joe90 Posted November 13, 2023 Author Share Posted November 13, 2023 13 minutes ago, Onoff said: Got a picture of the control board connection diagram? It’s dark, will do it in the morning 👍 Link to comment Share on other sites More sharing options...
Onoff Posted November 13, 2023 Share Posted November 13, 2023 This is mine: Link to comment Share on other sites More sharing options...
joe90 Posted November 13, 2023 Author Share Posted November 13, 2023 22 minutes ago, Onoff said: This is mine: I wish mine was that good, the wiring diagram (chinesium) makes no sense, I am yet to wire the sensors and will have to work out what to do. Also mine has no mention of a manual switch to open close the gates which I want in case the remote fails or family/friends visit when I am not here, (front door bell push behind the gate post is what I did on a previous house) I can mechanically disengage the motor with a key tho. Link to comment Share on other sites More sharing options...
Onoff Posted November 13, 2023 Share Posted November 13, 2023 52 minutes ago, joe90 said: I wish mine was that good, the wiring diagram (chinesium) makes no sense, I am yet to wire the sensors and will have to work out what to do. Also mine has no mention of a manual switch to open close the gates which I want in case the remote fails or family/friends visit when I am not here, (front door bell push behind the gate post is what I did on a previous house) I can mechanically disengage the motor with a key tho. 😂 & I thought my Italian stuff was bad! 11, 12 and 13 above go 24vac, negative, +24vdc. Never seen anything like it and it really threw me as it's not clear. Link to comment Share on other sites More sharing options...
LnP Posted November 13, 2023 Share Posted November 13, 2023 Depending on where you bought the kit from, have you thought about discussing this with the supplier? I installed some electric gates and bought the motors and controls from The Electric Gate Shop. I called them a few time with questions and they were very helpful. I have no affiliation btw. Link to comment Share on other sites More sharing options...
joe90 Posted November 13, 2023 Author Share Posted November 13, 2023 25 minutes ago, LnP said: bought the motors and controls from The Electric Gate Shop. Yes I have used them in the past and they were good, no so with the current stuff. I will work it out tho.. Link to comment Share on other sites More sharing options...
dpmiller Posted November 14, 2023 Share Posted November 14, 2023 can you post the diagram and a photo or two of the board,for us to chew on? Link to comment Share on other sites More sharing options...
joe90 Posted November 17, 2023 Author Share Posted November 17, 2023 Great my 5 amp Reed switch works on my bench test bed, now to wire it in the actual gate opener etc. the Reed switch does spark a little on closure but the write up on the Reed says “special rhodium contacts are used to avoid corrosion and wear”. 🤞 Link to comment Share on other sites More sharing options...
Onoff Posted November 17, 2023 Share Posted November 17, 2023 29 minutes ago, joe90 said: Great my 5 amp Reed switch works on my bench test bed, now to wire it in the actual gate opener etc. the Reed switch does spark a little on closure but the write up on the Reed says “special rhodium contacts are used to avoid corrosion and wear”. 🤞 Gems US - reed switch protection.pdf 1 Link to comment Share on other sites More sharing options...
joe90 Posted November 17, 2023 Author Share Posted November 17, 2023 41 minutes ago, Onoff said: Gems US - reed switch protection.pdf 52 kB · 2 downloads @Onoff, Great bit of info, will order bits and get them installed, thanks a lot 👍 Link to comment Share on other sites More sharing options...
Temp Posted November 17, 2023 Share Posted November 17, 2023 If it doesn't work I'd follow @Adrian Walker suggestion and use the reed to switch the power to the coil of a 230V relay. It says the reed should be enclosed so put both in one box. 1 Link to comment Share on other sites More sharing options...
joe90 Posted November 17, 2023 Author Share Posted November 17, 2023 18 minutes ago, Temp said: If it doesn't work I'd follow @Adrian Walker suggestion and use the reed to switch the power to the coil of a 230V relay. It says the reed should be enclosed so put both in one box. Yes that’s my plan B, but the Reed works on the bench and I am going to protect it like @Onoff posted above, the new Reed will be inside the waterproof casing of the motor box. 👍 1 Link to comment Share on other sites More sharing options...
Adrian Walker Posted November 17, 2023 Share Posted November 17, 2023 1 hour ago, joe90 said: @Onoff, Great bit of info, will order bits and get them installed, thanks a lot 👍 Based on that spec sheet it's not rated at 230V and 5A. Link to comment Share on other sites More sharing options...
joe90 Posted November 17, 2023 Author Share Posted November 17, 2023 (edited) 4 minutes ago, Adrian Walker said: Based on that spec sheet it's not rated at 230V and 5A. Specifications Attribute Value Contact Configuration SPST Maximum Switching Current 5A Maximum Switching Power 250W Maximum Switching Voltage 250V ac/dc Contact Resistance 100mΩ Contact Material Rhodium Maximum Release Time 0.2ms Operating Time Including Bounce 3.5ms Length 84mm Edited November 17, 2023 by joe90 Link to comment Share on other sites More sharing options...
joe90 Posted November 17, 2023 Author Share Posted November 17, 2023 From my (limited) knowledge the protection posted by @Onoff is basically a spark quench. 🤷♂️ Link to comment Share on other sites More sharing options...
Adrian Walker Posted November 17, 2023 Share Posted November 17, 2023 12 minutes ago, joe90 said: Specifications Attribute Value Contact Configuration SPST Maximum Switching Current 5A Maximum Switching Power 250W Maximum Switching Voltage 250V ac/dc Contact Resistance 100mΩ Contact Material Rhodium Maximum Release Time 0.2ms Operating Time Including Bounce 3.5ms Length 84mm Apologies, maybe I'm looking at the wrong spec sheet. Link to comment Share on other sites More sharing options...
joe90 Posted November 17, 2023 Author Share Posted November 17, 2023 1 hour ago, Adrian Walker said: Apologies, maybe I'm looking at the wrong spec sheet. I think that was the previous one that blew/welded. 1 Link to comment Share on other sites More sharing options...
Onoff Posted November 17, 2023 Share Posted November 17, 2023 Probably best with anything Chinesium, to work on half the given current rating. 2 Link to comment Share on other sites More sharing options...
joe90 Posted November 23, 2023 Author Share Posted November 23, 2023 Fir fecks sake !!!, got the resistor and capacitor as per @Onoff,s post above (why does nobody sell them singly?) wired it up on my test bench and!!!!” The LED,s pulse about once a second permanently 🤯 it’s as tho the resistor/capacitor is charging and discharging to activate the LED,s with the magnet activating the Reed the LED,s are on as should be. Can any guru out there help? (I think I will stick to woodwork). Link to comment Share on other sites More sharing options...
SteamyTea Posted November 23, 2023 Share Posted November 23, 2023 1 hour ago, joe90 said: Can any guru out there help https://en.wikipedia.org/wiki/RC_time_constant Useful this time of year as people like flashing lights to guide Santa in. Link to comment Share on other sites More sharing options...
joe90 Posted November 23, 2023 Author Share Posted November 23, 2023 Thanks Nick but that does not help me find a solution to my problem 🤷♂️ Link to comment Share on other sites More sharing options...
dpmiller Posted November 23, 2023 Share Posted November 23, 2023 the LED driver is slowly charging up until it fires. A suitable resistance in parallel with the driver should stop it, but this is one of the many issues with switch-mode power supplies. A different brand of driver may perform differently too... Link to comment Share on other sites More sharing options...
joe90 Posted November 23, 2023 Author Share Posted November 23, 2023 15 minutes ago, dpmiller said: A suitable resistance in parallel with the driver should stop it, Any guesses what value, hopefully 100ohm 1/4 watt (as I could only buy 10 at a time for the one I required 🤣) Link to comment Share on other sites More sharing options...
ProDave Posted November 23, 2023 Share Posted November 23, 2023 No, 100 ohm connected to 240V is (V2/R) is 576 watts, apart from wasting a great deal of power, your 1/4W resistor would last milliseconds and end in a big flash. 100K Ohm would be about 1/4W but without trying it you would not know if it would quench enough. 1 Link to comment Share on other sites More sharing options...
dpmiller Posted November 23, 2023 Share Posted November 23, 2023 yep a couple of hundred K would be worth a try, it's what we would fit across a starting capacitor to ensure it discharges. Or an old-fashioned pygmy 15W filament bulb? 1 Link to comment Share on other sites More sharing options...
