revelation Posted December 29, 2022 Author Share Posted December 29, 2022 3 minutes ago, JohnMo said: Our bath has been used once in the last year, I wouldn't bother. Plenty of other stuff to get on with. Mine will be used 3-5 times per week. Link to comment Share on other sites More sharing options...
JohnMo Posted December 29, 2022 Share Posted December 29, 2022 Just now, revelation said: Mine will be used 3-5 times per week Still wouldn't bother Link to comment Share on other sites More sharing options...
revelation Posted December 29, 2022 Author Share Posted December 29, 2022 10 hours ago, twice round the block said: If you get any form of leak, in the sealant or pipework, blockage in the trap your in for a whole load of grief if the area is pumped full of that stuff. I was planning to foam the bath before fitting so, not directly over pipes or fittings Link to comment Share on other sites More sharing options...
joe90 Posted December 30, 2022 Share Posted December 30, 2022 (edited) 14 hours ago, revelation said: I was planning to foam the bath before fitting so, not directly over pipes or fittings Then what harm can it do 🤷♂️ Worth a try then you can report back here with your findings, can’t do any harm. Edited December 30, 2022 by joe90 Link to comment Share on other sites More sharing options...
SteamyTea Posted December 30, 2022 Share Posted December 30, 2022 18 hours ago, TerryE said: Great minds ... Jan thinks I am mad, but tolerates this one. If I leave the bath full of water to cool, I get a damp house, unless I keep the extractor on, which defeats the object. Having MVHR would help. A cubic metre of water costs me about £8. Cost about £6.50 to heat up at night. Short, cold showers are really the answer, not the hot soak in the bath I prefer. I get all the health and wellbeing advantages of cold water swimming from a hot bath. Link to comment Share on other sites More sharing options...
Nickfromwales Posted December 30, 2022 Share Posted December 30, 2022 2 hours ago, SteamyTea said: Short, cold showers are really the answer Not for the rest of the population they're not...... 😜 That's exclusive to you matey. Link to comment Share on other sites More sharing options...
Nickfromwales Posted December 30, 2022 Share Posted December 30, 2022 23 hours ago, Adrian Walker said: Top tip. When you have finished using the bath, don't empty it until the water until it has cooled to room temperature. Takes 3x more scrubbing then, and that uses more hot water... Link to comment Share on other sites More sharing options...
SteamyTea Posted December 30, 2022 Share Posted December 30, 2022 27 minutes ago, Nickfromwales said: That's exclusive to you matey Link to comment Share on other sites More sharing options...
jonM Posted December 30, 2022 Share Posted December 30, 2022 I insulated my steel bath with rockwool. I think it reduces the amount of energy lost heating up the bath tub when running the bath, but once the bath has been run I would imagine that a lot of the heat is lost via surface evaporation and the insulation makes little difference. It is worth doing if you have some insulation left over but I don't think it is a game changer in terms of saving energy. Link to comment Share on other sites More sharing options...
Adrian Walker Posted December 30, 2022 Share Posted December 30, 2022 19 minutes ago, Nickfromwales said: Takes 3x more scrubbing then, and that uses more hot water... If you have soft(end) water that not the case. See the calculation and you will see its a no brainier to get free energy. Link to comment Share on other sites More sharing options...
Nickfromwales Posted December 30, 2022 Share Posted December 30, 2022 2 minutes ago, Adrian Walker said: If you have soft(end) water that not the case. See the calculation and you will see its a no brainier to get free energy. Assuming nothing was shed from your body during the bath ?? eg the reason you got into it in the first place Link to comment Share on other sites More sharing options...
Onoff Posted December 30, 2022 Share Posted December 30, 2022 1 hour ago, Nickfromwales said: Not for the rest of the population they're not...... 😜 That's exclusive to you matey. I think it's in the terms of his release, to keep the urges under control... 1 Link to comment Share on other sites More sharing options...
Nickfromwales Posted December 30, 2022 Share Posted December 30, 2022 33 minutes ago, Onoff said: I think it's in the terms of his release, to keep the urges under control... 🤢🤮 Link to comment Share on other sites More sharing options...
TerryE Posted December 31, 2022 Share Posted December 31, 2022 17 hours ago, SteamyTea said: Short, cold showers are really the answer, not the hot soak in the bath I prefer. Hot showers are far more economical (unless you do them @ToughButterCup style🤣). I am a little anal in my technique: I use about 5-10 ltr for a typical shower: a quick wet down; turn off shower and full body lather and rub down; leave lather on for at least 60 sec whilst flannelling; another wet down; flannel off any water and suds; a final slightly longer wet down, flannel off and towel down. Soap + 60sec contact + mechanical rubbing is better than an immersive soak (or just standing under a deluge shower) for getting rid of detritus, and surface bacteria and fungal spores. That being said, Jan took a tumble a couple of weeks back and she managed to crack a rib and tear some muscle and ligaments. Time is the only remedy for this type of fall. The pre-bedtime bath is better for getting a night's sleep during recovery. 14 hours ago, Nickfromwales said: Takes 3x more scrubbing then, and that uses more hot water... We've got a water softener and there's very little crap sticking the the bath. I find a quick rub down with a cleaning flanel gets it off. 2 Link to comment Share on other sites More sharing options...
SteamyTea Posted December 31, 2022 Share Posted December 31, 2022 (edited) 3 hours ago, TerryE said: little anal flannelling You went to Prep School as well then. I have an irrational phobia with flannels. Actually, not that irrational. Having had to look, and smell, a line of damp, discoloured flannels, that were used every day, by teenage boys, to remove genitalia crud and discharge, I cannot have one in the house. Matron never gave any of us bed baths either. They never mentioned any of this in Tom Brown's School Days, or the Harry Potter books do they. I blame the parents. Edited December 31, 2022 by SteamyTea Link to comment Share on other sites More sharing options...
Onoff Posted December 31, 2022 Share Posted December 31, 2022 4 hours ago, SteamyTea said: You went to Prep School as well then. Did you have the fagging system then? Link to comment Share on other sites More sharing options...
SteamyTea Posted December 31, 2022 Share Posted December 31, 2022 11 minutes ago, Onoff said: Did you have the fagging system then? No, not a prep school. It was worse, it was in Kent. Link to comment Share on other sites More sharing options...
TerryE Posted December 31, 2022 Share Posted December 31, 2022 (edited) The Great War poets are my favourite, though I have read a Larkin anthology decades ago. That's not the High Windows that I remember though the lines are familiar Larkin, so I looked it up: This Be The Verse. And nope, Direct Grant grammar school, then Cambridge, then the Royal Engineers before entering the real world. 🙂 My father similarly had an anathema to the use of face cloths that bordered on a phobia. We just wash ours regularly, say about once a week, and because we have multiple ones, that's probably after ½ doz uses. Yes they do harbour microbiota, but so I don't recommend sucking on one, but the moot issue is whether the stale oil and microbiota burden on the skin is reduced or increased by their use. PS. @revelation sorry for this wandering digression, but this sort of friendly interchange between the regular posters is what makes this a community and keeps us helping everyone. 😉 Edited December 31, 2022 by TerryE Link to comment Share on other sites More sharing options...
Nickfromwales Posted December 31, 2022 Share Posted December 31, 2022 @TerryE Hope Jan has a speedy recovery! 1 Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 2, 2023 Share Posted January 2, 2023 (edited) On 31/12/2022 at 04:15, TerryE said: Hot showers are far more economical (unless you do them @ToughButterCup style🤣). ... I think I'm right in saying that our shower has two flow-rates : 9 litres per minute and 18 per minute (Hansgrohe RainDance ) The higher flow rate shower head delivers a warm and gentle massage for my dilapidated back, and for a more recent insult: a new bit of metal in my hip. A Definition : Old age: where going to the bathroom almost always involves some form of first aid treatment. Edited January 2, 2023 by ToughButterCup Link to comment Share on other sites More sharing options...
SteamyTea Posted January 2, 2023 Share Posted January 2, 2023 23 minutes ago, ToughButterCup said: A Definition : Old age: where going to the bathroom almost always involves some form of first aid treatment And lots of mopping up. Link to comment Share on other sites More sharing options...
Pocster Posted January 2, 2023 Share Posted January 2, 2023 No . That’s the answer to this threads title . Sorted 😎 Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 2, 2023 Share Posted January 2, 2023 5 hours ago, SteamyTea said: And lots of mopping up. Thats why we have wetrooms: no mopping, just sluice it dahn' va plug'ole Link to comment Share on other sites More sharing options...
SteamyTea Posted January 2, 2023 Share Posted January 2, 2023 2 minutes ago, ToughButterCup said: Thats why we have wetrooms: no mopping, just sluice it dahn' va plug'ole Putting my bio-hazard suit on next time I am Up Norf. Link to comment Share on other sites More sharing options...
