So we have designed our roof using posi rafters. Originally our makeup was going to be from inside out…
plasterboard
battens
propassiv
304mm blown cellulose
22mm Steico sarking
counterbatten
slates
This Yielded 0.12 u value.
We have really been struggling to get someone to do the warmcel blown insulation so I am now considering other options…
I would rather not change out the posi rafers So I have 304mm Of rafters depth to work with.  Could I just swap out the cellulose for 2
layers Of say 150mm mineral wool? Would I need batts or the roll?
The warmcel was 0.038W/mk so I think a 0.035 or even 0.032 would give a better u value… does the above makeup support this or would I need to change it?
Reason I went cellulose was to minimise issues with fitting which is the same reason I don’t want to go PIR..
What kind of pozi’s, are they the metal web jobs or the I beam type?  The metal web jobs are a PITA, to get between the webs on the joist without making a mess of your hands, or material, it’s doable of course just increases the amount of labour time to do it right without gaps etc.  Just my thoughts just so you go into this with eyes open!
Metal web… I wouldn’t pick the easy option would I?! I’m going to speak to Steico today as they do a blown cellulose and a blown wood fibre product. I think their installer network is a bit more mature than warmcel…
It's such a shame that Warmcell seems so hard to get done, and costly. In America, they seem to sell the stuff in Home  Depot, and have the machines instore for hire. DIY in a weekend.
Our roof is a similar construction, but I tried to go warmcell and they refused to do it. In the end I had all the interstitial condensation calculations done and went open cell spray foam - 300 to 350mm deep. 250m² of roof done in a day and a half.
We used normal wood sarking boards with small gaps, no need for counter battens with natural slates.
plasterboard
battens
propassiv
22mm Steico sarking
counterbatten
slates
Have you tried Gordon, the chap that does a lot of the MBC frames? I know MBC will be keeping him busy, but worth a call as you can do this at any time and shouldn’t really hold you up being in the queue.
@JohnMo - which foam did you use out of interest and what was your end U Value? Am happy to look at all options really, but have been very wary of foam for obvious reasons (mortgages being one)...
Have you got a contact for Gordon?
Icynene LDC-50
Used battens under posi rafter to kill of thermal bridges.
U values Pitched 0.13
Nearly flat (12 degs) 0.12
Only issue with spray foam is numb skull installers that install in inappropriate places like holding a roof structure together with closed cell foam and a non vapour permeable membrane. Then wonder why the roof rots.
14 minutes ago, JohnMo said:
Icynene LDC-50
If you could have had warmcel over foam would you have used that instead?
Not sure. Not seeing anything wrong with the foam, it's been in for nearly 4 years.
Icynene LDC-50
Decent spray foam guys will propose a very thin layer of closed cell, either before or after the bulk open cell stuff is loaded into the voids, to act as the barrier.
Did this in a basement where we needed to insulate under the residence floors (swimming pool hall was its own heated and airtight envelope) and it worked a charm.
As with every single thing in life, if it’s done great on paper and executed less than well, it’ll fail.
Jobs like this need a clued-up client who can be on site and know what they’re looking at, or a good PM / site agent to do so in their behalf.
3 hours ago, SBMS said:
Was speaking to another installer that blows in Supafil Frame
Eleven years ago when I was considering what insulation to use, Supafil Frame was on my shortlist. I discounted Warmcel as a friend had used it in her house and had problems. In the end I used 350mm Icynene for the walls and roof of my timber I-beam portal frame. The only problem was trimming and cleaning up. I did use a similar product to Supafil Frame in the walls of the old bungalow I was living in, while building the house. When I dismantled the bungalow it was easy to see how well it had filled the old timber frame.
What problems out of interest?
The Warmcel was slumping and as a result there were cold areas around the ceilings. All down to the installers I guess. What I liked about the Supafil Frame was that, at the time, they used a transparent membrane so it was possible to see how well filled it was.
Anyone else had cellulose and had problems with slumping... I assume its an installer issue rather than an inherent problem with cellulose in pitched roofs?
  • 1 month later...
Jumping in on this as I’m in the process of planning a similar buildup for my roof. I’ve managed to get a price from a warmcell installer which is a good start. His material price plus install is very similar to a mineral wool alternative laid to the same thickness, if not a little cheaper if you consider the 0%vat.
I’m looking at a few other insulation options currently and if I were to go with warmcell or a deep mineral wool I’d be using JJI rafters due to being easier to cut and work with onsite. They’re also half the price of eco/posi’s for my job.
Are you having vaulted ceilings? @SBMS
@Nickfromwales could I get Gordon’s number also?
Yes we are having vaulted ceilings. Out of interest what was the price difference? My posi rafter roof is designed so there isn’t any cutting onsite needed?
You can get blown mineral wool also, so may be another option
I got a quote for this - was nearly double cellulose for some reason for the same thermal performance.
For the JJI joists which are supplied to me in full lengths ready to cut to length with very little waste, mostly the angled cuts for the ridge and wall plate come in at £3200. For the same lengths in eco/posi joists they came in at £7320. The posi’s would need more designing that this though as I have a valley which I would be hand cutting with the JJI joists. I haven’t done a posi valley so if they can’t be supplied with enough waste on the end for the cut no doubt there would be a greater cost for supplied/cut to lengths.
Who did you approach for blown mineral wool? I see Knauf do a supafil product. What was the product you were quoted on?
7k was about the same as mine - including all fixings though.  Posis won’t work easily into a valley between two roofs if that’s what you’ve got. Those rafters are being done in engineered/glulam. Couple of things to factor in… connectors and hangers. Our posi joists are being hung from our steel ridge beams. Those hangers quickly add up and could be as much as 1k-2k so factor that in if they haven’t been for JJIs. If you’re fitting the roof then fair play. If a joiner is I would say it’ll be easy to burn through 2-3k in labour cutting and fitting… I think posis can span further because larger rafters can be used but you might not need that. I’ve also made it so that our posi rafters oversail the wall plate for a ready made fixing for the soffit/fascia.
Yes - we got a quote for supafil - 12k vs 7k for cellulose. Roughly the same thermal performance if I remember correctly.
