SimonD Posted Sunday at 17:18 Posted Sunday at 17:18 3 hours ago, Iceverge said: What is your occupancy per m3 of internal volume. If it's low enough the volume of internal air can buffer periods of over and under ventilation. We are 4 plus dog in a volume of above 900m3. But as I mentioned above, ventilation requirements change dramatically once a hydrophilic fabric is introduced into the equation. So, to quote from an earlier study I read when deciding on my design: Quote During the humid and cool weather, the hygroscopic materials improve the indoor conditions, but during the cold weather, the effect is minimal. An important result from the humid and cool test periods is that the comfort and air quality in a room with significant hygroscopic materials and a ventilation rate of 0.5 ach is nearly the same as that in a room with no hygroscopic materials and a ventilation rate of 1 ach. https://web.ornl.gov/sci/buildings/conf-archive/2004 B9 papers/002_Simonson.pdf Now, it does acknowledge that consideration regarding air polutants is probably separate, but other studies using MVHR show similar reductions on ventilation requirements simply because moisture drive such a significant proportion of those ventilation requirements. 18 hours ago, saveasteading said: It looks as if we have a club of three at present, and some others dithering or not committing. Yes, indeed. At some point when I actually find some spare time, I might draw together my collection of research into this and building physics just so there more readily available reference.
Iceverge Posted Sunday at 22:38 Posted Sunday at 22:38 Interesting study that. Undoubtedly there's marked humidity buffering effect with the hygroscopic materials. The test was done in the presence of controlled mechanical ventilation. Had this been turned off I suspect RH would have climbed higher than desirable in both cases. Passively/manually ventilating can work with the proviso you have one of the following. 1. Heat driven stack effect. 2. Very large internal volumes. 3. Diligent occupants. Hygroscopic materials will undoubtedly help smooth out the worst RH extremes with the latter two. However for almost all owners I would think mechanical ventilation would still provide much cheaper and more consistent control over IAQ.
Nickfromwales Posted Sunday at 23:28 Posted Sunday at 23:28 49 minutes ago, Iceverge said: Diligent occupants. ...or "home slaves". MVHR just ticks over and you go about life. Just why would you go for anything that needed any such diligence aka compromise on lifestyle.
MikeGrahamT21 Posted Monday at 09:12 Posted Monday at 09:12 9 hours ago, Nickfromwales said: ...or "home slaves". MVHR just ticks over and you go about life. Just why would you go for anything that needed any such diligence aka compromise on lifestyle. And the benefit of air filtering too
Iceverge Posted Monday at 09:52 Posted Monday at 09:52 Or a cheapo dMEV fan with humidistat if MVHR isn't in budget or feasible. 1
JohnMo Posted Monday at 11:16 Posted Monday at 11:16 1 hour ago, Iceverge said: cheapo dMEV fan Not all dMEV fans are equal, some are quite noisy, I installed one in the summer house, next day removed it as it made racket and installed Greenwood CV2, totally silent. 1
TheMitchells Posted 6 hours ago Posted 6 hours ago On 15/02/2026 at 17:18, SimonD said: Yes, indeed. At some point when I actually find some spare time, I might draw together my collection of research into this and building physics just so there more readily available reference. I'd be interested in reading that - though I would need you to keep it simple!
