December 25, 20241 yr Author 2 hours ago, crispy_wafer said: can recommend the the blue bosch expert drill bits, brilliant! saves having to climb up and down ladders to fetch or carry 2 drills, especially when metal and masonry is involved. Nice. They don’t do a 4.8mm bit though. although what’s confusing the Tek screws I have are DeWalt and say they need a 4.8mm bit but DeWalt don’t make a 4.8mm masonry drill bit that I can find.
December 25, 20241 yr Are you sure it is an sds bit? They rattle about, deliberately, as a cross between drill and breaker and I'm not sure they drill precisely enough for this purpose. The screw has to cut itself into the concrete. Might be wrong.
December 25, 20241 yr 3 minutes ago, saveasteading said: Are you sure it is an sds bit? I am not sure the OP is using an SDS drill but the one stove is SDS. I have used SDS drills fir concrete screws to good effect in the past (but at 8mm for mine). your as bad as me, 11.30pm Christmas Day 🤷♂️ what are we like.
December 26, 20241 yr Author 9 hours ago, joe90 said: SDS ? https://www.fixfast.com/sds-4-8#length=6891 Yeah I saw that. It’s not that I can’t find a 4.8mm bit I just think it’s weird that DeWalt make Tek screws that require a drill bit they don’t produce!
December 26, 20241 yr If you are fixing into blocks you won’t need hammer on the drill, I’d be tempted to just try an hss bit somewhere, or just get an sds bit and stick that in the Chuck of your normal drill, an sds machine might just be a bit brutal. Edited December 26, 20241 yr by crispy_wafer
December 26, 20241 yr I'd opine that a masonry bit won't drill accurately enough that you'll see a difference between 4.8 and 5mm. And certainly with the blocks we get round here, you *will* need hammer...
December 26, 20241 yr Author 32 minutes ago, dpmiller said: I'd opine that a masonry bit won't drill accurately enough that you'll see a difference between 4.8 and 5mm. And certainly with the blocks we get round here, you *will* need hammer... I'm planning on asking DeWalt technical support what drill bit they recommend. I can't believe they'd recommend something they don't make themselves!
December 26, 20241 yr @Thorfun your over thinking this, DeWalt don’t know what substrate your drilling into and as said above different materials re act in different ways, is your drill SDS? Is it blocks or poured concrete your drilling into.? there is a view above that SDS does not drill accurate holes (that I have not exieriehced) so buy a 5.5,, drill and try it, if too tight then get a 6mm (or buy both fir the few quid they cost 🤷♂️)
December 26, 20241 yr Author 15 minutes ago, joe90 said: @Thorfun your over thinking this, DeWalt don’t know what substrate your drilling into and as said above different materials re act in different ways, is your drill SDS? Is it blocks or poured concrete your drilling into.? there is a view above that SDS does not drill accurate holes (that I have not exieriehced) so buy a 5.5,, drill and try it, if too tight then get a 6mm (or buy both fir the few quid they cost 🤷♂️) overthinking is what I do best! 🤣 I'm fixing in to concrete blocks that form a block and beam ceiling. I have an SDS drill but also a standard chuck hammer drill too so either is possible. I think 5.5 is too big. I have loads of spare blocks I can test on and can start with 5mm and see where that takes me. I know DeWalt might not know but I'm really confused as to why they say a 4.8mm bit when they don't offer one. it's not like DeWalt at all! normally a manufacturer will only recommend their own products so they can sell more stuff. and yes I am a cynical b*****d. Edited December 26, 20241 yr by Thorfun
December 26, 20241 yr 26 minutes ago, Thorfun said: think 5.5 is too big. Sorry I meant 4.8 (git confused with my own comment on red rawlplugs !!!). Great idea to do tests and what works best for what you have. 👍 personally I hate normal hammer drills, SDS does such a better job IMO.
December 27, 20241 yr Author first experiment underway. 5mm SDS bill. it seems pretty darn solid but will see how long it lasts.
December 27, 20241 yr 34 minutes ago, Thorfun said: first experiment underway. Brilliant, how tight did the screw feel putting it In?
December 27, 20241 yr Author Just now, joe90 said: Brilliant, how tight did the screw feel putting it In? yeah. pretty tight. I'm sure it'll be fine and the final load on each screw for the ceiling won't be as much as a concrete block pulling straight down as the load is spread across the whole ceiling and all the screws. so maybe for the sake of a few screws I reduce it to a 600mm x 600mm grid and that will then be completely over the top for fixings and reduce the load per fixing as well.
December 27, 20241 yr 1 hour ago, Thorfun said: first experiment underway. 5mm SDS bill. it seems pretty darn solid but will see how long it lasts. This tread has been some of the best alternative Christmas entertainment. Needs a good cliff hanger for New Year’s Eve. Edited December 27, 20241 yr by Nick Laslett
December 27, 20241 yr 18 minutes ago, Nick Laslett said: This tread has been some of the best alternative Christmas entertainment. Needs a good cliff hanger for New Year’s Eve. A smashed ceiling on the floor perhaps ?
December 27, 20241 yr 13 minutes ago, Nick Laslett said: Needs a good cliff hanger for New Year’s Eve. With a soppy sentimental story on the side. My great Aunt Gertrude rescued me from the slums. Her greatest wish was that some day I would fix a ceiling grid using self tapping screws into concrete. This is in her memory. But will I manage it?. Music "Dih dih daaaah! Fortunately a helpful group of blog members hear of this and offer advice.
December 30, 20241 yr Author so experiment number 1 is a success as far as i can tell. it's not budged a mm and has been hanging with that weight for 72hrs. so i think i will be fine using the 5mm SDS bit. But, because i'm not a cowboy like @Pocster, i have ordered a 4.8mm bit anyway. will be interesting to see if i can "feel" any difference when fixing the screw.
December 30, 20241 yr 3 hours ago, Thorfun said: But, because i'm not a cowboy like @Pocster, i have ordered a 4.8mm bit anyway. Yeah yeah . Don’t forget the photo of your ceiling ….. on the floor 😊
January 11, 20251 yr Author @nod looking for a bit of advice please. when extending the MF7 primary channel on the MF ceiling BG says to do it like this. so the pieces are back to back. but this causes an issue for me as I've already attached the hangers to the ceiling in a nice straight line and so the hanger is now on the wrong side to attach to the MF7! e.g. do you move the hanger so it's on the other side (a pain as I've already hung them) or can I put 2 pieces of MF7 the same way around butted up to each other and use another piece of MF7 on the other side to joint the two pieces together? obviously adhering to the 150mm overlap so the joining piece is 300mm long. hope that makes sense!
January 11, 20251 yr 5 minutes ago, Thorfun said: can I put 2 pieces of MF7 the same way around butted up to each other and use another piece of MF7 on the other side to joint the two pieces together? obviously adhering to the 150mm overlap What I did, now curious to see @nod response what I did do, was make any joints so they all didn’t appear in a line so on one row of mf7 the join would be near one wall, and the next row, the mf7 join would be near t’ other wall Edited January 11, 20251 yr by crispy_wafer
January 11, 20251 yr Author 2 hours ago, crispy_wafer said: What I did, now curious to see @nod response what I did do, was make any joints so they all didn’t appear in a line so on one row of mf7 the join would be near one wall, and the next row, the mf7 join would be near t’ other wall Has your ceiling fallen down yet? If not then that’s good enough for me! 😂
January 11, 20251 yr 2 hours ago, Thorfun said: @nod looking for a bit of advice please. when extending the MF7 primary channel on the MF ceiling BG says to do it like this. so the pieces are back to back. but this causes an issue for me as I've already attached the hangers to the ceiling in a nice straight line and so the hanger is now on the wrong side to attach to the MF7! e.g. do you move the hanger so it's on the other side (a pain as I've already hung them) or can I put 2 pieces of MF7 the same way around butted up to each other and use another piece of MF7 on the other side to joint the two pieces together? obviously adhering to the 150mm overlap so the joining piece is 300mm long. hope that makes sense! Just an observation to the picture The joint is wrong The pieces should butt together Both facing the same way with a 300 piec clipped over with eight pan heads holding it in place The hanger can be fixed directly to the joint 3.6
January 11, 20251 yr When using mf Don’t forget to buy a couple of welding clamps Clamp all metal to metal
