Beelbeebub Posted 18 hours ago Author Posted 18 hours ago 1 hour ago, BotusBuild said: Base load of Nuclear (fission to start, maybe fusion in the long term (maybe more than 20 years 😁)) Base load of Gas Turbines with 90 day storage Hydro (as in Wales) Tidal Solar Wind I would say the gas should be peaker/backup load not any kind of base load. 2
-rick- Posted 18 hours ago Posted 18 hours ago Just now, Beelbeebub said: I would say the gas should be peaker/backup load not any kind of base load. This and long term this is where hydrogen can be useful. Use excess solar during the summer to make hydrogen, store it for peaker use in winter. All done in one site, no need to pipe it anywhere. Other note is that batteries can fill all the short term responsive capacity that peaker/stored hyrdo used to do. The only thing batteries can't really do is longer duration peaker load. ie, those 1-2week super cold winter periods. 2
Beelbeebub Posted 18 hours ago Author Posted 18 hours ago 1 hour ago, Oz07 said: Tbf im not really on about re building our network based on coal or running off 100% coal. All I'm saying is its been a choice to demolish our remaining working coal power stations. Will that be a good choice time will tell. I don't think it is. A lot here seem to be doing some impressive mental gymnastics to explain why China are building lots of new coal plants but it's ok for them. If any coal stations were currently operational it would be wise not to shut them down. As I mentioned RoS was extended because of high gas prices. But my point is, they are shut down so it's water under the bridge. Two points to note are that the % of our total generation that used to be coal 30-40% in the late 00's early 10's is now supplied by renewables. So we have, in a sense, already replaced them. Secondly, coal prices are not immune to the current situation, so electricity from coal would be subject to the same price linkage as gas and oil. As for China. They are in a different situation from thr UK, their power demands are still growing. They are having to add more generation. Ideally all of this and more would be from renewables. Instead it is mostly (in the 4/5 range) from renewables and crucially the renewable addition is greater than the growth, so the proportion of coal is falling. It's not perfect but it is pretty good. Again they install more wind capacity that the entire UK grid every quarter. It's mind boggling - it also gives lie to the claim that renewables are a Chinese plot to cripple western industry....
SteamyTea Posted 18 hours ago Posted 18 hours ago 43 minutes ago, Beelbeebub said: Of course this is a win/win for the fossil fuel providers, not only do they get to keep selling their product, but demand actually goes up And it has still not happened apart from some small scale tests plants. It has been around over 30 years.
Beelbeebub Posted 17 hours ago Author Posted 17 hours ago 43 minutes ago, -rick- said: This and long term this is where hydrogen can be useful. Use excess solar during the summer to make hydrogen, store it for peaker use in winter. All done in one site, no need to pipe it anywhere. Other note is that batteries can fill all the short term responsive capacity that peaker/stored hyrdo used to do. The only thing batteries can't really do is longer duration peaker load. ie, those 1-2week super cold winter periods. The problem is and always will be storage of the amounts of H2 required. Just doing a quick calculation (may be wrong so here's the working) A large LNG carrier has around 250,000 m3 of LNG 1m3 of LNG is about 6.8Mwh thermal which equates to about 2.7Mwh electric (roughly 40% efficient). So a very large LNG carrier has 250,000 x 2.7Mwh = 680,000Mwh or 680Gwh of electricity. The UK uses around 22,000 Gwh in a cold month (and that's before we electrify heating and transport!). Which is about 700 Gwh a day. So we would need about 14 LNG tankers of storage for a fortnight. The problem is H2 is much harder to store cryogenically - it needs to be at - 250C or so. But if it was, it's energy density is 2.7mwh thermal per m3 so roughly 40% of LNG, that meany ou now need to store about 35 liquid H2 carriers holding H2 at -250C. If we store it as a compressed gas, the figures are even worse.
-rick- Posted 17 hours ago Posted 17 hours ago 2 minutes ago, Beelbeebub said: The problem is and always will be storage of the amounts of H2 required. Yep. Agree. Though you are assuming these plants would provide 100% of energy during the cold periods. Far from it. It would be there to augment existing supply not sure by how much but it will be a big difference. It would also be spread over many plants and the production side is relatively easier than LNG (as it's slow, not needing to compress at the speed that LNG plants do). But storage is a huge issue. For that reason I wonder if we do end up going down this sort of route we end up converting hydrogen to methane before liquifying it. Horrendously inefficient but also if done as a way to use summer excess (on massively overbuilt solar so that the deficit during winter is smaller) then might still make sense especially if it means existing natural gas users can switch to this supply too without retooling. To be clear its not a valid option for wide scale use but for some niche usecases where electric heating is not an option it might make sense. We imported 25% of our gas via LNG in 2024, this contingency capacity would less than 25% of our existing gas usage.
Beelbeebub Posted 17 hours ago Author Posted 17 hours ago 36 minutes ago, -rick- said: Yep. Agree. Though you are assuming these plants would provide 100% of energy during the cold periods. Far from it. It would be there to augment existing supply not sure by how much but it will be a big difference Good point.
Beelbeebub Posted 16 hours ago Author Posted 16 hours ago 38 minutes ago, -rick- said: It would also be spread over many plants and the production side is relatively easier than LNG (as it's slow, not needing to compress at the speed that LNG plants do). But storage is a huge issue. For that reason I wonder if we do end up going down this sort of route we end up converting hydrogen to methane before liquifying it. Horrendously inefficient but also if done as a way to use summer excess (on massively overbuilt solar so that the deficit during winter is smaller) then might still make sense especially if it means existing natural gas users can switch to this supply too without retooling. To be clear its not a valid option for wide scale use but for some niche usecases where electric heating is not an option it might make sense. If we are going down the speculative route I would propose Amonia production from spare electric. Relatively easy to store at normal pressures and temperatures. It is toxic so the stores would need careful positioning. It can be burned as a fuel for turbines but also converted to hydrogen for high temperature industrial and chemical uses. It is also an important precursor chemical for fertiliser production.... As you point out the synthesis may be inefficient, possibly more than just to H2 but if we are talking summer excess elec that we wouldn't be using anyway then the efficency is moot. This is the point of overbuilding our capacity. My solar array is way oversized. It punts out over 10kw on a sunny day. And after I have filled my 10kwh battery by mid morning I'm limited to 3.6kw export. But it does mean that even on a fairly overcast day like today I'm still generating over 1kw, which is plenty for my house and trickle charging my battery for overnight. If I could figure out a way of using the summer excess, even if it was inefficent it would be great. If I could store that excess for winter use, even at 50% or less round trip efficency, I could probably never need the grid. 1
SteamyTea Posted 16 hours ago Posted 16 hours ago Can we get our kW, kWh, MWh and so forth correct. It looks so much better. I use the dictionary on my phone to make it easy.
Oz07 Posted 14 hours ago Posted 14 hours ago 2 hours ago, Beelbeebub said: If we are going down the speculative route I would propose Amonia production from spare electric. Relatively easy to store at normal pressures and temperatures. It is toxic so the stores would need careful positioning. It can be burned as a fuel for turbines but also converted to hydrogen for high temperature industrial and chemical uses. It is also an important precursor chemical for fertiliser production.... As you point out the synthesis may be inefficient, possibly more than just to H2 but if we are talking summer excess elec that we wouldn't be using anyway then the efficency is moot. This is the point of overbuilding our capacity. My solar array is way oversized. It punts out over 10kw on a sunny day. And after I have filled my 10kwh battery by mid morning I'm limited to 3.6kw export. But it does mean that even on a fairly overcast day like today I'm still generating over 1kw, which is plenty for my house and trickle charging my battery for overnight. If I could figure out a way of using the summer excess, even if it was inefficent it would be great. If I could store that excess for winter use, even at 50% or less round trip efficency, I could probably never need the grid. Didnt @tonyshouse try this with a borehole in his basement. Probably too late to do now as it heated the ground up under his house iirc
Beelbeebub Posted 13 hours ago Author Posted 13 hours ago 1 hour ago, Oz07 said: Didnt @tonyshouse try this with a borehole in his basement. Probably too late to do now as it heated the ground up under his house iirc I have an old tractor, really tiny - uses a 2hp sidevalve B&S motor that is knackered. I was thinking of replacing it with a 2kw scooter motor from ebay and a 5kWh Lfp battery. Would be useful for little jobs our (slightly) bigger diesel one is currently overkill for. I'd replace diesel one except it is so bloody reliable and sips fuel it s not worth it.
Roger440 Posted 13 hours ago Posted 13 hours ago On 28/03/2026 at 16:08, JohnMo said: But what sort of coal was that? There are different grades for different purposes. The mine closed in 2024 produced high-grade anthracite coal, which is primarily used for industrial purposes, such as manufacturing steel and water filtration - no use for power stations. The last coal powered power stations imported the coal - so no point having them for self sufficient reasons. The way this thread is going, we will be dragging back the steam trains, and steam cars. Back in the good old days, when everything was rosy, we had pea soupers due to all the sulphur we were burning via coal. We can always bring coal gas back while we are at. And send the kids up the chimney to clean them. Sorry this thread is going daft. Who the f*ck wants coal anything - even the Chinese are installing more renewables than coal, and what coal power stations are there, are only used 50% of the time. So, theres a suggestion that we dont blow up a power station, because it might be useful in the event of a severe energy crisis. And thats managed to turn in to the threads gone mad, theres people advocating coal, steam engines and kids up chimnies. I think you were right, ban social media, because its clear some cant use it.
Roger440 Posted 13 hours ago Posted 13 hours ago 23 hours ago, Beelbeebub said: They will fix the energy security issue by stopping the small boats. They will fix the potholes in the roads by stopping the small boats. They will fix the cost of living crisis by stopping the small boats They will fix the NHS by stopping the small boats They will lower taxes by stopping the small boats They will ensure England win the world Cup by stopping the small boats. They will get rid of the itchy burning sensation between you toes by stopping the small boats. They will fix your leaky roof by stopping the small boats. Says the bloke who is displaying cult style behaviour in attempting to paint peoples postions (that are not as stated) and denigrate them, because there is only one possible viewpoint, yours. I get it, i MUST accept your position on everything. Because only you can be right. And if i dont agree, you will simply post more. And more. I guess a reflection of politics today.
Beelbeebub Posted 12 hours ago Author Posted 12 hours ago 18 minutes ago, Roger440 said: So, theres a suggestion that we dont blow up a power station, because it might be useful in the event of a severe energy crisis. None of the old coal plants are any use right now because none of them are working nor could any be brought back in to service in any real aitch timescale or budget. I looked up estimates for repowering a typical ccgt plant, not exactly the same but likely to be ball park, about £900m. Life extention was less but very dependent on the depth of the overhaul needed. Ivve agreed that if we had any plants running today and scheduled for imminent closure, we would be wise to look at keep them running for a bit longer. But that isn't the case
Roger440 Posted 12 hours ago Posted 12 hours ago (edited) 1 minute ago, Beelbeebub said: None of the old coal plants are any use right now because none of them are working nor could any be brought back in to service in any real aitch timescale or budget. I looked up estimates for repowering a typical ccgt plant, not exactly the same but likely to be ball park, about £900m. Life extention was less but very dependent on the depth of the overhaul needed. Ivve agreed that if we had any plants running today and scheduled for imminent closure, we would be wise to look at keep them running for a bit longer. But that isn't the case Jesus, give it a rest. But proving my point nonetheless. Edited 12 hours ago by Roger440
Beelbeebub Posted 12 hours ago Author Posted 12 hours ago 17 minutes ago, Roger440 said: Says the bloke who is displaying cult style behaviour in attempting to paint peoples postions (that are not as stated) and denigrate them, because there is only one possible viewpoint, yours. I get it, i MUST accept your position on everything. Because only you can be right. And if i dont agree, you will simply post more. And more. I guess a reflection of politics today. You bring some good arguments to the table and I'll happily change my mind. The orginal premise of the thread was to highlight that there was no realistic possibility of improving UK energy security by increacing oil and gas production (and that the best route was a package of policies broadly in line with "Net zero") To support my position I referenced several studies and reports, including from the oil industry itself, showing the impracticallity of "drill baby drill" To my knowledge nobody has rebutted that other than insisting I'm wrong and there is tons of oil just waiting to be found.
Beelbeebub Posted 12 hours ago Author Posted 12 hours ago 3 minutes ago, Roger440 said: Jesus, give it a rest. But proving my point nonetheless. When have I misrepresented your position? I merely mentioned there seems to be a nostalgia streak and desire to find any alternative to renewables even coal.
Roger440 Posted 12 hours ago Posted 12 hours ago 13 minutes ago, Beelbeebub said: When have I misrepresented your position? I merely mentioned there seems to be a nostalgia streak and desire to find any alternative to renewables even coal. You just said it. And my point is that you cant be wrong. Ever. There is no point discussing anything, because there is a risk my view wont align with yours. (high risk id suggest) And you are always right. I humbly apologise for daring to question or comment your narrative. Or is it a broadcast.
Onoff Posted 12 hours ago Posted 12 hours ago 28 minutes ago, Beelbeebub said: there seems to be a nostalgia streak In some cases justifiable in spades: https://www.sovereignmagazine.com/article/cornish-mine-redmoor-billion-critical-minerals
Beelbeebub Posted 12 hours ago Author Posted 12 hours ago 4 minutes ago, Onoff said: In some cases justifiable in spades: https://www.sovereignmagazine.com/article/cornish-mine-redmoor-billion-critical-minerals Brilliant - we should look to mining that. Probably not with steam pumps and kids though... 😁
Beelbeebub Posted 12 hours ago Author Posted 12 hours ago 19 minutes ago, Roger440 said: You just said it. And my point is that you cant be wrong. Ever. There is no point discussing anything, because there is a risk my view wont align with yours. (high risk id suggest) And you are always right. I humbly apologise for daring to question or comment your narrative. Or is it a broadcast. I'm frequently wrong Show me some evidence and I'll happily change my mind (I still think we need to stop burning fossil fuels from a climate PoV, but i'll accept that the energy security facet will move from "a reason to stop burning fossil fuels" to "a reason we might need to keep churning fossil fuels"). I'll point out that the ones in this debate who are clinging to the idea we can "drill" our way to energy security despite the evidence to the contrary are the ones displaying the "can't be wrong ever" attitude... 1
SteamyTea Posted 1 hour ago Posted 1 hour ago 10 hours ago, Onoff said: In some cases justifiable in spades: Tungsten mines are nothing new down here, but may give a good proxy as to how long it takes to start mining again. https://en.wikipedia.org/wiki/Hemerdon_Mine Six years and not much has happened.
Onoff Posted 59 minutes ago Posted 59 minutes ago 17 minutes ago, SteamyTea said: Tungsten mines are nothing new down here, but may give a good proxy as to how long it takes to start mining again. https://en.wikipedia.org/wiki/Hemerdon_Mine Six years and not much has happened. Wasn't there a tin mine where they switched the pumps off and everything flooded? A couple of weeks later the price shot up as in it would have paid to keep it viable. By then though the damage was done etc.
SteamyTea Posted 35 minutes ago Posted 35 minutes ago 11 minutes ago, Onoff said: Wasn't there a tin mine where they switched the pumps off and everything flooded? Most are now flooded. The water has to be managed to reduce the contamination risk. Not a case of close the mine and walk away. At the place I work I thought I had hit a wall early in the morning. Then realised I was a few feet from it. Had a look around and the ground was leaking water. During the day, a 40m strip of tarmac got distorted and more water started coming out. It eventually went up the slope to, what looks like an old vent shaft. Millions of litres of water have come out of it, into the stream. 104 years since it closed. Going to cost £200k (ish) to put right. We really should not be mining for energy when cheaper alternatives are now available. Shafted.mp4
