28 minutes ago, JohnMo said:
Up to you really. I didn't even think about cooling until after the first year in the house. So my floor is designed around 18W/m².
Floor surface is a property of flow temperature, pipe spacing, insulation below UFH and depth from surface. My floor runs at 18 to 19 depending on solar gain. The more solar I get the harder the ASHP works and cycle time increases from 10 to 12 minutes to a few hours. This brings down mean flow temperature, hence the difference in surface temperature.
Surface covering makes a big difference, carpets kill cooling.
I think the challenge on here is that there are those in the reverse ASHP camp and those in the separate AC camp. I don’t think there’s anyone that’s had both and can say which is more optimal, comfortable etc.
I think the neatest idea is running heat pump in reverse (it’s there anyway) but the added complexity of dew points, lagging
etc makes this more risky than AC. That’s where I am at moment. AC = guaranteed cooling, no risk. But more expense.
Dew point is nothing complicated, people would have you believe there is, for some reason. House at 22 the dew point is around 12 degs. Keep above that the dew point issue isn't there. You don't need to lag pipes any more than you do for heating.
I would do A2A or A2W not both. Both can do heat and cool. Make you choice and move forward. You could look at Panasonic squares loop system also.
Things I like with UFH
No noise, everything is hidden, silent. One switch to go from heat to cool.
Thing I didn't like with A2A, drafts, but liked the coolness in the house. But got to a point where we switched the Aircon off and just slept with windows open (34 degs and 100% humidity) because the drafts just bugged us and made us feel dry.
We went with A2A with electric DHW. We reused warm air ducting in main part of house with a ducted unit and Split wall mounted units in extension.
This is much simpler setup and free cooling in summer with solar panels. Didn’t notice the hot days. If there is no UFH requirements then this is simpler solution. In winter heating is very quick and provides room level control.
Do the units natively support switching from heat to cooling or is it work to ‘put the heat pump in cooling mode’?
by my estimation it’d be around 4k for the fan coil units needed for cooling with ASHP versus significantly more (10k+) for a2a system.
Extra installation costs for sure but when running it’s very efficient when just maintaining a room temperature
This is going to differ depending on manufacturer. Some will make it easy and some will make it hard. Choose a system that supports everything out of the box and you will have minimum problems. Assuming you plan to use an installer, find one who can sell the complete system. Now the planning restriction on heatpumps that cool has been lifted it should be easier to find.
When I looked for a system for my current place (before BUS existed) Panasonic seemed to be the goto for this. Ended up staying with gas as getting permission to put a heatpump in a flat (especially back then) was too difficult.
With a ducted system there is minimal drafts that we can feel.
but I agree with the wall units. Careful placement is required so you’re not sitting in the draft.
one regret I have is not having the money for ducted system downstairs and having to have wall units instead. But something had to give as money runs out quickly!
Some ASHP do not support cooling at all, some require a few bell and whistles (cost adders), other do it out the box. To switch between heat or cool is generally a volt free input. I just use an spare light switch, that's it. DHW continues to work as normal in either heat or cooling mode.
38 minutes ago, JohnMo said:
Some ASHP do not support cooling at all, some require a few bell and whistles (cost adders), other do it out the box. To switch between heat or cool is generally a volt free input. I just use a spare light switch, that's it. DHW continues to work as normal in either heat or cooling mode.
So if you switch the pump into cool mode but then the DHW falls for heat it reverts back to heat mode (and then back again to cool mode when water is heated)?
I have done both, and shared some views here earlier today
TLDR separate AC is lower hassle if getting someone else to do it. All in one ashp is neater and probably cheaper, but you need to be even more the ball managing or DIY installing it
Yep, just like below, centre is DHW heating, the blue sections either side are cooling. As soon as there is a DHW call the heat pump swops duty from cool to heat, the diverter valve moves to direct hot water to the cylinder, once complete it all reverts to cooling again.
Screenshot_2025-07-16-22-14-31-29_40deb401b9ffe8e1df2f1cc5ba480b12.thumb.jpg.e79db812f9c07852974475af32355ce3.jpg
Thanks @JohnMo I didn’t realise it was that automated. That’s interesting. I got chat gpt to model my cooling requirements during summer and it spat out this graph taking in my heat loss and cooling data along with this description of how it generated it. It still has a peak of around 13.4kW.
🔍 The whole-house 24-hour cooling load profile I plotted is
not based on full peak (worst-case) loads
Instead, it is based on:
A synthetic sinusoidal profile interpolated between average and peak cooling loads
– using column W (Average Load) as the baseline
– and column AD (Peak Load) as the afternoon high
📈 What does that mean?
At 4:00 AM, each room is assumed to demand only its average load (e.g., from internal gains or mild solar).
By 15:00, each room is assumed to hit its peak load (from full solar and ventilation gains).
The curve is room-by-room, then summed.
Has the above assumed you leave all your blinds up and just let your room flood with heat. If so that's a flaw in the maths.  Also taking some basic things, if your windows are facing south and have no shading, the solar gain doesn't start until you get sun through the window, so late morning onwards. Your peak load is at 9am. So would say your windows are facing east, is that correct?
At 9am even on a hot day, it's still cool outside, so open the windows and doors have a blow through, as day starts to get warmer than inside close everything up. Let your cooling, whatever you choose do what it does.
AI is great but you need to add a dose of common sense, or you are down a rabbit hole, shite in, yshite out.
Good point. It made a mistake and I’ve time shifted it now. But it does still make me think… it’s pretty hard to model correctly the cooling load.
What size outdoor unit do you have @Thorfun?
Very true.
But in reality, for many properties, there are only a few days in the year that cooling is needed, providing you are sensible with curtains and windows, and only a few rooms are likely to be affected.  Most people are more tolerant of over temperature than under temperature, so the precise control we are used to for heating isn't always necessary for cooling and its unlikely to be necessary to cool to the 20C most heat to.
For example my (200sq m, 7kW heating load, 1930s) house faces south and there is a large patio door in the room we spend most time in.   I have one fancoil in that room (in an otherwise all radiator system) and it makes sufficient difference (with the heat pump run above dew point) to get from horribly hot to pleasantly warm.  The only other room where there is a material problem is the master bedroom, which has an oversized type 33 static rad that I plan to add a bunch of computer fans to in order to hopefully get some cooling (Andre Kuhne on openenergy monitor did exactly that and got a 4C room temp reduction, which is a worthwhile difference).   I do wish I'd put in a couple more fancoils (TBH I didn't realise how good they can be) but I can live without.
For me at least it's simply not worth spending the money to get more sophisticated given the few days it's necessary.
Obviously it's very house and person dependent and the frequency of hot days may well increase, but I for me at least it doesn't merit a whole separate system.  If I were building from scratch I'd just do UFH and/or fancoils and keep above dewpoint.  Perhaps I'm just mean?
Edited by JamesPa
yes the panasonic ones do, we leave ours set at 21 in the winter they heat in the summer they cool, the heat pump decides.  It's all automatic for the fancoils.
Edited by Dave Jones
