No air getting into the system. Is this straight into an underground waste pipe ..? Flush the loo in the same room and see if it makes it better ...
Underground (block and beam). We also notice occasionally when turning the shower on there is a rattle/vibration coming from loft. It's a ceiling fed Mira showing.
Check the drains outside, my builder had a callback on a house he built last year with a similar problem and it was found to be half a housebrick in a 6 inch drain some 50m from the house. He thought with his plumber it was a faulty AAV but after much head scratching and a cctv survey found the above.
We can't see any obvious issues and all other taps/bath (in same room) seem to be ok.
I occasionally unscrew the handset from our shower hose, (be sure to dig out and put safe the little black rubber washer), then stick the hose down the trap on full whack and at it's hottest setting. The hair trap in our Geberit wall drain can only cope with so much. SWMBO and No.2 daughter moult like Cousin It!
@canalsiderenovation
Hey on the upside you're in now.
Suggest two diagnostic approaches.
1/ Ask everyone .. again, if they have "done something they should not have done" in the shower.."  Explain that you have been on BH and unless they come clean you will find out and make it public... if that fails..(and it probably will as I bet you have already explored this) then option 2.
2/ Buy a plunger, one of the ones that act like a bike pump may be the thing. Get a big drum of warm water (not boiling as you may crack the tray) pour it into the tray to get a head of water say 50m m in the tray. Plunge like your life depends on it.
Report results here.
Thanks
There is only me and the wife and it's our ensuite so straight to option 2 then. We have a normal type plunger so I'll try that later before we buy one of those posh things.
Will also try the suggestion by @Onoff too.
I generally find that hair is the issue in mine. Once a quantity gets stuck and various products such as conditioner etc get trapped in it to make it a greasy mess then the drain stops flowing properly. My solutions are 1. see if there is any hair I can grab and yank out using some industrial tweezers or similar, 2. use one of those air pump things as above (they aren’t very expensive), 3. resort to chemicals. Have only needed 3 a couple of times.
Do you have a hair trap fitted?
TIMESETL Toilet Plunger with 2 Interchangeable Heads, Powerful Manual Drain Buster for Toilet Bathtub Shower
https://www.amazon.co.uk/dp/B07D6LRPYF/ref=cm_sw_r_cp_api_glt_fabc_QEX340FR08MEDXD4Q90C?_encoding=UTF8&psc=1
We both have long hair so I suspect that could be the problem but we do regularly clean the plug bit - pic below. I've tried the normal plunger just and whilst nothing seemed to happen it is flowing down far better.
Thanks for the link I've ordered one as I suspect we may need one in the future!
After the same issue last night I've just plunged the shower with the plunger @newhome recommended.
Plot thickens ... Best way of me describing is by highlighting the plans with the areas.
In the ensuite where the bath is, is where our shower is as we switched them round. When I plunge the shower the toilet in the cloaks makes a gurgling sound and water rises and falls so what I'm doing in the shower in the ensuite has some impact on the toilet in the cloaks! The toilet and sink in the vanity unit in the ensuite - the same room as the shower is not impacted at all strangely.
Screenshot_2021-04-26-23-12-32-983_com.google.android_apps_docs.thumb.jpg.627c46cc173417be5d7c8f883515cc18.jpg
  • Confused 1
So what happens to the shower trap level when you flush the loo in the cloaks?
The plan does not help much without seeing a plan of how the pipes are actually connected.
This.... Bit of gurgling and movement. Toilet water levels following plunging are a bit low in the ensuite too.
Which we have asked the builder for time and time again. We have sent a sternly worded email to the builder about outstanding work, render, EWI etc and hopefully this will trigger some sort of action and this is now added to the list.
I don’t know much about plumbing but I did read on here that you are supposed to avoid back to back toilets.
If plumbed wrongly, there is a risk of "swapped contents"  I think it was @joe90 that first mentioned this some time ago.
Yes, I came across this actually happening in a pair of semi,s (luckily the neighbour was a relative!). Back to back toilets (on a Dividing wall) connected to a “double branch 92’ “.
edit, this was on a near horizontal pipe not a vertical stack, I doubt it would have been a problem with a vertical stack due to gravity (but still not something I would like to do).
Edited by joe90
After an unsuccessful visit by the plumber last week with lots of head scratching we were still waiting for a solution.
Last night's toilets all started backing up and we still have the issue above but noticed the utility sink drain outside wasn't going down either.
Guy who did all drains and septic tank came out today. The issue.....Get ready for this you won't believe it...
When the electrician came out 19 days ago to work through some final issues/snagging he turned off the fuse to the treatment plant/pump but didn't tell anyone or turn it back on. It took 19 days of not having the treatment plant or pump working before everything slowly started to back up and not flow. Flicked switch back and hey presto everything hunky dory. Spark must have flicked it off at some point.
He's coming back on Wednesday so I'll be having words!
Does the pump / tank not have an alarm fitted for the high level alerts ..?? Most pumping station should  have them.
Not sure to be honest but given it was turned off at mains (fuse box) it wouldn't have made any difference!
Yeh it should - most of the pump station controllers have  pump failure alarm along with a liquid level alarm, but some come fitted with a power failure alarm.
This sort of thing should be used with a battery backup.
https://www.tanks-direct.co.uk/high-level-alarm-battery-backup-for-sewage-pumping-station-cw-float/p3139
They can also be retrofitted with a power failure alarm.
