saveasteading Posted 18 hours ago Posted 18 hours ago We had a delivery of sopping wet timber and sent it back. From asking around it seems that all suppliers round here keep tanalised (and other treatments) timber in the yard, uncovered. They think that is ok because it won't rot, and they regard it as 'outdoors' timber. Few have enough shelter, and seem to me to have far too much stock, perhaps as an investment. Their own trade specifies that all wood should be protected and ventilated. But they don't much care as long as it is selling. They don't invest in tarpaulins. The brochures may say kiln dried, but then forget to mention ' and then left outdoors in the rain until somebody accepts it.' The thing is, that we are using treated timber for the shell and are investing in the long term with no worries about dampness , woodworm etc. I know from experience that wasps can find their way into tiny gaps and like to chew wood for their nests, Treated wood won't be chewed twice. Plus as we are building in the open, it was bound to get a bit wet for a while. An earlier delivery was also wet, and it bent by up to 50mm over a 6m length, making it unsuitable for structure. Half of these were also sent back, without argument. So the moral is to tell your supplier that the timber must be dry in accordance with their industry guidelines. They might decline, but they can also set some aside under cover, or buy it in new from the docks. This probably does not apply to CLS which presumably is regarded as internal timber. We are ordering some so will see. Structural timber must be dry so that it keeps shape, especially in the vertical. And I dread to think what happens to a floor when the joists twist. Do the floor screws reach? Plus you don't want it twisting after construction. The timber industry body agrees, except that the merchants dont seem to know that. 1
SimonD Posted 18 hours ago Posted 18 hours ago 6 minutes ago, saveasteading said: The timber industry body agrees, except that the merchants dont seem to know that. There are a lot of people I know who are fed up with my moaning about this. I went to a merchant not long ago that a lot of builders around here use and swear by for timber quality. I then looked at their yard only to see the treated timber stacked in a hardcore yard that and not even paved and then the timber completely open to the elements. Needless to say I did not buy my timber from there. The issue is also protection from sunshine because as soon as the sun falls on some exposed damp timber, let the warping begin. The problem is that it's almost impossible to find a merchant that properly follows the standards. Even when stored under cover, the warehouses are almost never humidity controlled either. I use one supplier who has a closed humidity controlled warehouse you're not even allowed to access but have to wait outside for the forklift to bring your order, but even they store a lot of treated timber outside (with a little cover). 1
MikeGrahamT21 Posted 18 hours ago Posted 18 hours ago Places like B&Q and Wickes are actually quite good places to buy timber from, since their warehouses are also shops, they are heated to some extent and ventilated, but even there some of it can be warped, or just not dried enough as the tanalising happens after kiln drying (iirc), and often isn't left long enough to dry before being shipped to store
saveasteading Posted 18 hours ago Author Posted 18 hours ago We have gone with 'the devil you know' as they have agreed to buy in what we need and keep it indoors. obv this is no risk just cash-flow and a bit of space, but shows willing. We do have to do an urgent tally of expected quantities. (we have several km of timber going in) I can't understand why they can't put tarpaulins over. That is a one-time cost. The industry could make them to exactly suit bundles of timber at a low cost. Their industry document shows this. I guess the merchants just throw these covers away because the yardmen can't be bothered. I'm quite cross about this and worry somewhat about the quality of other buldings... eg the ones where our rejected timber goes to later. Also that the majority of project managers must be accepting this stuff.... and what else do they not care about? In case anybody wants more info. It quite clearly says that keeping it dry is very important. https://timberdevelopment.uk/are-you-keeping-your-timber-stocks-safe/ And the following summary comes from AI so is hardly hidden info. The yellow is my highlighting. Based on TRADA guidelines, proper storage of timber on site is critical to prevent moisture changes, warping, distortion, and staining. Key Principles for Timber Storage Keep Off the Ground: Store timber on dry, even ground to prevent moisture uptake, preferably on elevated, level bearers (e.g., 75mm x 75mm). Protect from Elements: Use waterproof, breathable covers to protect from rain and direct sunlight, which causes warping. Allow Air Circulation: Ensure air can circulate around the timber, even under covers, to prevent condensation and moisture buildup. Avoid Contamination: Keep timber away from standing water, muddy areas, and sources of damage.
