JamesPa Posted Saturday at 21:01 Share Posted Saturday at 21:01 38 minutes ago, Beelbeebub said: Technically speaking the heat in an A2A heatpump is delivered as a hot gas (vapour) that is condensed into a liquid at the point of heat delivery (the room unit heat exchanger coil). So it is a tricky question if the delivery is via gas or liquid. I'm not sure the legal system is capable of dealing with the finer points of thermodynamics Thanks for the clarification. I think you are right that the legal system can't deal with the finer points of thermodynamics but on that account I would say the delivery medium is a gas. It would be interesting to understand what the intent was. If it's only to allow a2W why use 'liquid' as opposed to 'water ( which may be treated to prevent corrosion or freezing)' Link to comment Share on other sites More sharing options...
Beelbeebub Posted Saturday at 21:33 Share Posted Saturday at 21:33 I've poked around to try and see where the prohibition on A2A might be. I haven't found it yet, except that the new system must provide all the heating and hot water and no hybrid systems are allowed. There are very few A2A systems that can also provide hot water. I believe daikin do one, but I haven't actually seen it in this country and I don't think it has any mcs certification. So maybe it would be as simple as allowing hybrid systems. Again, I think allowing A2A would see a significant up tick in installs as it would be cheaper and hence might be entirely covered by the grant. It is also potentially less disruptive for some properties. There would be an issue with skills as we don't traditionally have many A2A fitters in the UK. That said, if we coukd get our arses into gear around r290 and the manufacturers could produce r290 multi splits, I don't expect there would be much conversion from a gas safe engineer to an r290 safe engineer. There aren't any actual skill sets that are different the main criterion is being responsible and diligent when it comes to ensuring the gas lines are secure. Link to comment Share on other sites More sharing options...
JamesPa Posted Saturday at 21:46 Share Posted Saturday at 21:46 7 minutes ago, Beelbeebub said: I've poked around to try and see where the prohibition on A2A might be. I haven't found it yet, except that the new system must provide all the heating and hot water and no hybrid systems are allowed. There are very few A2A systems that can also provide hot water. I believe daikin do one, but I haven't actually seen it in this country and I don't think it has any mcs certification. So maybe it would be as simple as allowing hybrid systems. Here are the regs for BUS https://www.legislation.gov.uk/uksi/2022/565/contents/made Reg 9(2) requires that the heat is delivered by a liquid. Based on your explanation of A2A above I think that excludes A2W but there clearly may be room for debate. Definitely there is no exclusion of units capable of cooling as some maintain there is. However pd rules don't apply if used for cooling, which is a separate consideration to the grant. Link to comment Share on other sites More sharing options...
Beelbeebub Posted Sunday at 09:32 Share Posted Sunday at 09:32 11 hours ago, JamesPa said: Based on your explanation of A2A above I think that excludes A2W but there clearly may be room for debate It would get very technical, how do you define delivery? You could argue the heat is *transported* from point of production to the end point by a vapour but *delivered* as a condensing liquid. The bulk of the energy is delivered as the heat of condensation with a minority delivered by sensible heat of the vapour or liquid phases. But the biggest stumbling block is the general lack of DHW provision. Milliband is talking about removing this restriction. Which might pave the way. Link to comment Share on other sites More sharing options...
Beelbeebub Posted Sunday at 09:33 Share Posted Sunday at 09:33 On a side note, the regs exclude any HP over. 45kw total including shared ground loop systems. This would seem to be an issue for. The Kensa "shoebox" systems or any other shared ground loop systems that might be very useful for blocks of flats etc. Link to comment Share on other sites More sharing options...
joth Posted Sunday at 12:58 Share Posted Sunday at 12:58 15 hours ago, JamesPa said: It would be interesting to understand what the intent was. If it's only to allow a2W why use 'liquid' as opposed to 'water ( which may be treated to prevent corrosion or freezing So my guess... One of the main intents of BUS is to support wide scale training in domestic HP installation, hence the instance on MCS and encouraging profit taking by those with said training. Domestic plumbing is seen as a wet plumbing not F-Gas skill set and so they want people to cross train into the skills that are typically needed to maintain these things going forward Link to comment Share on other sites More sharing options...
Beelbeebub Posted Sunday at 14:00 Share Posted Sunday at 14:00 54 minutes ago, joth said: So my guess... One of the main intents of BUS is to support wide scale training in domestic HP installation, hence the instance on MCS and encouraging profit taking by those with said training. Domestic plumbing is seen as a wet plumbing not F-Gas skill set and so they want people to cross train into the skills that are typically needed to maintain these things going forward A reasonable point. But the skillset to install. A2A (basically fgas certification) would also be encouraged by subsidising a2a. The skillset to install any HP (vs gas boilers) is basically in the specification. There isn't anything in installing a HP that a gas safe engineer can't already do. The only tricky bits are getting the system design and sizing right in the first place. With a2a the issue is fgas - and there are good reasons for not letting any old sod loose given the higher gwp of the gasses. R290 gets around that issue but does introduce the flammability issue - but that isn't significantly different from gas safe issues. 1 Link to comment Share on other sites More sharing options...
Stones Posted 19 hours ago Share Posted 19 hours ago I've been reading the comments with interest. So the original question, Are we targeting ASHP's at the wrong market? I think the answer is an undoubted yes. Or you could say right market, wrong product. For political expediency, ASHP's are being touted as a boiler replacement. But for the vast majority of existing homes they are not, due to the other work required to allow them to operate optimally / at comparable running cost to gas. If ASHP's were capable of delivering a CoP of 3.5 - 4 with flow temps of 55C - 60C, they would be. Until there is no need or requirement to significantly upgrade the heat distribution system, and for the most part I'm referring to radiators and associated pipework, the public are not going to bite. Improving insulation / airtightness for such housing stock is a red herring, useful in reducing energy use, but is not going to get most homes down to the point where they do not require heating. Take a mid 90's house (that I happen to know well) with an oil boiler and radiators. If the owners wanted to fit an ASHP, they would need to replace all their radiators with 3 to 4 times larger in terms of btu heating capacity (up to twice the physical size if they could accommodate double radiators) to achieve comparable running costs. Carpets would have to come up, to get to floor hatches, all the microbore pipe to the radiators would need stripped out and replaced with 15 - 22mm pipework. Time, disruption, and significant cost if they could even get anyone to do the work. And what would they get out of it - a warm fuzzy glow that they had reduced their carbon emissions? Looked at objectively then, why would anyone put themselves through all that? You want change, it needs to be straight forward, meet peoples needs and be affordable. The government needs to move away from ideologically dictating technologies, to setting the framework for the reduction of emissions / reducing the use of FF. Let the market develop and implement the solution. Link to comment Share on other sites More sharing options...
PhilT Posted 18 hours ago Share Posted 18 hours ago 23 minutes ago, Stones said: I've been reading the comments with interest. So the original question, Are we targeting ASHP's at the wrong market? I think the answer is an undoubted yes. Or you could say right market, wrong product. For political expediency, ASHP's are being touted as a boiler replacement. But for the vast majority of existing homes they are not, due to the other work required to allow them to operate optimally / at comparable running cost to gas. If ASHP's were capable of delivering a CoP of 3.5 - 4 with flow temps of 55C - 60C, they would be. Until there is no need or requirement to significantly upgrade the heat distribution system, and for the most part I'm referring to radiators and associated pipework, the public are not going to bite. Improving insulation / airtightness for such housing stock is a red herring, useful in reducing energy use, but is not going to get most homes down to the point where they do not require heating. Take a mid 90's house (that I happen to know well) with an oil boiler and radiators. If the owners wanted to fit an ASHP, they would need to replace all their radiators with 3 to 4 times larger in terms of btu heating capacity (up to twice the physical size if they could accommodate double radiators) to achieve comparable running costs. Carpets would have to come up, to get to floor hatches, all the microbore pipe to the radiators would need stripped out and replaced with 15 - 22mm pipework. Time, disruption, and significant cost if they could even get anyone to do the work. And what would they get out of it - a warm fuzzy glow that they had reduced their carbon emissions? Looked at objectively then, why would anyone put themselves through all that? You want change, it needs to be straight forward, meet peoples needs and be affordable. The government needs to move away from ideologically dictating technologies, to setting the framework for the reduction of emissions / reducing the use of FF. Let the market develop and implement the solution. Agreed where we are talking about replacing a perfectly good boiler system. But if it's 30+ years old like mine was, and needs a major upgrade anyway, the net cost to me of a new ASHP, DHW tank and bigger rads was no different to a modern upgraded boiler system. That financial equation of course varies enormously from the cheapest (possibly one of the utility companies like Octopus) to the most expensive (premium expert installers such as Heat Geek) Link to comment Share on other sites More sharing options...
MrPotts Posted 18 hours ago Share Posted 18 hours ago Most people won’t replace a working boiler so the only time that anyone would vaguely consider a HP is during a breakdown but who wants to wait 3+ months for heating to be restored when a new boiler can be installed in days. Surely a better solution is to reduce the price of electricity (BUS grant can be used here) to be the same as gas and install electric heating either by boiler, in place where the old gas boiler was, or panel radiators. By 2030 all our electricity will be provided from renewables anyway, according to Ed, so the subsidy won’t be for long. 😀 Link to comment Share on other sites More sharing options...
S2D2 Posted 17 hours ago Share Posted 17 hours ago 1 hour ago, MrPotts said: Most people won’t replace a working boiler so the only time that anyone would vaguely consider a HP is during a breakdown but who wants to wait 3+ months for heating to be restored when a new boiler can be installed in days. Surely a better solution is to reduce the price of electricity (BUS grant can be used here) to be the same as gas and install electric heating either by boiler, in place where the old gas boiler was, or panel radiators. By 2030 all our electricity will be provided from renewables anyway, according to Ed, so the subsidy won’t be for long. 😀 I replaced a working 11 year old boiler to avoid this issue, waiting for it to break results in only one realistic outcome, a new combi goes in. 2 Link to comment Share on other sites More sharing options...
ProDave Posted 16 hours ago Author Share Posted 16 hours ago 2 hours ago, MrPotts said: By 2030 all our electricity will be provided from renewables anyway, according to Ed, so the subsidy won’t be for long. 😀 I sprayed my coffee all over my laptop when I read that. Made my day. Great sense of humour. 1 Link to comment Share on other sites More sharing options...
marshian Posted 15 hours ago Share Posted 15 hours ago (edited) 1 hour ago, S2D2 said: I replaced a working 11 year old boiler to avoid this issue, waiting for it to break results in only one realistic outcome, a new combi goes in. In my case it was 13 years but same reason - didn’t want it to be a distress purchase - knew what I wanted and how I wanted it set up and saw no point waiting any longer Edited 15 hours ago by marshian Typo 2 Link to comment Share on other sites More sharing options...
marshian Posted 12 hours ago Share Posted 12 hours ago 5 hours ago, Stones said: For political expediency, ASHP's are being touted as a boiler replacement. But for the vast majority of existing homes they are not, due to the other work required to allow them to operate optimally / at comparable running cost to gas. If ASHP's were capable of delivering a CoP of 3.5 - 4 with flow temps of 55C - 60C, they would be. Until there is no need or requirement to significantly upgrade the heat distribution system, and for the most part I'm referring to radiators and associated pipework, the public are not going to bite. In the interest of discussion I'm going to disagree UK has always lagged behind other countries - The mandating of condensing boilers was done without also mandating how to ensure they condense for all of their operating time - for many replacements they were left on virtually the same settings as the previous non condensing boilers - huge opportunity missed IMO Had I been informed that lowering flow temps would have gained me 7 % efficiency gain the rad changes I have made in the last 3 years would have been done 13 years ago As a result we also missed on getting houses ready for ASHP with lower flow temps which is why you state that ASHP with 55 - 60 deg flow temps and a cop of 3.5 to 4.0 would result in far more conversions but those flow temps and COP is not possible with the current ASHP hardware. 5 hours ago, Stones said: Take a mid 90's house (that I happen to know well) with an oil boiler and radiators. If the owners wanted to fit an ASHP, they would need to replace all their radiators with 3 to 4 times larger in terms of btu heating capacity (up to twice the physical size if they could accommodate double radiators) to achieve comparable running costs. Carpets would have to come up, to get to floor hatches, all the microbore pipe to the radiators would need stripped out and replaced with 15 - 22mm pipework. Time, disruption, and significant cost if they could even get anyone to do the work. And what would they get out of it - a warm fuzzy glow that they had reduced their carbon emissions? Looked at objectively then, why would anyone put themselves through all that? I upgraded all my T11 rads to T22 of the same overall dimensions - in terms of output at same temp that's 1.4 times bigger (@T50) - you don't even notice they are bigger - That enabled me to go from a ~60 deg flow to a ~30 deg flow - I am on 22mm circuit with 15mm from circuit to rad but even microbore would would flow enough l/min to ensure the rads were warm enough to heat the house Total spend on rad upgrades was far less than the cost of a boiler change 5 hours ago, Stones said: You want change, it needs to be straight forward, meet peoples needs and be affordable. The government needs to move away from ideologically dictating technologies, to setting the framework for the reduction of emissions / reducing the use of FF. Let the market develop and implement the solution. On this point I agree but I don't trust the government to run a bath let alone set a framework for reducing the use of FF 1 Link to comment Share on other sites More sharing options...
