Vijay Posted August 15, 2017 Posted August 15, 2017 I'm just digging for the drainage and I think I can just about get away with a 1:40 fall everywhere. While reading something about drainage, it says that any drainage that has W.C's attached should be a 1:80 fall. Is that strictly true? Cheers Vijay
Onoff Posted August 15, 2017 Posted August 15, 2017 A bit here on the old forum: http://www.ebuild.co.uk/topic/3629-fall-of-sewage-pipe/
Vijay Posted August 15, 2017 Author Posted August 15, 2017 Thank you. Looks like 1:40 will be fine for 100mm pipe
PeterW Posted August 15, 2017 Posted August 15, 2017 I'd go 1:80 unless you really need the drop with 1:40.
Vijay Posted August 15, 2017 Author Posted August 15, 2017 I've just about got 1:40 (with a bit of work), so I'd really struggle to get 1:80 without core drilling a hole through foundations................
RichS Posted August 16, 2017 Posted August 16, 2017 (edited) 10 hours ago, Vijay said: I've just about got 1:40 (with a bit of work), so I'd really struggle to get 1:80 without core drilling a hole through foundations................ Vijay, I think you've got this the wrong way round. If you've got 1:40 then 1:80 is already available, i.e. a lot less fall. If you overdo the fall then the liquids disappear too quickly and leave the solids sat in the pipe, that's why @PeterW suggests 1:80 Edited August 16, 2017 by RichS
ProDave Posted August 16, 2017 Posted August 16, 2017 I thought the issue with 1:80 was it is the absolute minimum allowed, so you have to be really careful that nothing happens to allow a bit of pipe to sag. Some say when doing 1:80 under the ground you should concrete it in for that reason. If you have enough room I would go as close to 1:40 as you can. It's not one or the other, it's anywhere in between. 2
CC45 Posted August 16, 2017 Posted August 16, 2017 BC was happy for me to use 1:80 but only with 150mm pipe & concrete. I stuck to 1:40.
PeterW Posted August 16, 2017 Posted August 16, 2017 1:80 shouldn't sag if it's packed properly and bedded - it does if you don't support it in situations such as internal soil pipes. Polypropylene pipe sags worse than uPVC as it has a slightly lower melting temperature.
Nickfromwales Posted August 16, 2017 Posted August 16, 2017 19 minutes ago, PeterW said: 1:80 shouldn't sag if it's packed properly and bedded - it does if you don't support it in situations such as internal soil pipes. Polypropylene pipe sags worse than uPVC as it has a slightly lower melting temperature. A bit close to the wind though, and allows little for error?
Vijay Posted August 17, 2017 Author Posted August 17, 2017 (edited) On 16/08/2017 at 08:15, RichS said: Vijay, I think you've got this the wrong way round. If you've got 1:40 then 1:80 is already available, i.e. a lot less fall. If you overdo the fall then the liquids disappear too quickly and leave the solids sat in the pipe, that's why @PeterW suggests 1:80 Not if the foundations and manholes fitted by the developer are are already in place - I would need to drop the foundation or raise the manhole Edited August 17, 2017 by Vijay
Vijay Posted August 17, 2017 Author Posted August 17, 2017 How should any pipework running under the B&B floor (and on top of the cleared ground) be supported? Do I just use a concrete slab under the rest bends or do I bed any pipework and restbend in concrete?
Nickfromwales Posted August 17, 2017 Posted August 17, 2017 If the ground is not great, use a flagstone as a pad, then wet concrete pads on those to actually hold the pipe. Come 1/2 way up the pipe, no need for more than they afaik. Just make sure it's benched either side so it can't move. Get a laser and work out the fall over the distance. That'll tell you your fall.
Vijay Posted August 17, 2017 Author Posted August 17, 2017 (edited) Cheers Nick. How often should a pipe run be supported to stop sag? Edited August 17, 2017 by Vijay
Nickfromwales Posted August 17, 2017 Posted August 17, 2017 Id say every 900mm, but there should be a regs standard for horizontal soil pipe runs.
Oz07 Posted August 17, 2017 Posted August 17, 2017 Isn't the whole point of b&b that the ground inside can move and heave? I've never been a fan of long runs underneath beams for this reason. I think it would be preferable to dig a trench filled with pea gravel allowing a big of movement without upsetting the falls.
Vijay Posted August 17, 2017 Author Posted August 17, 2017 2 hours ago, Oz07 said: Isn't the whole point of b&b that the ground inside can move and heave? I've never been a fan of long runs underneath beams for this reason. I think it would be preferable to dig a trench filled with pea gravel allowing a big of movement without upsetting the falls. Can't do that as the foundations are in and the pipes are to be ontop
TerryE Posted August 17, 2017 Posted August 17, 2017 On 16/08/2017 at 08:29, ProDave said: I thought the issue with 1:80 was it is the absolute minimum allowed, so you have to be really careful that nothing happens to allow a bit of pipe to sag. Shit sticks.
