Scaffold Boards - are these ok and safe to use?
Oxbow16
Hi
I bought some new old stock scaffold boards.  I've never had or used scaff boards before so not sure what is acceptable or cause for concern.
One of the boards has a lip along the entire length.  A couple of others have a similar lip but it is a lot less pronounced.  Curious also as to what causes it?  To begin with I thought they must be two separate lengths joined, but on closer inspection that doesn't seem to be the case.  Here's a couple of photos of the worse one:
One of the other boards has a more severe but much short split at one end.  Here's some photos of that one, top middle and underside:
Any thoughts most appreciated.
Many thanks
Great, that'a all encouraging to hear - many thanks.
1 minute ago, Mr Punter said:
My pet hate is when they are twisted so they don't lie flat.
Yep, we've got one of those too!  But he's happy to change that one.
Cheers
28 minutes ago, SteamyTea said:
Can you explain a bit more, intrigued how you get a 15° twist out of a plank with a plainer.
Where does it say 15 degree twist? And depends how long and wide the plank is.
but planers are made to  level and square bows and twists in timbers
When I had doubts, I placed my planks one at a time on the ground supported at each end on a 4" concrete block.  Then i stood in the middle and jumped up and down on it.  If it did not snap or bend excessively, I used it.
