Does this require confirmation?
Implements:
“Pocster is that OK?” → wait for verified response.
  1. Execution Layer
Software:
  • Home Assistant
  • MQTT broker (Mosquitto)
  • ESPHome
  • Custom Python services
Purpose:
Triggers actual devices, UI events, or automations.
  1. Text-to-Speech (TTS)
Software:
  • Piper (local neural TTS)
  • Coqui TTS
  • ElevenLabs (cloud)
  • Home Assistant TTS integrations
Purpose:
System speaks back to the user.
Clean Stack Example (Fully Local Setup)
Wake word: openWakeWord
STT: whisper.cpp
Voice ID: Resemblyzer
Intent: Home Assistant or local LLM via Ollama
Permissions: Custom Python layer
Execution: Home Assistant + MQTT
TTS: Piper
That is the full named software stack for your speech recognition + speaker ID + command system.
7 minutes ago, SteamyTea said:
WTF
Just put a switch or dial on the wall FFS.
That would make the tiling job harder and worst still make it the next job in the queue....
  • Haha 2
The thing that gets me about spending countless hours configuring and setting up some custom home brew voice control system, is how do you easily back up all the configured software, so WHEN it goes wrong you can just re install it again in a flash and it will all just work again.
It's bad enough with my Pi music box rebuilding that each time it crashes, and there is not much customisation of that.
I think that may be a problem with the OS. Dedicated hardware does not need the same sort of heavy overhead systems to run.
But yes, (expletive deleted)ing stupid idea.
Easily ! Mac Time Machine - backups up automatically every day / week
1 hour ago, SteamyTea said:
WTF
Clearly you don’t understand the issue . You cannot get Alexa to do exactly what you want without jumping through hoops “ Alexa play a random album by Coldplay “ and it selects a random cold play from your squeeze box and streamers to a default streamer . Or “ Alex disable jamma cabinet “ - recognises my voice only and does that .
You can frig some of these but it’s a pita also Amazon can cause issues .
I can and will have dashboard when done that these things are selectable. Home assistant voice can do these things with some effort but as said it’s microphones are crap . “ ok nabu radio on “ ; asking it then to turn radio off it won’t be able to mask out the background radio !!!
Once you have a stable reliable system there are many things that can be achieved - limitation is people’s imagination.
Posting here will of course land on lots of “ why bother “ views .
Take my home cinema setup . 1 button does about 6 things ( SWMBO friendly ) yet some of this hardware has no Bluetooth / zigbee / WiFi - so making dumb things work in the chain can be challenging.
Some of you have no vision …. 😆
Edited by Pocster
Remember this is local and no LLM overkill .
It was look at this today or painting …
Edited by Pocster
You’ve got it ! After building for 10 yrs a bit of variety and fun projects are required !
Chatting to my best mate we’ve had a strategic change . Going to historical LLM use multiple 8 way microphone arrays . Be able then to localise regions based on timing of wake word to hit which mic .
LLM allows a lot of fuzzy talk e.g
“ play something I like by Coldplay “
Going to add a database so we have history I.e in the above example you would play Coldplay album that I have played the most in the last 3 months on the speaker nearest to the microphone.
This exceeds Alexa capabilities. History of lighting / music etc from previous actions .
Equally I could record conversations as reminders to be replayed later 😊 ; can’t see any issues with SWMBO there .
Then we can take intent into assumptions . I get home at 7pm in a Friday rather than I ask for radio on Avalon ( that’s what it’s called ) could implement the likelyhood and therefore ask “ do you want the radio on Pocster ? “.
As constant querying verbally may become annoying we can have a point where it simply puts the radio in based on probability of that is what I want .
Also once wake word is received any audio has its volume reduced while doing speech to text as you speak I.e not waiting for command to finish .
Add in the voice id ( Alexa does this but not very well ) I.e SWMBO talking or me . If SWMBO requests something I haven’t authorised then confirmation is requested from me .
The more I think about this more uses I can think off - some OTT of course - but that’s the fun !
Edited by Pocster
8 hours ago, -rick- said:
Just lay some flipping tiles! 😜
You know what . I did that . I bed 4 tiles today
Edited by Pocster
Good job! As a master procrastinator myself, little and often seems to work quite well for jobs you'd really rather not do.
    Software options:
  • openWakeWord
Purpose:
    Software:
  • Faster-Whisper
Purpose:
    Software options:
  • pyannote.audio
Purpose:
Important:
If rule-based:
  • Rhasspy
Software:
Purpose:
Checks:
  • Who spoke?
Implements:
  1. Execution Layer
Software:
  • Home Assistant
  • ESPHome
Purpose:
Software:
  • Coqui TTS
Purpose:
STT: whisper.cpp
TTS: Piper
All I got from that was "hands free".
4 hours ago, Nickfromwales said:
Or ask the wife to switch it on/off.
Just asked your wife and she said she was in a hurry to get home.
1 hour ago, JohnMo said:
Home automation = hours/days arsing about, to save seconds or maybe even nothing in reality.
😂😂😂😂 . Limited vision expected from people whom clearly don’t understand the impact of local LLM and incorporating it into everything you can think of .
3 minutes ago, BotusBuild said:
What's in my head every time I read a computer related thread from @Pocster on BH 😀
Have been in his man shed?
Not what goes though mine.
I pressed the button and got this message.
'High Demand'
Edited by SteamyTea
