Alan Ambrose Posted Saturday at 12:41 Posted Saturday at 12:41 (edited) Apart from @Thorfun, I can't see any mentions of CCT LED strips on 't 'ub - i.e. the ones that you can change the colour temperature of from warm to cool white. Any thoughts or experience? Edited Saturday at 12:44 by Alan Ambrose
Russell griffiths Posted Saturday at 14:18 Posted Saturday at 14:18 What do you want to know, I’ve got about 12m of it in a kitchen fitted in a small aluminium track. all works from an app on the I pad and switched from the wall so the last setting is remembered. the LGBGT multi colour ones are ridiculously expensive compared to them. 1
Alan Ambrose Posted Saturday at 14:20 Author Posted Saturday at 14:20 @Russell griffiths - do you actually change the colour much and/or do you have it on a schedule?
Russell griffiths Posted Saturday at 17:09 Posted Saturday at 17:09 2 hours ago, Alan Ambrose said: @Russell griffiths - do you actually change the colour much and/or do you have it on a schedule? The white ones we don’t alter much, chilled out mellow white in all the glass cabinets and on the ornaments. the RGB ones we have we mess with loads more, but that’s probably just the novelty, we haven’t moved in yet.
-rick- Posted Saturday at 17:58 Posted Saturday at 17:58 (edited) My aim for any new install is to have cct lights. I want them for three main reasons: 1. As dawn simulation to help me wake up even in the middle of winter with dark mornings. Using home automation to gradually introduce light over a period of time before the alarm goes off. Used to have a wake up light that does similar but expect an installed version with bright LEDs to be better. 2. As daylight augmentation during winter. I hate the dark days when cloud comes out and it’s dark enough inside to need to turn the light on but when you do the lights have such a different tone that I feel it better to close the curtains even hours before dusk. Again with automation and light sensors I believe it should be possible to have the lights turn on ct matched to the daylight and boost the light without feeling the jarring effect. 3. As dusk simulation. As per (1) but the other way round with ct moving from cool to warm as the evening goes on and help the body naturally prepare for sleep. In this case it’s moving dusk later during the dark months. * I’m not really bothered by multicoloured lights though do like the idea of having red low level lights come on dimly if I wake up and move around in the middle of the night. Suspect not worth the hassle and will just use very dim white for this. Edited Saturday at 18:01 by -rick- Add bit on Red light and fix spelling 1
Mike Posted Saturday at 19:22 Posted Saturday at 19:22 (edited) 1 hour ago, -rick- said: 1. As dawn simulation to help me wake up even in the middle of winter with dark mornings. Using home automation to gradually introduce light over a period of time before the alarm goes off. Used to have a wake up light that does similar but expect an installed version with bright LEDs to be better. I'd be with you for at least the fade-up feature, given a suitable controller to automate it. 1 hour ago, -rick- said: 2. As daylight augmentation during winter. I hate the dark days when cloud comes out and it’s dark enough inside to need to turn the light on but when you do the lights have such a different tone that I feel it better to close the curtains even hours before dusk. I hate dark days too, so if the alternative was a fixed CCT of 3,000 K or less, then this would be useful. However, with my personal preference for 4,000K I never have a desire to close the curtains before dusk. 1 hour ago, -rick- said: 3. As dusk simulation. As per (1) but the other way round with ct moving from cool to warm as the evening goes on and help the body naturally prepare for sleep. In this case it’s moving dusk later during the dark months. I can see the utility of this for some people. Though, as a night-owl, it wouldn't suit me at all, at least not until the last few minutes of the day. 6 hours ago, Alan Ambrose said: Any thoughts or experience? In short, I think that the value of changeable CCT lighting depends on how you like your lighting; I'm not a fan of cool lighting (except in limited circumstances) nor of warm lighting (unless it's in an old cottage or the result of real candles), but if you are, then go for it - in which case I'd recommend applying it to all lighting (that will be switched on together) so that you don't end up with an odd mix of colour temperatures. Edited Saturday at 19:23 by Mike 1
-rick- Posted Sunday at 07:04 Posted Sunday at 07:04 10 hours ago, Mike said: I hate dark days too, so if the alternative was a fixed CCT of 3,000 K or less, then this would be useful. However, with my personal preference for 4,000K I never have a desire to close the curtains before dusk. If 4000k works from dawn to dusk for you then yes that’s a cheaper alternative. 10 hours ago, Mike said: I can see the utility of this for some people. Though, as a night-owl, it wouldn't suit me at all, at least not until the last few minutes of the day. I’m mostly a night owl too, but I think there is value in having a way to subtly wind down near bedtime and the older I get the more I realise how lighting impacts that. 10 hours ago, Mike said: in which case I'd recommend applying it to all lighting (that will be switched on together) so that you don't end up with an odd mix of colour temperatures. absolutely. Mismatched temperature lighting is awful. Bulbs is the difficult aspect. LED strips are cheap and easy to do as CCT but I’ve still not settled on the best way to do temp changing bulbs as I’d rather not have smart bulbs but smart controllers, dumb bulbs. After the last conversation we had on this topic here I’ve started considering buying non cct bulbs and gutting them to replace the LEDs with CCT ones and controlling them with a custom controller as mad as that sounds because I’ve not seen products that do what I want. 2
Spinny Posted 16 hours ago Posted 16 hours ago I agree CCT bulbs with remote control are the real problem. Many manufacturers make CCT switcheable downlights which can be manually switched at the ceiling fitting. The continuing lack of zigbee etc smart lights is testament to the backward nature of the industry. Many smart bulbs e.g. GU10 are dim giving only 350-400lm and IMO anything less than 600lm+ is not really bright enough - at least with higher ceilings and when you want bright task lighting. i am planning to put 2 LED strips into some of my profiles - 1 cob addressable RGB to use for colour chasing etc - and another cob CCT alongside for good tunable whites. I have tested out, but not yet installed so cannot comment on level of use. In general the white colour matching issue is a PITA, and bright dimmable remotely controllable CCT lights with highish CRI's are the required answer, but with seemingly no-one actually making them in bulb or integrated downlight form.
