ToughButterCup Posted Wednesday at 12:54 Posted Wednesday at 12:54 fekkin' it up... I have some metal Lindab downpipe that needs to be cut - to install a diverter to a water butt. I'm happy about marking it out (use a downpipe bracket) , but I'm hesitant about cutting it. Why? 'Cos it's thin. Once it's been deformed (by me grabbing it and trying to keep it still) it never goes back into shape properly. Anyone know how to cut it cleanly without bending it at the same time? I've looked on Tinternet and on Lindab's own site without much success. Hence this post.
JohnMo Posted Wednesday at 13:09 Posted Wednesday at 13:09 https://tradewarehouse.co.uk/blogs/metal-guttering/how-to-cut-metal-guttering?srsltid=AfmBOopQ4EZ-p-gajPUNlRl2O4PXaEP0PWWypwK32BUxOrptG8Qb4rMp
Gone West Posted Wednesday at 13:12 Posted Wednesday at 13:12 16 minutes ago, ToughButterCup said: Anyone know how to cut it cleanly without bending it at the same time? I cut all our Lindab guttering system with a hacksaw as was recommended by Lindab. 1 1
markc Posted Wednesday at 14:10 Posted Wednesday at 14:10 If you need to cut into the down pipe, holesaw for round holes, dremel type machine with a cutting disk for straight lines / squares etc 1
ToughButterCup Posted Wednesday at 15:06 Author Posted Wednesday at 15:06 (edited) 1 hour ago, Gone West said: I cut all our Lindab guttering system with a hacksaw as was recommended by Lindab. I've watched their videos and looked at the tradesman and thought they forgotten more than I know about how to do this. It's how they support the work that is so skilled. I'm going to have to set up a work table to hold the downpipe in place while I cut it. I am ashamed deeply deeply ashamed to have to admit here in front of millions of people that I have not got a hacksaw. But now that I come to think about it one of my children will have stolen it. Ah well it's an ill wind that blows nobody any good, so here's the excuse for another trip to the builders merchant. Knowing them they won't have the size I need will they? 😑 Edited Wednesday at 15:10 by ToughButterCup
Gone West Posted Wednesday at 16:10 Posted Wednesday at 16:10 1 hour ago, markc said: If you need to cut into the down pipe, holesaw for round holes, dremel type machine with a cutting disk for straight lines / squares etc In the Lindab instructions they specifically say not to use power tools for cutting. The reason they give, is that using power tools destroys the galvanising around the cut. Apparently if hand tools are used then the galvanising is able to 'creep' back over the cut surface and maintain rust proofing. We didn't have any rust problems after six years. 2
Gone West Posted Wednesday at 16:13 Posted Wednesday at 16:13 1 hour ago, ToughButterCup said: It's how they support the work that is so skilled. I just used a WorkMate with the jaws around 40mm apart and rotated the downpipe as I cut it with the hacksaw. 1
Onoff Posted Wednesday at 17:06 Posted Wednesday at 17:06 Roll a thin bit of card around the pipe and mark with a Sharpie. That'll give you a dead square cut line. Then use the hacksaw to follow the pen line, rotating the tube as you go. As in you're almost scoring it. Take it easy and the saw will follow the groove when you finally cut the tube. 1 1
SteamyTea Posted Wednesday at 18:28 Posted Wednesday at 18:28 I find a diamond cutting wheel on an angle grinder is pretty good for cutting thin metal. I also have all my fingers.
Onoff Posted Wednesday at 19:20 Posted Wednesday at 19:20 (edited) I think when zinc coated steel is cut, zinc oxide forms. This acts as a protective layer. Only really works on thin sheet edges. Same with a light scratch. Won't work on say the cut end of a galvanised RSJ. Best thing for that is a Zilt stick applied with a porta pack. Most now use so called "cold galv" out of a rattle can. Zinga is very good. Edited Wednesday at 19:21 by Onoff 1
SteamyTea Posted Wednesday at 19:51 Posted Wednesday at 19:51 (edited) 30 minutes ago, Onoff said: Zinga is very good A Zinga Gazelle was a car, taking you back to your Rootes. Edited Wednesday at 19:51 by SteamyTea
SimonD Posted Wednesday at 22:09 Posted Wednesday at 22:09 6 hours ago, ToughButterCup said: It's how they support the work that is so skilled. I've used two methods. One was with a really old work bench where the surfaces could be angled to 45degrees and the tube would just rest in the pocket. The other was just to screw some 4 x 2 together at right angles and gently hold the pipe against those. Eventually you'll get the feel of very light strokes with the hacksaw and you can hold both the gutter and down pipes by hand on any bench and it works fine. For the holes in the gutter, you need to get yourself some tin snipps and a decent dead blow hammer for the edges. Installation instructions attached. Have fun. It's lovely material to work with. Rainline-Assembly-Guide.pdf 1
Nick Laslett Posted Thursday at 09:50 Posted Thursday at 09:50 Robin Clevett has a Lindab guttering install video on Skill Builder. If you fall down the rabbit hole far enough, you can find Lindab documentation that informs that you can use a metal chop saw for cutting the material. http://publications.lindab.com/UK/rainline-brochure/?Page=2&page=46 Even the product sheet for the downpipe mentions chop saws. https://www.lindabprofile.co.uk/wp-content/uploads/2021/06/Lindab-Downpipe-SROR-Data-Sheet.pdf Obviously a hacksaw is the simplest method. They also have touch-up paint for the cut edges and drill holes, how necessary this is, is anyone’s guess.
Nestor Posted Thursday at 11:09 Posted Thursday at 11:09 I used a holesaw for the gutters and a 5" grinder for cutting downpipes. 17 hours ago, Onoff said: Roll a thin bit of card around the pipe and mark with a Sharpie. That'll give you a dead square cut line. I rotate the gutter by hand whilst cutting. I struggle using a hacksaw, the blade is to fine and narrow even using a mitre box. 1
Oz07 Posted Thursday at 16:27 Posted Thursday at 16:27 There was some lindlab on a house I looked at the other week and I was distinctly unimpressed. Is this stuff expensive? It didn't look bad but it didn't strike me as looking any better than pvc. Perhaps the guy used a rubbish range
Mr Punter Posted Thursday at 16:29 Posted Thursday at 16:29 I have used a chop saw. One of the Evolution multi material ones. Goggles are a must.
Nestor Posted Thursday at 17:09 Posted Thursday at 17:09 35 minutes ago, Oz07 said: There was some lindlab on a house I looked at the other week and I was distinctly unimpressed. Is this stuff expensive? It didn't look bad but it didn't strike me as looking any better than pvc. Perhaps the guy used a rubbish range I fitted over 90 metres of Lindab Majestic gutters and assorted outlets, brackets, joints etc and thought the quality was very good though a bit surprised the leaf trap was plastic. Obviously looks great but the cost!
ToughButterCup Posted Thursday at 17:23 Author Posted Thursday at 17:23 I (erm, we..😳) fitted ours so long ago I have forgotten how we did it. But I do remember fitting some of it in a thunderstorm. How tired of living were we ! In answer to your point @Oz07, you can rest a ladder on it, it sounds nice in the rain and you can't hear it expand and contract in the sun as happens on our cottage. Thanks everyone. Tomorrow's job. 😑 1
