July 24, 20179 yr 48 minutes ago, Weegaz said: Thanks Declan, I have been looking at 1000mm x 8" high x 5" wide - £13.00 + VAT (per metre) from a company in Newry. Haven't yet priced around. It will be a two man job, my brother will be helping......whether he likes it or not You will need a kerb lifter for them and a spare back!!! Like every job its all in the preparation that makes it easy. Lifting the kerbs is the quick bit. I have seen a lot of houses using garden edges instead of kerbs. Gives a nice cleaner look than a big chunky kerb for the wife to scrape the car wheels on. Edited July 24, 20179 yr by Declan52
July 25, 20179 yr 16 hours ago, Declan52 said: You will need a kerb lifter for them and a spare back!!! Like every job its all in the preparation that makes it easy. Lifting the kerbs is the quick bit. I have seen a lot of houses using garden edges instead of kerbs. Gives a nice cleaner look than a big chunky kerb for the wife to scrape the car wheels on. Do you mean like a pin kerb Declan?
July 25, 20179 yr 17 hours ago, vfrdave said: Hi @Weegaz good to hear you have moved in how things settling down for you? Those are fairly beefy kerbs, I assume they are granite? Things are good Dave, just getting used to the increase in space mostly. We have the stairs to finish off properly and also looking at the outside works at the minute. yes kerbs are granite I have been looking at but up for other suggestions if anyone has any.
July 25, 20179 yr 2 hours ago, Weegaz said: Do you mean like a pin kerb Declan? Yeah I think they look nice.
August 7, 20179 yr Anyone have any issues getting upc downpipes in the 7016? And more so brackets in that colour? Need brackets that are close to the wall (as no fascia) and trying to avoid an s bend between the gutter and the downpipe. Any help appreciated .
August 7, 20179 yr You could ring Brett Martin in Mallusk http://www.brettmartin.com/en-gb/plumbing-and-drainage/products/rainwater-systems/anthracite-grey.aspx or Down PVC (great to deal with) http://www.downpvc.co.uk/rainwater.html or online try https://www.directplastics.com/guttering-downpipes/anthracite-grey-gutter
August 9, 20179 yr Morning all, how much would you expect to pay for second hand kwikstage scaffolding approx the following:- 40 9'9' standards 50 4'2' transoms 30 8' ledgers 36 8' planks 20 adjustable base jacks Thanks in advance
August 9, 20179 yr 45 minutes ago, vfrdave said: Morning all, how much would you expect to pay for second hand kwikstage scaffolding approx the following:- 40 9'9' standards 50 4'2' transoms 30 8' ledgers 36 8' planks 20 adjustable base jacks Thanks in advance I sold a batch just slightly less than that amount (only 30 boards and only 10 base jacks) for £1100 last year don't forget to get some diagonal braces as well.
August 9, 20179 yr 46 minutes ago, ProDave said: I sold a batch just slightly less than that amount (only 30 boards and only 10 base jacks) for £1100 last year don't forget to get some diagonal braces as well. So £750 would be a good deal if it is in reasonable condition
August 9, 20179 yr 38 minutes ago, vfrdave said: So £750 would be a good deal if it is in reasonable condition I would say so. Check the condition of the boards. When I bought my first lot, I then stored it (badly) for nearly 2 years, then found half my boards were rotten, so I had to buy a whole load more. My "test" was to support both ends of a board on a concrete block so just a few inches off the grounf and then jump up and down on the middle of the board. If it didn't break, I used it. If it did break then it was only a few inches to drop and no harm done.
August 9, 20179 yr BT connection, were any of you charged for site surveys, cabling and ducting? In the past i have heard of people getting this all thrown out for free. Looking at the online new site connections form it is quoting prices for all of these.
August 9, 20179 yr Nope. Bt guy came out and dropped me off the length of cable needed and told me where he wanted it brought to. Came back a few days later and hooked it up.
August 9, 20179 yr 15 minutes ago, Declan52 said: Nope. Bt guy came out and dropped me off the length of cable needed and told me where he wanted it brought to. Came back a few days later and hooked it up. Did BT pull cable for you Declan? Our ducts are in and the 2 rolls of cable are lying in the garage
August 9, 20179 yr No I had to get it to the pole and to the box inside my house. Did you put draw string in the duct??
August 9, 20179 yr We got charged for our BT cable - It was a reasonable long length so that may have had something to do with it.
August 9, 20179 yr 7 hours ago, Weegaz said: Did BT pull cable for you Declan? Our ducts are in and the 2 rolls of cable are lying in the garage Yes, double checked this when the guys where fitting ducts. Will have a go at it one of these weekends. On another note, we have to get our level access to doors for building control. Does anyone know if me putting down sand and a few flags would suffice as a temporary measure as the paving won't be completed properly for at least another 3 months
August 9, 20179 yr I only had about 4 slabs out my front that formed the ramp up to my door with a further 4 at the door at the threshold height to give a flat area and it got passed ok.
September 26, 20179 yr I'm planning to use a Main Contractor and am about to go out to tender. I'll be asking for an elemental breakdown of costs so I can hopefully compare quotes. Have any of you got a good example of an elemental breakdown that you could share with me? Thanks.
September 28, 20179 yr On 26/09/2017 at 13:36, JohnW said: I'm planning to use a Main Contractor and am about to go out to tender. I'll be asking for an elemental breakdown of costs so I can hopefully compare quotes. Have any of you got a good example of an elemental breakdown that you could share with me? Thanks. Hi John, What house type are you building and what is the floor area. I had a QS do an elemental breakdown at the beginning I could send you. In saying that PIR insulation has went throught the roof and is going up again shortly.
September 28, 20179 yr Hi @Ryan85, it's a block build, 200mm fully filled cavity, 2 story house total floor area about 230 sq metres. Thanks for the heads-up on the PIR prices, it seems ALL materials are going up in price. Gives me a feeling that the sooner I get started, the better.
September 28, 20179 yr Good idea to use a QS to compare gender prices. In our experience contractors are unwilling to tender for works which require a detailed breakdown. With demand high for a contractors some won't even look at plans. All our responses included PC sums, some have been estimated ok and others such as electrics and plumbing have gone up. Ours is 2600 sft with a PC sum of 13500 for plumbing UFH and rads upstairs, MHRV but PC sum was revised and is now 15,000. PC sums are way out, budget 20 percentage for increases and unforeseens
September 29, 20179 yr A lot of contractors will take the floor area and multiply that with the general cost/per sq.m. You will need an elemental breakdown for the mortgage company anyway John W so get a QS to do it for you.
October 3, 20179 yr WeeGaz, What 4G Router did you buy and how are you finding it. I still have the Sky broadband that me nor the wife use as the download speed is slower than dial up lol.
