October 3, 20179 yr On 10/1/2017 at 08:42, SteamyTea said: And we all know that social studies is bollocks If I was a social scientist I might challenge this statement but I would not want to waste space on this social network
October 3, 20179 yr On 9/29/2017 at 18:41, JSHarris said: Before Staples closed down here I went in and bought loads of pencils and sharpies in their sale, and have them liberally scattered around all over the place, along with the free tape measures. My Brother, not well known for his mathematical ability but still wealthier than me has calculated that since the invention of the ball point pen enough have been made to cover the planet in a layer 75mm (3 inches he said) thick but can you find one when you want one. Nope...
October 3, 20179 yr students and lost pencils, my answer is usually, 'keep it behind your ear, or as you have sufficient space, keep it between your ears'
October 3, 20179 yr 1 hour ago, Simplysimon said: or as you have sufficient space, keep it between your ears Similar to the secretary and her lost pencil joke.
October 3, 20179 yr 21 minutes ago, SteamyTea said: Similar to the secretary and her lost pencil joke. Oh go on then...
October 7, 20179 yr Author On 03/10/2017 at 17:06, curlewhouse said: [...] I have a habit of spraying some of my tools with yellow paint - which identifies them as mine, though I do it really so I can find them as I'm hopeless at putting things down and then wasting 10 minutes hunting for them - so bright yellow helps! [...] Great minds think alike. On 03/10/2017 at 17:06, curlewhouse said: [...] then roofers apparently fitted the slates by throwing 1000 aluminium nails in the air in the hope 1 falls into a slate hole - or so it appears from the many hundreds lying around the perimeter of the house now (which as they won't rust will pose a hazard forever unless all found). [...] Ditto, for us but in our case it was screws. (Taken out of the shuttering) The answer to the problem is, in part , solved by using a magnet: a faff, but it took me 10 minutes to rescue a box-full of screws (£7:00)
October 7, 20179 yr Our Rationell windows came screwed to the pallets with a lot of very good torx head screws, some nice brackets, and some sheets of plywood. All got saved and used, why would you not? Then my neighbour had his Rationel windows delivered. The screws were just dropped on the ground. I went and fetched my large magnet. (A variation on skip diving I suppose) I can't abide waste.
October 7, 20179 yr On 03/10/2017 at 21:49, SteamyTea said: Similar to the secretary and her lost pencil joke. Is that the one that's a robot with a built in pencil sharpener?
October 7, 20179 yr 4 hours ago, Lesgrandepotato said: Is that the one that's a robot with a built in pencil sharpener? Aw go on I need a new joke...
October 7, 20179 yr 5 hours ago, Lesgrandepotato said: Is that the one that's a robot with a built in pencil sharpener? I am not sure how that one involves a lost pencil.
