We are planning our bungalow conversion, we will be adding a story on top to create a house.
Ideally we wanted a new brick design all over but to keep it within (almost) or budget we are going to have to keep the original building so the best option we have is to render over it but then thinking about having the new top half brick.
The top of the downstairs windows is the height of the current bungalow
What other exterior finishes could we use? We are struggling to find an exterior look we like, we are based in a little village so didn't want to go too modern
I have attached our elevations, would love any input/ideas from any one
With render we externally insulate but then if we bricked the top half would this sit too far back and look a bit daft?
Thanks in advance
Edited by richo106
8 minutes ago, the_r_sole said:
Are you actually converting the bungalow? Or are you going to completely demolish it and rebuild it?
If we had the budget would love to knock it down, I've had several builders who are experienced in house building/renovation  and they say what we are planning is very doable and more cost effective way tp hopefully achieve what want. Obviously we all agree knocking it down is better but budget won't stretch to that. The existing bungalow is structurally very good and good footings.
We just need to over come the issues of insulation and exterior look
the elephant in the room is the VAT, with a conversion like this you're handing a fifth of the cost over to the tax man and inheriting a load of issues with the existing fabric - have you had it costed up as a new build compared to the conversion?
Zero Vat on new build and lower maintenance for years to come, even decades if you design in low maintenance
lower or no heating bills - plenty enough up sides to demolish and start again
Even though we are now living in the bungalow, if we knocked it down and re-used the footings would this be classed as new build. Would I need to change the plans submitted to planning?
When speaking to the builder he said it would considerably more to knock down and rebuild, I believe the footings would need widening also to accommodate the wider wall structures now.
Luckily in the job I work in I can materials at a very good discount so hoping to save there.
Also with claiming the VAT back I don't know if my cash flow could handle claiming it all back at the end
  • 2 weeks later...
Another vote for knock down and rebuild.  you will get a MUCH better house and with the zero VAT no more expensive.  there really is not much you would be saving of the old bungalow.
Then add in the fact the layout will be based on what is there at the moment (or jet more knocking down) which will compromise the finished layout.  Complete new build gives you freedom to design it without compromises.
Get him to commit to a a fixed price contract regardless of what he finds wrong with the old building.
While you're at it throw in that it must meet 1.5 ACH50 or better. That'll make him get down to brass tacks pretty quickly.
Edited by Iceverge
Split the contract and tender it in two sections - one for the demolition and another for the rebuild. Make sure you have all your i’s dotted and t’s crossed and that you have a tight specification and schedule of works and see what the costs are.
