Happy Valley Posted June 26, 2022 Posted June 26, 2022 We are hopefully about 6-8 weeks from moving in and need to choose a supplier for the electrics. No solar panels yet but hopefully in a few years. It will run the usual things plus an 8.5kW ASHP. Question is who to use. I hear a lot about Octupus Energy but not sure if its for us.
ProDave Posted June 26, 2022 Posted June 26, 2022 If you are thinking of Octopus, PM me for a referal code that will get you £50 credit. 1
Thorfun Posted June 27, 2022 Posted June 27, 2022 I’ve recently been trying to find a supplier for our new connection to install a smart meter. I phoned a number of suppliers and their response was that they weren’t taking on new customers due to the state of the energy market. so I would suggest phoning everyone now to find anyone who will install a meter and the switch to your preferred supplier at a later date once you’ve made that decision. 2
Buzz Posted June 27, 2022 Posted June 27, 2022 6 minutes ago, Thorfun said: I’ve recently been trying to find a supplier for our new connection to install a smart meter. I phoned a number of suppliers and their response was that they weren’t taking on new customers due to the state of the energy market. so I would suggest phoning everyone now to find anyone who will install a meter and the switch to your preferred supplier at a later date once you’ve made that decision. I read about this on the forum and started to panic as it was one thing i had not considered that might be an issue , but i found that E-on have no problems fitting new meters in this area , from the first call to instillation of the smart meter was 4 weeks , i will stick with them for now and shop around once we have moved in . 1
PeterW Posted June 27, 2022 Posted June 27, 2022 11 hours ago, Happy Valley said: No solar panels yet but hopefully in a few years. It will run the usual things plus an 8.5kW ASHP. No gas ..? And does the heating work overnight on E7..? Have a look at the Go35 tariff from EDF.
SteamyTea Posted June 29, 2022 Posted June 29, 2022 On 27/06/2022 at 08:10, PeterW said: Have a look at the Go35 tariff from EDF. I just did. https://www.edfenergy.com/sites/default/files/goelectric_ratecard_jul24.pdf Those are painful prices. May be better off on a standard rate. 52p a day to say you can buy in at 4.5p/kWh at night. Then, it will cost you 51p/kWh. They know that an EV can only pull 7.2 kW for a short time before it throttles back. ASHPs are similar. Not often they will run at max power for very long. They usually pull about 5A, 1.3 kW, or so. I think you need to be very careful with these sorts of deals.
joth Posted June 29, 2022 Posted June 29, 2022 Personally, unless you're a real energy optimisation nerd (in which case you'd have done the research and wouldn't be asking on here, LOL), then I'd suggest signing up to a 1 year fixed rate flat rate tariff, measure how much energy you're using over a full season and what your usage/lifestyle patterns are living in it, and only then consider if a cheap rate overnight tariff would be more suitable. E.g. you may be able to to get all your required heat by only running the ASHP during the 4 hour overnight cheap rate on Octopus Go, but you may need to run it at a significantly higher flow rate (thus less efficient) to get sufficient heat delivery in the short time window. So maybe much better off leaving the ASHP on 24/7 at a lower flow rate and not trying to play the TOU juggling game (which let be honest is a lot of effort for a small reward -- well, unless your ASHP has a huge crankcase vampire load and you can power it off completely for 18 hours a day)
SteamyTea Posted June 29, 2022 Posted June 29, 2022 17 minutes ago, joth said: Personally, unless you're a real energy optimisation nerd (in which case you'd have done the research and wouldn't be asking on here, LOL), then I'd suggest signing up to a 1 year fixed rate flat rate tariff, measure how much energy you're using over a full season and what your usage/lifestyle patterns are living in it, and only then consider if a cheap rate overnight tariff would be more suitable Thank you, I am. 6 years at university studying it. It is worth getting, or making, an energy data logger, then analyse what is really happening. It can show you so much. 1
Happy Valley Posted June 29, 2022 Author Posted June 29, 2022 (edited) Well Octopus take 3 months to assist so that's a none starter. British Gas are not taking on new electric only customers. Email sent to EDF - at least their website does not say not taking on new customers Edited June 29, 2022 by Happy Valley
joth Posted June 29, 2022 Posted June 29, 2022 6 hours ago, SteamyTea said: 6 hours ago, joth said: Personally, unless you're a real energy optimisation nerd (in which case you'd have done the research and wouldn't be asking on here, LOL), then I'd suggest signing up to a 1 year fixed rate flat rate tariff, measure how much energy you're using over a full season and what your usage/lifestyle patterns are living in it, and only then consider if a cheap rate overnight tariff would be more suitable Thank you, I am. 6 years at university studying it. LOL we know you are! I was (perhaps ambiguously) addressing the OP. I should have said "unless one is a... [nerd] .."
Bramco Posted June 29, 2022 Posted June 29, 2022 4 hours ago, Happy Valley said: Well Octopus take 3 months to assist so that's a none starter. 2 months ago we had them fit a smart meter in a couple of weeks from initial contact. Maybe depends where you are? Simon
PeterW Posted June 29, 2022 Posted June 29, 2022 11 hours ago, SteamyTea said: I just did. https://www.edfenergy.com/sites/default/files/goelectric_ratecard_jul24.pdf Those are painful prices. Sadly that has changed in the last 48 hours as it was cheaper than that a few days ago - another supplier trying it on !
Happy Valley Posted June 30, 2022 Author Posted June 30, 2022 13 hours ago, Bramco said: 2 months ago we had them fit a smart meter in a couple of weeks from initial contact. Maybe depends where you are? Simon I think it is their way of trying to put you off - many companies do not want new customers at the moment.
bmj1 Posted July 11, 2022 Posted July 11, 2022 On 29/06/2022 at 15:41, Happy Valley said: Well Octopus take 3 months to assist so that's a none starter. British Gas are not taking on new electric only customers. Email sent to EDF - at least their website does not say not taking on new customers Try this link - "UW". They are currently taking on new customers for Energy. I managed to get them to install a 3-phase meter in around 2 weeks (from when I had my service live with them), which I thought was a decent result.
Kelvin Posted July 11, 2022 Posted July 11, 2022 Octopus are a shambles. So much so I’ve emailed ‘call me Greg’. 😂 A month of nonsense to get the supply connected and now 4 months for a meter. They’ve given my £90 in compensation but that doesn’t really help me.
Kelvin Posted August 3, 2022 Posted August 3, 2022 (edited) On 29/06/2022 at 18:28, Bramco said: 2 months ago we had them fit a smart meter in a couple of weeks from initial contact. Maybe depends where you are? Simon I got my supply installed in June and it’s the end of September before they can install the meter. The only reason they took me on is because I already had an account with them. Due to all their screw ups they’ve upped the credit to £150 from £90. Scottish Power are also no longer taking on new customers. It’s ridiculous. Ofgem needs to step in and force them all to do it. If they won’t then the Government needs to do something. You can’t have basic utilities being withheld from people. Edited August 3, 2022 by Kelvin
