Can anyone help with finding a microwave to fit in this Howdens space?
Dimensions are cabinet 590x455 internal and the existing Lamona unit is 480x255.
As you can see there is a snap on trim.
Can't source the doors anywhere, glendevon oak, discontinued. Ditto Lamona ovens...?
Can't help other than to say I hate "built in" microwaves because they are all just a bodge fitting of a free standing MW and a surround trim.
Why does nobody make a proper built in microwave, built to standard built in oven dimensions to be built in properly?
We have full size fitted neff microwave in our kitchen, approx those dimensions, does not have rotating centre though only slatted shelf
Edited by Jml
It's not the one with the black sides, but here is a stainless steel Lamona trim
http://www.ebay.co.uk/itm/Integrated-Microwave-Frame-Kit-Lamona-/142519546723
As an aside to @ProDave's question, Siemens now do full size ovens with a built in microwave, we have gone for two of these rather than a full size oven and smaller microwave.
They aren't cheap though! Luckily our kitchen supplier had some of last year's model at a much lower price.
http://www.cameokitchens.co.uk/product.php/21774/siemens_hm678g4s6b
Edited by AliG
@ProDave  Gaggenau do build in Microwaves the BM450/480 series and the MBP 250 series, though they are horrendously expensive as i know as we are having Gaggenau ovens, only people who do side opening!
@Tennentslager
I think this should be relatively straightforward, but there needs to be a little careful research.
I think that 590x455 is a standard (plus or minus a few mm) size - my built in microwave with a warming draw beneath is in exactly such a hole. And minor adjustments (say +10mm in height or -5mm each side in width should be allowable for (eg trim the wooden top panel and paint the edge or fix a couple of strips of dark timber down the edges). So
1 - My previous setup was microwave mounted on rail kit on the shelf with cosmetic alu or stainless surround panel. I found one sufficiently the right size to fit the existing panel and even the mounts by taking some measurements and taking the surround panel and a tape measure into my local Curry's and measuring all the freestanding microwaves until I found an acceptable one that fitted closely enough. I might have had to move one mounting rail 10mm but that was about it.
2 - Equally you may find that if you talk to the shop or manufacturer they may well have panels to fit all of their built-in microwaves that match your standard size hole for £10 or £25.
3 - It is quite fruitful putting "built-in microwave 590mm 455mm" into Google.
 4 - Some of the bigger online sites have filters for different values of height and width. eg Appliance World Direct
http://www.appliance-world.co.uk/microwaves?sort=na&perpage=12&price_slider=£68+-+£13439&opt[]=22_3858&opt[]=23_3859
My local superstore does not offer this filter but just their microwave page suggests at least 2 or 3 close to your requirements from the first page of results.
https://www.appliancesdirect.co.uk/st/integrated-microwave-ovens
So you have several options.
Ferdinand
Edited by Ferdinand
As an alternative, my microwave has now come out onto the worktop, and the hole is being turned into a 600x600 worktop space using a single porcelain mottled-grey big floor tile trimmed on one side.
Seems to work OK, and will have painted MDF liner inserted.
Edited by Ferdinand
Totally misread it, I thought you had somehow lost the trim.
This appears to fit
http://ao.com/product/uim600-newworld-microwave-stainless-steel-26817-50.aspx
Also in order of price, the last one is a Bosch combi which is nice but more expensive.
http://www.cameokitchens.co.uk/product.php/24061/aeg_mbe2658sb
http://www.cameokitchens.co.uk/product.php/24062/aeg_mbe2658sm
http://www.cameokitchens.co.uk/product.php/24059/aeg_mbe2658dm
http://www.cameokitchens.co.uk/product.php/21603/bosch_hbc84h501b
Edited by AliG
Thank you all...sent this all to my sister to let her make a decision, I'll be the one with the screwdriver once the new unit is delivered.
Top helpers you buildhubbers ???
